mwhouston Posted October 23, 2014 Share Posted October 23, 2014 (edited) Item: MC Phono preamp built by retro-thermionicLocation: Southern Vic.Price: $90Item Condition: New, constructed to sellReason for selling: I have three similar stagesPayment Method: Pickup - Cash, Paypal, Postage about $10 to $20 depending on sate.Extra Info: This compact, battery powered MC stage has been constructed on vera-board using WBT silver solder and silver plated, fine copper wire; 2SK170, BL jFets (one per channel only) with Russian PIO output cap. Holds 8 X AAA 1.5V batteries (internally) for long life use. 100ohms\1nF input load. Ferrite beads on input wiring. Dead quiet with good gain to drive EQ\MM stage. Carries the "retro-thermionic" brass nameplate. Small yellow LED indicates "on". Cast Al enclosure with internal bitumanised heavy Al foil dampening\screening. Heavy gold plated RCAs. Take a look at the Blog entry.Pictures: Edited October 23, 2014 by mwhouston 2 Link to comment Share on other sites More sharing options...
rx7rotary Posted October 23, 2014 Share Posted October 23, 2014 Fantastic! I love it... 1 Link to comment Share on other sites More sharing options...
pulinap Posted October 23, 2014 Share Posted October 23, 2014 It is not clear to me from the description whether this is a MC headamp or a phonostage...... 1 Link to comment Share on other sites More sharing options...
thoglette Posted October 23, 2014 Share Posted October 23, 2014 It is not clear to me from the description whether this is a MC headamp or a phonostage...... Head amp - pre-pre if you like What I want to know is: how did you get that finish? Is it paint or powder coating? 2 Link to comment Share on other sites More sharing options...
mwhouston Posted October 23, 2014 Author Share Posted October 23, 2014 It is not clear to me from the description whether this is a MC headamp or a phonostage...... If I sadi it is a pre-pre MC stage would that help. So it take about 0.3mV and raises it to about 5mV. Link to comment Share on other sites More sharing options...
mwhouston Posted October 23, 2014 Author Share Posted October 23, 2014 Head amp - pre-pre if you like What I want to know is: how did you get that finish? Is it paint or powder coating? The finished is Epoxy Enamel spray with an acid etch primer first. 1 Link to comment Share on other sites More sharing options...
thoglette Posted October 23, 2014 Share Posted October 23, 2014 The finished is Epoxy Enamel spray with an acid etch primer first. Thanks! Link to comment Share on other sites More sharing options...
elcamry Posted October 23, 2014 Share Posted October 23, 2014 Nice job , GLWTS Link to comment Share on other sites More sharing options...
mwhouston Posted October 23, 2014 Author Share Posted October 23, 2014 Nice job , GLWTS GLWTS? Link to comment Share on other sites More sharing options...
Guest Hensa Posted October 23, 2014 Share Posted October 23, 2014 GLWTS?Good Luck With The SaleSent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
mwhouston Posted October 23, 2014 Author Share Posted October 23, 2014 Good Luck With The Sale Sent from my iPhone using Tapatalk At $90 it's a steal. Link to comment Share on other sites More sharing options...
Guest Hensa Posted October 24, 2014 Share Posted October 24, 2014 I would like to 'steal' it from you - PM sent... Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
