Rec. 709
ISF Calibration Photos
114 posts in this topic
I used to have one of those Datacolour ones on the far right, worked well enough, but God it was slow compared to my current Xrite i1Display pro,  doubt I would have the patience to use one again, especially when the need of repeated metering at the 10%-30% range.
1 person likes this
You were one of the lucky ones if yours was reasonably accurate. I love the display pro, it's fast even with measurement smoothing enabled.
Sent from my SM-G935F using Tapatalk
Been working out at the SA Film Corporation this week. The picture below is taken from a 55" Panasonic ST60 and the film is "52 Tuesdays" with the colour grading etc. performed by Closer Productions Studios.
ah the old plasmas still going...great to her theyre using one for grading and such !
1 person likes this
Is that the [or one of] the  monitor that they use to colour grade on ?
Reason I ask is not for info on the monitor itself, but on the background colour of the wall paint.
For critical work I have my calibrated monitors sitting with a background that is equivalent to a 15% Grey card....except in Blue [well the whole room is painted that colour ]....I guess that shade of Brown / Dark tan would be similar , it certainly makes your eye focus on the screen without strain, which can happen with either a darker or lighter background wall colour, not something you want when colour grading.
OT: I don't know how long you have owned you Xrite i1 Display pro [I bought mine within weeks of it's release- forgot when that was - several years ago anyway ], but I've noticed that the Rubber surround  is starting to get really tacky on my unit, which is a bit disconcerting.
Maybe it's the horrible Sydney humidity we have been suffering recently, but from my previous dealings with rubber that has become like this is....Not Good.
Edited by Tweaky
They used a combination of the plasma and and a mac for grading. I used to use 70% grey with a bias light when I was running with a projector.
Sorry to hear about your meter. My i1 Display Pro is a few years old now (I profile it to a spectro to maintain accuracy) and it has aged particularly well. I used to keep it in Vanguard case to protect it from humidity, but don't tend to these days.
Some shots of an older Sim 2 projector, which I re-calibrated for a client. In case you're wondering, the grass in the third shot is a little too 'vibrant', but this is the source material
1 person likes this
Hey mate, do you find that the display pro has drifted much over its life?
I'm pretty sure my old i12 is waaaaay out now, and I'm tossing up whether I should try and find an old i1 pro to use to profile it, or just grab a new spectro like the display pro and run that instead.
I figure being able to reprofile with a spectro helps in the long run, but the risk is in not knowing the state or history of an old second hand unit.
Any thoughts?
I'm pretty sure you can send your meter to Image Science in Victoria to be re-calibrated....cost ?
https://imagescience.com.au/
It would be a damm sight cheaper that a replacement unit, plus, depending on software being used, you wouldn't have to go through the palava of getting a new meter registered to work with your software [something to consider]
They only really go out of whack if left near a heat source [like left on top of a amp or PC ], my unit functions just fine, it's just the rubber around it that I have concerns about.
As for the SIM2 calibration.....A early DLP PJ judging by the look of the photos, probably a 2 chip one.
Looks like a fair bit of age on the lamp judging by those photos, then again, 10+ year PJ's with a new lamp tend to look like that anyway....tech has moved on.
My first ever 3 Lens CRT PJ was a SIM2, I used to work in a pub and they had taken it down thinking it was broken.....I said what are you doing with that?....Reply, Nothing, you can have it if you want....OK, I'll take it....I had it up and running within 48 hours....Took me ages to learn how to focus & calibrate it though [Manually with little plastic tools bought from Jaycar ]...Thanks AVS CRT section and Guy Kudo's , Yiikes Holy Focus! post [sticky] I wouldn't have been able to do it otherwise.
Edited by Tweaky
Any thoughts?
I would have a serious look at a new display pro colorimeter. I have had one in my kit for a while now and hasn't drifted that much and what little drift there is is far less than other colorimeters I have used.  I suspect this is largely due to its sealed design. If you want to take things a step further, you could always add a new i1pro 2 spectro down the track to profile against.
Single chip DLP Domino D60, the customer still loves it and has no plans to move on as yet. I can't recall how many hours were on the lamp, but it had clocked up a few.
Do you still have the CRT?
Some shots taken of an Epson 9200 which I calibrated for a client yesterday... apologies the middle shot is a little out of focus, it's a little hard to capture these some times. :-)
Edited by Rec. 709
typo
1 person likes this
I was hoping you would post photos of this model Epson or the 9300 , but considering the 9300 already has the inbuilt ISF metering, your services would be unlikely to be called upon to calibrate that.
What is this referenced to?.....Extended gamut or 709 ?
I've seen a review online that says it doesn't do the extended gamut of 4k.
http://www.projectorjunkies.com/epson-tw9300-full-review-2/
Test results below......looks out of whack to me.
I've been looking at getting this PJ for several reasons, mostly black level and latency for gaming [seems fine at 1080p].......But, looking at those photos above, I'm reconsidering even bothering getting a demo....the left side of the top photo seems to have pixels that are slightly misaligned, unless that is some chromatic aberrations of you phones camera lens [It hasn't made a appearance in previous photos you have posted, that's why I think it's a fault of this particular PJ]
To my eyes, the contrast is spectacular for a PJ in this price range, until you look at the low level blacks, then that contrast ramps downwards quickly from I estimate 25% to 0....it just looks flat at those lowest levels, probably only because everything else looks so good in comparison.......similar to have a great floorstander speaker  that does everything brilliantly but is let down by the extreme bass. where it sound 'one note' .
As for the CRT PJ's.
No the SIM2 went many years ago, I swapped it for a HTPC build for me by some Uni students.
I replaced it with a NEC CRT PJ that I bought from a forum member of a now defunct Aussie HT forum [just as the original incarnation of this forum started - before it became Stereo.net ]
Actually I still have some spare parts if you run across anybody needing any for a NEC 6PG or 9PG...I have a set of NOS Tubes, a setup remote, deflection board, and point board- which gives finer picture convergence points between the 3 lenses electronically.
Cheers mate, your sentiment echoes others I've heard on the display pro.
I probably should calibrate my work monitors too, so maybe I can convince the boss we need one for the 'office'... :)
Sent from my HTC 2PS6200 using Tapatalk
