Need help finding this weird kind of fuse
#1
Posted 05 August 2012 - 06:23 PM
#2
Posted 05 August 2012 - 06:41 PM
I need to replace four n38 ic protector fuses, they look like a TO92 transistor just with the middle pin missing. To my knowledge they are a 50v 1.5 amp normal blow fuse. Anyone know where i can get them or another kind of fuse to do the job? I was thinking maybe Pico fuses would work
Found a place here - http://www.donberg.i.../fuses/n38.html
Edited by Full Range, 05 August 2012 - 06:43 PM.
Amp Earle Weston Tweaker MK 4: DAC Earle Weston 6SN7 Tube Prototype
Speakers Audio Nirvana Full Range Speakers: CD Marantz CD63 SE :
Turntables Garrard 401, Revox 795 & Sonab Tape Nakamichi Home Theatre Is handled by JVC components
Also Art Collector, Coffee Lover, Inventor: QLD Audiophile Club Member - Paul P
#3
Posted 05 August 2012 - 07:01 PM
#4
Posted 05 August 2012 - 07:38 PM
http://www.wescomponents.com/
Go-Company also has them - They are in Qld
http://www.gocompany.com.au/
http://www.gocompany....au/go2-7-8.pdf (second page half way down)
#5
Posted 05 August 2012 - 08:00 PM
#6
Posted 05 August 2012 - 08:21 PM
#7
Posted 05 August 2012 - 08:32 PM
#8
Posted 05 August 2012 - 09:23 PM
#9
Posted 05 August 2012 - 09:34 PM
Edited by skippy124, 05 August 2012 - 09:54 PM.
#10
Posted 05 August 2012 - 09:41 PM
#11
Posted 06 August 2012 - 06:29 AM
I'm not sure what you mean? I bought them from Hong Kong ages ago for something i was doing and have heaps left over. There like these http://www.ebay.com....=item5ae86a3df5
There the ones VintageA, quick and fast blow they are the same thing, the reason I used the quick blows 1st is to protect the circuit, because with the same rated fuse if it was to go again it means there is a fault condition. If you encounter it doesnt blow and everything works then all is well!
Somewhere on that fues should have a letter "F" for fast or "S" for slow!
Edited by pchan, 06 August 2012 - 06:35 AM.
#12
Posted 06 August 2012 - 08:08 AM
Edited by vintageaudio50, 06 August 2012 - 08:09 AM.
#13
Posted 06 August 2012 - 03:28 PM
#14
Posted 14 August 2012 - 10:15 PM
