Hifiplus Posted December 22, 2014 Share Posted December 22, 2014 Just upgraded my surround processor and although it is very good with cd playback I thought I had heard better so I dragged my Audio Note DAC 1 out, dusted it off and fired it up. Sure enough it is superior the problem is I cant fit it in my rack. Im now looking for something as good (better?, although i dont think that is possible) but in a more convenient size. The Ps audio Nuwave looks like it would fit the bill, although Im open to suggestions. Link to comment Share on other sites More sharing options...
scuzzii Posted December 22, 2014 Share Posted December 22, 2014 Chord DAC would be a small unit. Audio GD Ref 7.1 is also very capable. I have both and haven't heard better in what I've tried. Link to comment Share on other sites More sharing options...
Krispy Audio Posted December 22, 2014 Share Posted December 22, 2014 What's your max dimensions for the dac? Link to comment Share on other sites More sharing options...
analog brother Posted December 22, 2014 Share Posted December 22, 2014 trinity dac Link to comment Share on other sites More sharing options...
analog brother Posted December 22, 2014 Share Posted December 22, 2014 hegel hd-25 Link to comment Share on other sites More sharing options...
Galactic Soap Posted December 22, 2014 Share Posted December 22, 2014 Bel Canto DAC 3.5 + VBS Link to comment Share on other sites More sharing options...
Audiobugged Posted December 22, 2014 Share Posted December 22, 2014 trinity dac Yeah this should do it! +1 Although surround processor replacement so 2 to 4 (7.1 = 8) trinity dacs needed... Drop a note to the designer and see if he can do a package deal and I'm sure he'll be more than happy to discuss. Link to comment Share on other sites More sharing options...
Hifiplus Posted December 22, 2014 Author Share Posted December 22, 2014 Never heard of the Trinity dac, will check it out. Dimensions to fit would be 200mm wide, 50m high. Link to comment Share on other sites More sharing options...
kdoot Posted December 22, 2014 Share Posted December 22, 2014 Dimensions to fit would be 200mm wide, 50m high. Oh, the Flagpole DAC. Nothing else fits that description. (check your units ) Seriously, depending on the sound you are looking for and the gear you're running it from, a Metrum Octave Mk1 might be an option - it would certainly fit the small space. I happen to have one now surplus to requirements if you're interested. Link to comment Share on other sites More sharing options...
analog brother Posted December 22, 2014 Share Posted December 22, 2014 (edited) very small space you are talking about. both units i suggested will not fit into 200mm x 50mm (w x h) Edited December 22, 2014 by analog brother Link to comment Share on other sites More sharing options...
Volunteer sir sanders zingmore Posted December 22, 2014 Volunteer Share Posted December 22, 2014 Sounds like a potentially costly exercise. Is there really no way you can keep the AN? Link to comment Share on other sites More sharing options...
greigw Posted December 22, 2014 Share Posted December 22, 2014 Never heard of the Trinity dac, will check it out. Dimensions to fit would be 200mm wide, 50m high. They will all be very two-dimensional compared to the AN. Link to comment Share on other sites More sharing options...
Audiobugged Posted December 23, 2014 Share Posted December 23, 2014 They will all be very two-dimensional compared to the AN.Tri stacked trinity dacs are very 3-D 1 Link to comment Share on other sites More sharing options...
greigw Posted December 23, 2014 Share Posted December 23, 2014 Never heard of the Trinity dac, will check it out. Dimensions to fit would be 200mm wide, 50m high. They will all be very two-dimensional compared to the AN. Tri stacked trinity dacs are very 3-D And with significantly more depth! Link to comment Share on other sites More sharing options...
rocky500 Posted December 23, 2014 Share Posted December 23, 2014 (edited) Emotiva Stealth DC-1 Dac is close to that size. 214mm x 50mm. Just checked the faceplate and it is 217mm as it sticks out a little futher. https://emotiva.com/products/electronics/stealth-dc-1 I think this is a great Dac but they now use Bongo for freight which is quite expensive. Edited December 23, 2014 by rocky500 Link to comment Share on other sites More sharing options...
AccuTidal Posted December 23, 2014 Share Posted December 23, 2014 (edited) What's about this DAC? Edited December 23, 2014 by Chanh 2 Link to comment Share on other sites More sharing options...
Guest BobbyD Posted December 23, 2014 Share Posted December 23, 2014 Get a bigger rack and go AN Dac 5 Sig.... problem solved Link to comment Share on other sites More sharing options...
Hifiplus Posted December 23, 2014 Author Share Posted December 23, 2014 Yep, I think spend the $ on a new rack may well be in order. No idea what is in that pic Chanh - monster dac?! Link to comment Share on other sites More sharing options...
AccuTidal Posted December 23, 2014 Share Posted December 23, 2014 This is my diy DAC, consists of 22 x 1794 DAC chips in parallel. The theory is parallel dac could reduce jitters? I posted a thread here http://www.stereo.net.au/forums/index.php?/topic/68388-could-this-be-the-first-tallest-diy-dac/#entry1152543 Link to comment Share on other sites More sharing options...
Black Orange Posted December 23, 2014 Share Posted December 23, 2014 Chord Hugo. Tiny and will beat most dacs. Link to comment Share on other sites More sharing options...
Audiobugged Posted December 23, 2014 Share Posted December 23, 2014 This is my diy DAC, consists of 22 x 1794 DAC chips in parallel. The theory is parallel dac could reduce jitters? I posted a thread here http://www.stereo.net.au/forums/index.php?/topic/68388-could-this-be-the-first-tallest-diy-dac/#entry1152543 I wonder why you stopped at 22 and not at something like 88? Is there a special reason for this? Personally, if I went down the diy route, I would go all-out too... Link to comment Share on other sites More sharing options...
legselevens Posted December 29, 2014 Share Posted December 29, 2014 Who sells the trinity dac? Any more info on them? Link to comment Share on other sites More sharing options...
analog brother Posted December 29, 2014 Share Posted December 29, 2014 trinity dac is distributed by zensati australia. retail is $60k http://www.trinity-ed.de/typo/index.php?id=12&L=1 Link to comment Share on other sites More sharing options...
analog brother Posted December 29, 2014 Share Posted December 29, 2014 there is now another contender though..... 'more' affordable too. http://www.berkeleyaudiodesign.com/reference/ 1 Link to comment Share on other sites More sharing options...
PKay Posted December 29, 2014 Share Posted December 29, 2014 there is now another contender though..... 'more' affordable too. http://www.berkeleyaudiodesign.com/reference/ What is the Aussie retail? Looks like a really good dac for 16 bit. Link to comment Share on other sites More sharing options...
