pcking Posted July 22, 2016 Share Posted July 22, 2016 Just curious if any music lovers still using there Pono's , and are they happy. 1 Link to comment Share on other sites More sharing options...
Luc Posted July 22, 2016 Share Posted July 22, 2016 Interesting. I was only wondering the same thing the other day. They seem to have dropped off the radar a bit. Do you like yours then and is it all that you expected? Link to comment Share on other sites More sharing options...
LogicprObe Posted July 22, 2016 Share Posted July 22, 2016 I use mine all the time. It's great! Link to comment Share on other sites More sharing options...
woadl Posted July 22, 2016 Share Posted July 22, 2016 Yes still using mine it's taken over from my IPod classic Link to comment Share on other sites More sharing options...
LogicprObe Posted July 22, 2016 Share Posted July 22, 2016 Yes still using mine it's taken over from my IPod classic Yeah..........I used to use my iphone for my portable player but the Pono sounds so much better. 1 Link to comment Share on other sites More sharing options...
pcking Posted July 23, 2016 Author Share Posted July 23, 2016 I usually use it a few times a week, particularly enjoy early Stones music. Would like to get around to trying the balanced out option one day , anyone here gone that way yet ? Also battery run time is a bit short, maybe Pono 2.0 might change this , if it were to happen. Link to comment Share on other sites More sharing options...
Volunteer sir sanders zingmore Posted July 23, 2016 Volunteer Share Posted July 23, 2016 Store is "under construction "? https://www.ponomusic.com Link to comment Share on other sites More sharing options...
pcking Posted July 23, 2016 Author Share Posted July 23, 2016 Store is "under construction "? https://www.ponomusic.com I believe there linking up with 7 Digital , after splitting from Omnifone. Link to comment Share on other sites More sharing options...
Volunteer sir sanders zingmore Posted November 5, 2016 Volunteer Share Posted November 5, 2016 On 23/07/2016 at 11:31 AM, Sir Sanders Zingmore said: Store is "under construction "? https://www.ponomusic.com Still under construction. What's happened? Link to comment Share on other sites More sharing options...
Rob181 Posted November 6, 2016 Share Posted November 6, 2016 Waiting for the concrete to set... 4 Link to comment Share on other sites More sharing options...
LogicprObe Posted November 6, 2016 Share Posted November 6, 2016 Had mine in the car for a long drive over the weekend. Excellent! Carries a lot of music well. Link to comment Share on other sites More sharing options...
PicoWattson Posted January 11, 2017 Share Posted January 11, 2017 Still using mine and it has also replaced the Ipod. But using it single ended is definitely not utilising it to it's full capacity. Big difference with the balanced cable. Link to comment Share on other sites More sharing options...
woadl Posted January 11, 2017 Share Posted January 11, 2017 Can I ask what software are you using now as the new PonoVault is next to useless Link to comment Share on other sites More sharing options...
PicoWattson Posted January 11, 2017 Share Posted January 11, 2017 Don't bother with the internal memory. Drag and drop straight onto a 64GB micro SD card through Windows Explorer. 1 Link to comment Share on other sites More sharing options...
Guest cavillor Posted January 14, 2017 Share Posted January 14, 2017 Dead duck, that Pono. Link to comment Share on other sites More sharing options...
PicoWattson Posted January 15, 2017 Share Posted January 15, 2017 Eaten dead duck, and I must say delicious.... Link to comment Share on other sites More sharing options...
