Further turntable help for a newbie
#1
Posted 29 August 2012 - 10:47 PM
I am looking to buy my first turntable just for occasional listening to records at home (I only own a few records at the moment). I want to spend under $100 for the turntables as it's my first setup and I don't want to get carried away before I even have a decent amount of records to listen to. I am pretty picky about how it will look (I definitely want something black) and am after something vintage just for the look and feel that comes with that. I am pretty keen on Technics as a brand as well.
After just missing out on a few I was after, here is all I can currently find which I might be interested in:
http://www.ebay.com/...#ht_1051wt_1163
There was going to be a list there but finding some black technics that can ship to Australia is proving annoyingly difficult. From what I can gather on google this is a decent turntable but the $100 is a bit steep for it?
Any thoughts on this one would be well appreciated. If I don't end up buying it I will throw in any other options I come across in here because I don't really have much idea.
#2
Posted 29 August 2012 - 11:01 PM
PureAudio, SOTA Turntables, Esoteric, Verity Audio, Shunyata, Zu Audio, Transfiguration, Morch, dCS, Solid Tech, Moon, Furutech,Grave Science & more!
#3
Posted 29 August 2012 - 11:07 PM
#4
Posted 29 August 2012 - 11:08 PM
I think you would be better off getting something local, have you tried posting a wanted to buy here in the classifieds?
Someone here may have something better, local to you.
Edit: Oops, beaten by minutes
I think I noticed a similar Technics in cash converters at Moorooka today for $39 or $49.
You in Brisbane?
Edited by datafone, 29 August 2012 - 11:12 PM.
Just Vinyl
SR-838/2M Bronze - Tweaked BHL Phono - Custom EL34 - ML-1's - Aurealis cables/IC's
#5
Posted 29 August 2012 - 11:16 PM
#6
Posted 29 August 2012 - 11:17 PM
#7
Posted 29 August 2012 - 11:18 PM
I can, make sure it works and see what cart it has, and let you know.
The classifieds is a good idea, might get something better...
Edited by datafone, 29 August 2012 - 11:19 PM.
Just Vinyl
#8
Posted 29 August 2012 - 11:21 PM
#9
Posted 29 August 2012 - 11:30 PM
I think a mate of mine has a couple of plastic body Technics under his house doing nothing, I'll look into that on Saturday for you also, could be freebies, but these are silver body and were used for DJ work a long time ago, so may not be the best.
Edited by datafone, 29 August 2012 - 11:55 PM.
Just Vinyl
#10
Posted 30 August 2012 - 05:59 AM
http://www.stereo.ne...ge__hl__ipswich
Edited by Telecine, 30 August 2012 - 06:02 AM.
#11
Posted 30 August 2012 - 01:37 PM
Contact member Pegasus, I think he can help you out with something. I believe that he still has a turntable to give away:
It's still here in Ipswich if anyone wants it.
Just needs a new TKS headshell mount. I presume they are still available. Should only cost a few dollars.
The little "L" shaped clip broke off. You could probably make one from devcon or the like.
Would recommend a new belt as well.
Has Gold plated RCA plugs and decent cabling.
CD: Shanling CD-T80 DAC: Leema Elements Turntable: Linn Sondek LP12, Hercules/Moses, Grace 707, Audio Technica ATI 150MLX, Trichord Dino & PSU Tuner: NAD C 420
Pre Amp: Parasound Halo P3 Power Amp: Parasound A21 Speakers: SGR Trapezoid Cable: Goertz MI-3 Divinity Interconnects: Chord, Xindak.
#12
Posted 30 August 2012 - 02:42 PM
OK, I looked at this one, and It's $49, and is a DB20 auto, is a "P" mount cart that has no stylus, and there is no strobe so impossible to know if It's speed stable.I think I noticed a similar Technics in cash converters at Moorooka today for $39 or $49.
You in Brisbane?
Give it a miss.
Edited by datafone, 30 August 2012 - 02:43 PM.
Just Vinyl
#13
Posted 30 August 2012 - 09:19 PM
A friend of mine gave me a Pioneer PL-X11Z today which I don't mind the look of, but it apparently came with a Pioneer amp which powered it so I would need to buy a power adapter to run it. Plus it needs a needle. I am going to just scrap it and keep looking I think.
A Toshiba SR-Q630 turned up in the classifieds which looks nice enough, but I couldn't find much info on it online. Does anyone know anything about this TT? I'm a bit bummed it isn't Technics to go with my amp, but as the guy pointed out it might be asking a bit much only looking for something in a specific brand and color.
#14
Posted 30 August 2012 - 09:34 PM
Specs & manual here http://www.vinylengi...a/sr-q630.shtml
If It's in good working order, grab it if you can.
Just Vinyl
#15
Posted 30 August 2012 - 09:40 PM
#16
Posted 30 August 2012 - 09:43 PM
Just Vinyl
