+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 25 of 26
  1. #1
    Member everyones_shadow's Avatar
    Join Date
    Apr 2007
    Location
    Adelaide
    Posts
    459
    Will an old AVR do?
    Hi all
    Am I right in thinking that if I buy a Blu-Ray player with all modern decoding chips and features that I could feed that into an older AVR using just the volume control, input switching and power amps from the AVR and letting the player do the digital processing?
    I realize I wouldn't get speaker/room correction but would I lose anything else? There are 5.1 AVRs from most of the good brands on eBay for less than $200.
    ES
    Stereo: LP12 Lingo, Akito, Denon 304, MF X-LP
    Trichord Genesis, Krell 300i, Vaf DC-X GIV Mk2
    HeadFi: MF X-Cans v3, Sennheiser 650
    HT: Pioneer 655, AE Aego 3.1, Panasonic G10 50" Plasma, Panasonic PVR, PS3 (for BD), XBox 360 (for media)
  2. #2
    Moderator Jake's Avatar
    Join Date
    Sep 2007
    Location
    Happy Rock
    Posts
    6,448
    You wont get HDMI.
    Analog:
    VPI Scout, 2M Black, Luxman PD272, Graham Slee Green Reflex Digital: Denon DVD-2900, Sonos DAC: Stello DA220 MKII Pre: Conrad Johnson Premier 17LS2 Power: ME550II Speakers: Audiovector M3 Avantgarde SW: DIY Headfi: AKG-701, ER4P, Graham Slee Green Solo PJ: TW2000
  3. #3
    Join Date
    Apr 2007
    Location
    Adelaide
    Posts
    459
    Quote Originally Posted by Jake View Post
    You wont get HDMI.
    Ah. That matters. Thanks. When was HDMI introduced?
    ES
  4. #4
    Member mr-happy-pants's Avatar
    Join Date
    Aug 2006
    Location
    Melbourne (where all the GtGs happen)
    Posts
    1,819
    Older units with HDMI would be the go...
    Please! Please! This is supposed to be a happy occasion! Let's not bicker and argue about who killed who.
  5. #5
    Member joz's Avatar
    Join Date
    Apr 2006
    Location
    CSI Elwood,Not so sunny playground of the not so rich and famous
    Posts
    3,476
    The older units will not accept 1080p even as pass through I believe.
    If they only have component 1080i will be maximum,which is still really good but still less than what the format can provide.
    When your talking about older,how old?
    Overall the later the reciever the better the tech.
    If you get the player to do the decoding,I believe that you will need at least 6 analogue inputs on the reciever.
    CHEERS THE JOZ!!
    Peace love and mungbeans
    Bring on the Illuminators
    Expectant father waits patiently..
  6. #6
    Member jel's Avatar
    Join Date
    Sep 2006
    Location
    Adelaide
    Posts
    218
    Depending on how much 'all in one' functionality you want, HDMI doesn't matter.
    You can get a player with analogue outputs (ie OPPO-83, Pana BD-80, Sony 550) and an AVR that has 5.1 analogue inputs,
    Then you can:
    - Connect your BluRay player HDMI (or component video) direct to your display.
    - Connect the analogue output of the player to the 5.1 input of the AVR
    This will give you the high quality picture and audio, without needing a newer AVR with HD audio decoders and HDMI.
    TV : Samsung DLP SP50L6HX ; HTPC : 2 x AverMedia A177 ; Blu-ray : Panasonic BD-35 ; DVD : Pioneer 969avi
    AVR : Yamaha RX-V1800B ; Power Amp : Rotel RMB-1085 ; Front : VAF i66 Mk1 ; Centre : VAF i66cc Mk1 ; Rear : VAF DC-7 ; Sub : 2 x VAF DC-S
    Misc Audio : Sansui AU-317,
    Hafler DH-200, Sony 725D, Rotel 211, Technics ST-S3, Technics SL-Q2, AR-93, B&W CC6
  7. #7
    Member Batty's Avatar
    Join Date
    Oct 2009
    Location
    Dernancourt SA
    Posts
    984
    My panasonic has no idea what HDMI is so I feed directly from my WDTV media converter to the TV and feed the optical output to the receiver.
    Analogue setup : 1986 Townshend Rock Mk2/AO rewired RB250/Goldring 1042 + Denon DL-110, Copland CSA-14, Castle Howards.
  8. #8
    Older AVR's generally can be picked up for a lot cheaper and have better amp sections in my opinion, if your using it just a multi channel pre+amp Id go with an old avr.
  9. #9
    Member ENIGMA's Avatar
    Join Date
    Jul 2008
    Location
    Melbourne
    Posts
    1,164
    Just use optical out on the bluray player to the AVR & HDMI to the panel/tv.
    Don't worry too much about the new decoding formats and enjoy it in 5.1 from the AVR.
  10. #10
    it will all work just fine
    here is what i do
    run hdmi into a hdmi 4 way switcher. From there to my pj. This will allow you to have 1080p if needed
    use digital coax from the blu ray to the avr. instead of true dolby digital or DTS MA you will have normal dolby digital and DTS
    works a treat for me
    Source: Analogue VPI HRX wih super platter, JMW 12.7 arm, SDS power supply, Cart: ortofon jubilee, Phono Stage: Musical Surroundings Nova Phonomena, Digital: Esoteric X-03SE, Pre Amp: Moon P5, Amps: 2 x SGR Elite EL15s, 2 x SGR Elite EL30s Main Speakers: SGR Octagon Active, Center: SGR CX3C, Subs: 2 x SGR SV15
    PICS HERE
  11. #11
    Join Date
    Jul 2005
    Location
    Western Sydney
    Posts
    532
    Quote Originally Posted by ENIGMA View Post
    Would this possibly lead to syncing problems between audio and video?
    Owner of Crave Audio, dealers in Bel Canto, Nuforce, Oyaide, and others
    Preamp - Nuforce Pre9 - Belcanto Pre3VB Power amp - BelCanto Ref1000 mkII - Nuforce Ref9SE v3 Speakers - Proac 2.5
    Sources - Squeezebox Transporter - Bel Canto CD2 - Bel Canto DAC3.5 - Belcanto VBS1.
  12. #12
    Join Date
    Sep 2007
    Location
    Happy Rock
    Posts
    6,448
    Quote Originally Posted by dlite View Post
    Nope. I do the same and its all perfect.
    Analog:
  13. #13
    Join Date
    Jul 2008
    Location
    Melbourne
    Posts
    1,164
    This problem is usually related to using analog audio outputs & dig video outputs at the same time.
    As you are using a digital audio output, all should be fine.
  14. #14
    BDP with on-board decoding/5.1 outputs + AVR with 5.1 inputs is all you need.
    Forget about using a normal digital connection.
    BD is nothing without HD sound !
  15. #15
    older avr for sale yamaha rxv 795 with 5.1 inputs [and 5.1 preouts] about 8 years old with remote and manual no faults pick up from melbourne $100. was a mid level amp.
    cheers jeff.
    4
  16. #16
    Member Paul Spencer's Avatar
    Join Date
    Jan 2005
    Location
    Melbourne
    Posts
    1,557
    I'm looking at getting an older receiver as well, but I wouldn't go that cheap. I'd look for component video inputs as a minimum. I don't see a reason you should have to give up any features offered by the receiver, although I haven't properly looked into blueray. Surely they would have component video and coax digital audio outputs, both of which are easy to find on older receivers.
    Audio blog | DIY speakers, Rythmik subs & Articles
    Coming soon: New DIY speakers & bass horns
    My work : www.redspade.com.au
    Red Spade
    - creative web design studio
  17. #17
    Member EDGEAUDIO's Avatar
    Join Date
    Mar 2008
    Location
    "THE SHIRE" Sydney
    Posts
    247
    Quote Originally Posted by soundandpictures View Post
    SAP, does this really make much difference using the analogue connections over a digital connection?
    This is how I have my BDP connected to a pre HDMI AVR. Sounds OK but I do notice speaker level issues between different discs.
  18. #18
    Join Date
    May 2007
    Location
    Sydney NSW
    Posts
    71
    I was keen to go this way myself as I have a 3 yr old Arcam pre which has HDMI for video only.Looked at either the Pana BD80 or Sony S550 but doing a bit of research on them I found that users were saying that there was a significant difference in SQ ,when using the 5.1 analogue out it wasnt as good.
    Both these 2 players mentioned above dont have the greatest dacs and this is where the problem lies. I wish this wasnt the case as I love my Arcam[especially its 2 ch] and would have to spend much much more to get a modern AVR which would be comparable to what I have.
    Has anyone compared this? Using same Blu ray player comparing HDMI V 5.1 analogue?
    Dali Suite 2.8 fronts with C.8,R.8 and S1.2 sub. Arcam AVP700 pre with Rotel RMB1075 amp,Rotel RCC 940ax cd player,Pioneer BDP51 Bluray , Kimber speaker cable and I/C's
  19. #19
    Join Date
    Mar 2008
    Location
    "THE SHIRE" Sydney
    Posts
    247
    Quote Originally Posted by EDGEAUDIO View Post
    Well, I've just realised that my Samsung BDp1500 does not have analogue out which is probably why I connected using the optical out which is the only available audio output for older AVR's - Doh!
  20. #20
    Quote Originally Posted by Jeffro View Post
    yes i have and found i preferred just using digital coax from the blu ray player to my processor.
    Others may find it different though as what i found is bass management through the blu ray players was not as good.
    My rotel 1098 has and is still doing a brilliant job.
    The only thing that annoys me about it is the clicking of the relays when the sound format changes.
    PICS HERE
  21. #21
    Member jel's Avatar
    Join Date
    Sep 2006
    Location
    Adelaide
    Posts
    218
    It might be worthwhile adding the OPPO 83 to your research, they seam to get a good review.
  22. #22
    Join Date
    Jun 2005
    Location
    buninyong, victoria
    Posts
    198
    If you can't afford a new avr , then by all means go for an older ( decent) one with inputs you need......l kept my Sony TADA9000es as l really like it , and bought a Pioneer bdp51fd ( great dacs ) and run 7.1 anolgues for sound and hdmi direct to my pj.........works really well
    cheers ken
    2 Ch , Pioneer DV-S969avi , Pioneer bd51fd ,pending Gigawork Big dac , Yaquin 100 b kt88 tube amp ( joe rassmussen modded ) and OB Hawthorne Audio psi 15" slightly modded coaxials with 15" "Auggies" bass drivers driven by a 500w d class plate amp
    Ht 7.5 system , Pioneer bd51fd , Sony TADA9000es amp , Seas and Audax speakers , 1 x 15" ported sub , 4 x 18' IB sub array ran by behringer 2500 amp
  23. #23
    if you buy a good blu-ray player (ie with good speaker set-up/bass management etc, good analogue stage), that also has full decoding for all the HD audio codecs, then you should be better off using the multi channel (5.1 or 7.1) analogue outputs into your AVR. this way you still get lossless audio.
    for various reasons though, you may find using S/PDIF provides better sound (even though you cant get lossless audio this way), as John A did. So best always to check for yourself.
    as already mentioned, hdmi can then be run straight from the player to the TV, so no need to worry about that in the AVR.
    Lounge Room: Hitachi 42PD8800TA Plasma, Foxtel iQ2, Beyonwiz DP-S1, Sony PS3, Sonos + Sonos iPhone Application. HT Room: (under construction) Monitor Audio GS60, Monitor Audio GS LCR, Monitor Audio GSFX, Denon AVR-4308A, Denon DVD-3930, Sony BDP-S5000ES. TBC: Subwoofer, 2ch integrated amp, CD/SACD player, Record Player, Phono Pre. For the love of god when will it end?
  24. #24
    Join Date
    May 2007
    Location
    Sydney NSW
    Posts
    71
    The Pioneer might be the way to go.
    Correct me if i am wrong but the dacs are not only important in the Blu ray player,but also important in the avr/pre-pro as far as using the analogue out??
  25. #25
    Join Date
    Jun 2005
    Location
    buninyong, victoria
    Posts
    198
    Dacs are important , l went the pioneer because my avr does'nt do hdmi etc and this was the best way for me to go , unless l sold the sony..........if you have a hdmi able'd avr with good dacs then thats the way to go.......no need to have great dacs in both avr and bdp if you have hdmi
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Sponsors
Donations
StereoNET is a free resource provided to enthusiasts of HiFi and Home Theatre. If StereoNET has helped you in some way, please consider making a small donation to show your support.
Facebook
