Greetings all - this is my first post - I've been lurking around and reading and absorbing all the great information and advice on the SNA forum. I want to get some ideas and advice on improving my room acoustics.
My listening room is about 4m long x 3m wide x 2.8m high. On one side of the 3m long wall is a window - the other side is the door to the room. The other 4m long wall is bare. All walls are double brick and plastered. There is carpet and a nice rug over the carpet as well.
A 42" plasma is mounted on the 4m long wall in the middle and I sit pretty much in the center of the room on a leather lazy boy - with the 5.1 speakers in the obvious layouts. I run both a HT setup and a stereo setup in the same area.
After reading some posts I decided to place an un-used bed matress on the rear bare wall, and placed a thick blanket over the plasma directly in front of the listening position. The imaging and clarity improved a great deal.
Rather than using the blanket and matress - I've decided to invest in some purpose built and eye pleasing alternatives. I'm thinking of purchasing the Soft Sound Pyramid Studio Foam for the back wall, and Soft Sound Anechoic Hanging Baffles to cover the front facing wall - from http://www.soundproofcow.com/
Can anyone comment on the use of these two products ? Or recommend similar or better products - preferably obtainable in Australia.
Thanks in advance.
Will post some pics as soon as I figure out how to.
Regards
Ken
Bookmarks
