Need a learning remote to control one AV system (TV, amp, BD, Foxtel) - must be easy to set up and use. Anyone got any recommendations?
Cheers, nosepeg...
Cheers, nosepeg...
I use a Logitech Harmony, nosepeg. Cable into your computer, select your components from huge database, then enter activities e.g.Listen to CDs.
Works a treat. Various models available according to budget.
wolster
"Opera is when a guy gets stabbed in the back and, instead of bleeding, he sings." - Ed Gardner
Harmony One, faultless and has lithium re-chargeable battery. Hunt around and you should be able to get one for $180 or so (I think rrp is around $400).
Music: Leema Antila CDP, Musical Fidelity A5cr pre/pwr, B&W 802D's, Chord Signature interconnects & speaker cable, Thor PS10 Pwr Stn.
HT: Pioneer KRP-600M, DVDO Edge, Denon AVR2805/A5cr pwr, Fox HD, Sony BDP-S550, B&W 802D, Monitor Audio GRLCR, GR20 surrounds, GSW12
The Logitech Harmony series are great , we have been using a couple of the entry level ones for years and once setup there are simplicity itself to use.
Setting up the the first time can be a bit daunting but you just take your time and follow the wizard based system.There are plenty of hints and tips built into the wizard but if you get stuck you just call Logitechs Harmony support line and they will guide you.
Great product and great service
2Ch: Audio-GD CD7SE transport , Satch NOS DAC with valve output stage,Supratek Chardignon with psu updates , Yamaha M60 power amp HF AND MF bi amped with Rotel RB1080 LF B&W 703's:HT:Panasonic AE700 projector ,Pioneer 508XDA,Samsung BDP 1400 BR player , Olin HD STB,HTPC, Yamaha RXV1800 avr,Tannoy Saturn S8 mains , Saturn C6 ,Whtamough Tempest 2 sub,Tannoy R1 rears.
Like evryone else says, harmony. Very high WAF. Different models depending how you like using it - one hand, two hand with big screen etc. I have a 1000i which is the two handed big screen jobby. Mrs_G likes the screen more than our old 880.
Meridian G98DH - Meridian G68 - Meridian 5200s - SGR Wingnut sub - Meridian DSP3100s
Yep, Harmony it is. We've got the Harmony One which is easy to set up and can be as basic or as all encompassing as you want it to be.
Speakers: Dynaudio Confidence C1 - Amplifier: Primare I30 - Source: Raysonic CD128 - ICs etc: Yep! - Visual: Pioneer 508XDA 50" Plasma
http://www.logitechshop.com.au/shop/...px?itemid=3480
this is what i use. I got a 3 pack and my mum uses 2 up home. cost me $75 each in the end
2 Channel - Project Debut 3 (Ortofon 2M Red) : Yaqin MS12 : NAD C542 :Lite DAC AH (CAA) : Redgum i35 : VAF DC 7
2.1 Channel - Keces 151 : NAD 325 BEE : Tavagan 3" : B&W 608
5.1 CHannel - Denon 4308A : B&W 683 : B&W HTM61 : B&W 685 : Velodyne CHT 12Q
+1 for the Harmony.
We have a 520, 525 and 785. All have been easy to set up and very reliable. WAF is extremely high as Mr_Gimlet says.
MUSIC ROOM = Linn Axis + Akito Tonearm + Ortofon 2M Black + Naim CD5i + Squeezebox Classic › Maverick TubeMagic DAC › Cayin A-55TP › PMC GB1i
TELI ROOM = Technics 1210 + Creek OBH-8 + Rega Apollo + Mac Mini + Samsung 46" LED 6000 series › Harmon Kardon AVR 255 › B&W 602
SHED = Rega Planet (deceased) + NAD Cassette + Pioneer Tuner › 70's Monarch Amp › Crap shed speakers
There you go, Bunyip
Just in case there is any doubt - Harmony!
Can take a little time to set up initially and get your mind set right, particularly if you want to get the most out of them.
I would not contemplate a mutli-box set-up without one.
Ta Gents - Harmony it is then - will do some hunting around...cheers, Nic.
I have to agree with Logitech guys, i owned the Harmony 880...it has screen simplicity that makes easy to use..you just need to follow the instructions to setup correctly and you are set!
Another vote for the Logitech Harmony One
Owned various Harmony remotes wore one out, have 785 now, love it, the colour buttons just right to control STB too, only problem is wife can use it, so my ch flicking days are over!.
Yep Harmony One here as well![]()
Sources: Marantz SA8003, Laptop & Flacs & Benchmark DAC1 USB Amp: Krell KAV300i, Speakers: VAF I-91, REL Strata III Sub Home Theatre as above + Centre: Duntech Onyx, Rear: Sonique SAV1 Receiver: Denon AVR2106, Sources: PS3, Panasonic DVDRec Other: Perreaux SXH1, AKG 702
wolster yours looks blonde Ive heard they dont work all that well and often play p - try this one
I have a Harmony 785 but it has seen a lot of use in the three years or so and a couple of buttons are not playing nicely any more. It has been a superb remote for the most part, but I am wondering if any other people with the same model are experiencing similar things? It is the right-arrow button on mine that is most dodgy - annoying as it is the ad-skip one.
If there is nothing that can be done about it, what would be the best replacement that has the colour code buttons available?
Note to OP: I don't wish my experience to put you off the Harmony 785 - could just be we are heavy on the buttons, but the Harmony has been excellent for us - easily programmed (after a bit of practice) and easy to use.
Al.
Bookmarks
