+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    quick question regarding head phone amp
    Hey guy's i just have a quick question about head phone amps and how they are connected.I know that most(if not all?) of them connect at the rear via rca interconnects.My question is though,do you connect them directly to your CDP(I'm using a DVD/CDP which has a dedicated 2 channel output at the rear)
    Or do i connect to my amp via one of it's outputs?Does it make any audible difference?
    Marantz SR4300
    Samsung series 4 50'' Plasma
  2. #2
    Member Batty's Avatar
    Join Date
    Oct 2009
    Location
    Dernancourt SA
    Posts
    984
    I usually just connect my source directly to the headamp
    Analogue setup : 1986 Townshend Rock Mk2/AO rewired RB250/Goldring 1042 + Denon DL-110, Copland CSA-14, Castle Howards.
  3. #3
    Moderator Jake's Avatar
    Join Date
    Sep 2007
    Location
    Happy Rock
    Posts
    6,449
    You can do either. I have mine (it has 2 switchable inputs) connected to both my turntable directly, and also the fixed output of the preamp.
    Jake
    Analog:
    VPI Scout, 2M Black, Luxman PD272, Graham Slee Green Reflex Digital: Denon DVD-2900, Sonos DAC: Stello DA220 MKII Pre: Conrad Johnson Premier 17LS2 Power: ME550II Speakers: Audiovector M3 Avantgarde SW: DIY Headfi: AKG-701, ER4P, Graham Slee Green Solo PJ: TW2000
  4. #4
    Member braddo's Avatar
    Join Date
    Jun 2008
    Location
    wollongong
    Posts
    321
    Go straight from source to the headamp. If you do go through another amp make sure it's just a 'pass through' type situation, otherwise your going to get your amp sound come through your headamp, and then then the head amp sound on top of that which you DON'T want. What head amp have you got? What outputs has it got?
    Or, has your source got 2 different outputs? That would be best, one to your amp, one the other to your headamp.
    mark levinson 36s > me24 pre > me850 > royd doublets
    raysonic cd128 > red dawn IC > me24 pre > k701/edition9/hd595
  5. #5
    Join Date
    Sep 2008
    Location
    Perth
    Posts
    37
    less connections the better. It is only tricky when your source is also hooked up to another amp and the source does not have multiple outs. It also depends on whether your amp has a dac in it or not. My little dot mk III does not, so I just have it hooked up from the sound card on my computer. Also, are we talking portable amp or stationary?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Sponsors
Donations
StereoNET is a free resource provided to enthusiasts of HiFi and Home Theatre. If StereoNET has helped you in some way, please consider making a small donation to show your support.
Facebook
