Absorb_sound Posted December 8, 2014 Share Posted December 8, 2014 Item: Pair of Elektra Audio InfraBass Bipolar SubwoofersLocation: MelbournePrice: Cost $6600 for the two, sell $2000 includes $40 donation to SNAs Item Condition: Cosmetic - 7/10, operational - 10/10. Reason for selling: Using full range speaker, no longer needed.Payment Method: Pickup - Cash, Paypal, Bank Deposit .Extra Info: Each cabinet has 2 upgraded 10" Focal Kevlar drivers. Internally Rewired with Jenna Labs wire. Large Bybee Quantum Purifiers on all positive and all negative speaker inputs and small Bybee purifiers on RCA amplifier inputs. Special Edition also has upgraded 500W internal amps. Dimensions & Weight: 535 x 335 x 410h with spikes. 35KG each Each box/cabinet has 2 Focal 10 inch drivers in a Bipolar configeration , which means they are at oppossite ends of the enclossure . The big advantage is active vibration cancellation, improving the dynamic range, and reducing the vibrational load on the box. The 500watt amps are class A B , not digital . Having 2 subwoofers with 4 total drivers means you can run the amps much more effortlessly with better sound quality at lower volumes than if you had just one . It is also better with eliminating room modes if you position them asymmetricaly. You also get smoother bass . If your a serious buyer, are fairly local and don't mind lugging around a bit of weight , you can have an audition in your own system . Link to comment Share on other sites More sharing options...
cazzesman Posted December 9, 2014 Share Posted December 9, 2014 Are these designed and built by Arthur Rappos? Regards Cazzesman 1 Link to comment Share on other sites More sharing options...
Absorb_sound Posted December 9, 2014 Author Share Posted December 9, 2014 (edited) Yes . And Mod Wright in America did the mods to the amps . Edited December 9, 2014 by Absorb_sound Link to comment Share on other sites More sharing options...
vincentchua Posted December 11, 2014 Share Posted December 11, 2014 Hi there are you willing to split these up or are you looking to sell as a pair? Cheers Link to comment Share on other sites More sharing options...
Absorb_sound Posted December 11, 2014 Author Share Posted December 11, 2014 As a pair . They work much better this way . Just to tempt you I could do the two for $1750 . Link to comment Share on other sites More sharing options...
vincentchua Posted December 18, 2014 Share Posted December 18, 2014 G'day. I have a 300B amplifier with a subwoofer line out. Is it as simple as just splitting the single line out into two RCA outputs for each sub? Do you have a splitter subwoofer cable that you can throw in? Link to comment Share on other sites More sharing options...
Absorb_sound Posted December 18, 2014 Author Share Posted December 18, 2014 When I was using them , I had a preamp with 2 outputs . One output would go to a power amp and this would go to my main electrostatic speakers that were bass shy , so they tented to roll off naturally in the upper midbass (?) area . The other output from the preamp went directly into the 2 subwoofers and I used the variable upper frequency cut off , to blend them in to the main speakers . So does your amp have a single output that is the two channels blended together . If so that would be mono , ... right ? If so , ideally it would be better to have 2 outputs for stereo sound . No I don't have a subwoofer splitter cable . Link to comment Share on other sites More sharing options...
betty boop Posted January 12, 2015 Share Posted January 12, 2015 This item has been withdrawn from sale or relisted. Link to comment Share on other sites More sharing options...
