frankn
PS Audio DirectStream Memory Player 2016
120 posts in this topic
PS Audio are developing their own music server. I'm guessing it will have a disc importing capability. If it can send CD and SACD data to a DirectStream DAC in the same way that the DirectStream Memory Player does, within the confines of a proprietary PS Audio ecosystem, then that would be the route I wish to pursue.
If my DSJ sells before then, well, I'll just have to buy another one (assuming it will be required for a secret handshake with the PS Audio Octave music server).
Edited by WhakPak
4 hours ago, Jumbuck said:
The DSJ is still an OK DAC to stream to though.
This is getting slightly off-topic (along with WhakPak's discussion of his sale of his products)  :  Another very good review on the DSJ  -  http://www.hifiplus.com/articles/ps-audio-directstream-jr-digital-to-analogue-converter/
Summary
At £3,700 (with an included 1 year Roon trial subscription included) this is not an inexpensive piece of kit. However, the few units I have heard that can reach the analogue heights achieved by the DSJ have been either its bigger DirectStream brother or a handful of other products all coming in at several times the price. Nothing I have heard at this price point thus far has had the word ‘Analogue’ floating in my ears from the start of listening. Enthusiastically recommended.
Further off topic - but from the PS Audio forum - Paul's post:
Octave, just to be clear, is the name of the music management software that will control a number of future PS devices and people’s music libraries. The first server to incorporate Octave will be our top of the line and yes, it will include a ripping engine. It’ll be completely automatic. One can sit and stuff discs in while watching TV and drinking beer and Octave does the rest for you.
Big goal - lets hope they can make it a reality within a reasonable timeline and within reasonable cost.  Wait and see.
I wish the phono would hurry up too!
Oops I digress :unsure:
1 person likes this
..they also have new speakers stewing in the PS Audio skunk works. Makes me wonder if it will ever end.
I'm listening to my DMP tonight, it's a tough call giving up on something that sounds so good. I'm considering work-around solutions, particularly whether it is possible to rip a perfect copy of my favorite songs from a number of different CD on to a DVD. This will significantly reduce the flux density of CD case mines in the CD case minefield in front of my DMP.
1 person likes this
Just purchase one of Duc's Reference phono stages and be done. ;)
I shall have a look thanks Frank.
 I would like to have the BHK trio though.
I went and visited an audio buddy yesterday to have a good listen to his new PS Audio chain.  He has the power conditioner, DMP, whatever the matching DAC and an amp the same physical size as one of your units Frank.
It's all just 3 weeks old!
...Very, very nice!!!
It seems there is some glitch though that needs to be sorted re the DSD/ SACD playback that still isn't happening.  My friend said that the man from Magenta was heading east to VIC soon for another matter and, that while he was in town he would personally come and sort this.  Pretty good customer service there.  I didn't realise that 'hifi' and 'customer service' could actually be used in the same breath for the last two decades.
So how good is it going to sound when DSD is happening?  Looks like I will need to head down the Coast again to find out for myself after this glitch is rectified.
1 person likes this
If the DMP is connected to the DS DAC using the HDMI cable that came with the DMP, there should be no issue with SACD playback. If the DS DAC is detecting PCM for SACD playback here is probably an issue with the HDMI cable, or the I2S jack on either the DMP or DS. Another thing to check is that the SACD mode on the DMP is set to stereo SACD and not redbook CD. Another thing to check, make sure only the HDMI cable connects the DMP to the DS DAC just in-case the DAC is locking on to the DMP via another input.
If all these things check out OK then re-flashing the software might fix the problem. If the owner has trouble re-flashing the firmware contact me via PM and I can email him a force version of the firmware that should work. Or, just wait for Magenta to deal with it.
p.s. remind the system owner to check that the video engine of the DMP is turned off (not that this will be causing the problem).
Edited by WhakPak
1 person likes this
Hi Red,
whackpak's comments are right on the money - he should know since he also owns the same.
Does your friends unit play cd's ok and the cd layer of an SACD but not the SACD layer?  As long as DMP default is set to play SACD and the DMP is connected via the supplied PS Audio HDMI cable it should work. If it isn't playing SACD layer does your friend have another HDMI cable to try?  I'd use a cheapie to check. Also as Whackpak said make sure video is off in the DMP.
...if none of these suggested fixes work I'd be most surprised, and if so, there is nothing else that Magenta could try other than swap out the DMP for another one.
Did you notice what resolution the DS was reporting when the DMP was playing SACD, was it 88.2/24? If the DMP detects an I2S connection to DS DAC (whether or not that input is selected on the DS), all of the other digital outputs of the DMP will be disabled for SACD playback. So if the DS DAC is showing 88.2/24 for SACD playback and the HDMI cable is connected, is a good indicator that the DMP is not seeing the I2S connection to the DS DAC.
Edited by WhakPak
WhakPak, appreciate all your posts on the PS gear.
Luckily I don't mind in the least getting out of my chair to change a CD, being half as often compared to a record.
The mentioned pricing of $8k for the CD spinner and another $8k for the super DAC is testing the Australian market for sure, and have come in a bit higher than expected.
So we need quite a few interest rate rises to get the desirability of the Aust dollar up again to achieve USA parity like just a few years ago. Then hopefully the price might drop by 25% and I'll jump into spending action.
Meanwhile my McIntosh SACD 500 still sounds fine.
1 person likes this
Buy 2nd hand. Always a good option.
Always a good option?  Absolutely, I just must have patience...., and then dive in!
what's holding you back, check the for sale listings.
3 hours ago, Anthony1 said:
...The mentioned pricing of $8k for the CD spinner and another $8k for the super DAC is testing the Australian market for sure, and have come in a bit higher than expected...
The PS Audio prices are about parity for the US and Australian markets. It might come as a surprise but the RRP of the Directstream Junior DAC is cheaper in Australia ($4,695 AUD) than the US ($3,999 USD).
I heard the new DMP last Sat. - that's the one I want!  And you need the matching DAC too.
I will wait, I can start saving now...
It does sound good, no doubt. I've been listening to Adele all day on DMP, after going to the concert in Perth last night.
1 person likes this
Currently listening to Dave's True Story on mine - beautiful vocals, amazing depth, soundstage, realism - a listening pleasure.
1 person likes this
DTS?  Frank - your DMP deserves to play better than that sanitised material.
I know you have real music in your cave, I have seen it, heard it.  Get that happening.
    • By frankn
      Item: PS Audio PerfectWave Transport (Memory player) / EASTER SPECIAL
      Price: Last Pitch to get it sold ONLY 1600 (waiting to go to *bay) and I'll cover shipping and insurance with Australia Post - see example costs below.
      Item Condition: Superb - see pictures
      Reason for selling: Upgraded
      Payment Method: Pickup - Cash, Australia Post COD, EFT (preferred), PayPal but you pay charges on top of other pricing
      Extra Info:  I am the original owner.  Original boxes & packing (double boxed, unique 'cradle' for unit) will be used for shipping.  Included are the plastic top cover (will be in-place when shipped), manual, white cotton gloves, standard remote (not the one in the picture), standard power cable - as delivered to me when I purchased it.
      Warranty until 21st March 2018 - Magenta Audio confirmed the warranty is transferable.
      Unit has worked without any issue from day1.  Superb transport.
      BUY WITH CONFIDENCE - although I only have 1 endorsement you can look back at my sales - Weston KT150 Topaz Mono-blocks, Meridian CD, DEQX, ME850 etc.  No-one has had ANY issue with units I sold.
      I checked shipping and insurance costs via Australia Post calculator (box size 62/52/25cm), used weight = 12Kg, insured value = 2500.  Results;
      ADL - Nth Perth, WA = $104.15 (add $13.05 if you want to pay via Australia Post COD)
      ADL - Brisbane, QLD = $91.55 (add $13.05 if you want to pay via Australia Post COD)
      ADL - Hobart, TAS = $116.75 (add $13.05 if you want to pay via Australia Post COD)
      Huge amounts of information on the WWW, also search SNA.
    • By Magenta
      Item: PS Audio Perfect wave Transports (PWT)
      Price: PM
      Item Condition: excellent
      Payment Method:
      We have a number of PS Audio Perfect Wave Memory Players for sale at excellent prices. These have been traded in against the new (amazing) DirectStream Memory players. PM me for details. Regards Mike
    • By Tivoli Hi-Fi
      Item: PS Audio NPC Nu Wave Phono Converter Black or Silver
      Location: Tivoli Hi-Fi 155 Camberwell Road Hawthorn East VIC 3123
      Price: SOLD including Shipping anywhere in Australia (RRP is $2595)
      Item Condition: Silver Ex Display, comes with all original packaging and full Australian Warranty. Black is SOLD
      Payment Method: Direct Deposit, Paypal, Cash - Pickup in store, Credit Card including AMEX with no fees or penalties.
      PM Tivoli Hi-Fi staff [email protected] hours for prompt response.
      Extra Info:  Take the best analog phono preamplifier PS Audio can make, combine it with a state-of-the-art Analog To Digital Converter, place them both in a hand crafted chassis, add a massive power supply, provide fully balanced class A analog outputs as well as multiple digital outputs including DSD and PCM and you have the NuWave Phono Converter.
      Flexible loading and gain options to suit any MM or MC Cartridge. For those that want to digitally catalog your vinyl collection the NPC can encode your vinyl as FLAC or DSD, cooool!
      RCA or XLR out, the NPC ticks every box!
    • By Tivoli Hi-Fi
      Item: Trade In PS Audio DL3 DAC
      Price: SOLD
      Item Condition: Trade in item in excellent condition.  No original box but can be shipped safely. Item comes with power cord and printed manual.
      Extra Info:  Highly regarded DAC made in Boulder Colorado. 24/192 DAC with USB, Optical and Coaxial inputs and XLR or SE outputs.
    • By Tivoli Hi-Fi
      Item: Trade In PS Audio GCPH Phono Stage
      Price: SOLD
      Item Condition: Trade in item in excellent condition.  Comes with original box and accessories including manual and remote control.
      Extra Info:  Highly regarded phono pre in outstanding condition. Balanced and SE outputs, adjustable gain and loading for MM and MC Carts.
