Upgraded DAC design from Silicon Chip
#1
Posted 02 July 2012 - 03:40 PM
Has there been any discussion about this upgraded dac kit from earlier in the year? Has anyone heard this DAC in action? I had a look for a thread about this but i couldn't find anything.
http://siliconchip.c...66/article.html
I am in the market for a dac for my HTPC and I am considering a DIY kit to get better value for my price range (under $500). I'm not very good at DIY audio but my dad is quite experienced and together we could put together most projects. I'm very interested to know what the quality of one these kits is like.
Are there any other kits that are generally rated very good for under the $500 mark? I have heard there are some good ones on ebay etc that come partially assembled.
Perhaps someone could point me in the right direction here?
#2
Posted 02 July 2012 - 04:17 PM
I have no experience with the Silicon chip DAC kit.. But the good thign about SC kits is that they are complete kits, meaning case, transformer, hardware,, etc..
Now they even sell just the printed circuit boards if you want to source your own bits and pieces..
Other options for DAC kits are below: (some of these are not complete kits)
http://hifimediy.com...ategory&path=62
http://www.twistedpe...al/buffalo.aspx
http://www.junilabs.com/en/index.html
http://www.audionote...com/dac2_1.html
I know there are more,, and hopefully someone on here might ad some too.. But watch out for some of those "E-bay" DACS,, there has been a lot written about them over at DIYaudio
Hope this helps!
Ta
CM
Main rig: Squeezebox Touch (with TT3.0) -> Audio Gd DI-DSP -> HiFi MeDIY Direct-Out DAC -> Pass Aleph Single-ended Class A Preamp (DIY) -> SC Class A mono-blocks -> Usher S520's
Alternate: DCX2496 (Fully Modified) -> SC ULD-MK1, modified into mono-blocks
Headphone rig: Millet Mini-Max -> AKG-701's
#3
Posted 02 July 2012 - 05:32 PM
#4
Posted 03 July 2012 - 09:31 AM
thanks for the reply Cyber_murphy. I'm also considering an audio-GD 3.1 at the moment. I wonder what would be better bang for buck?
Not sure,, I've had no experience with audio-GD, but many on here have..
I have laways preferred DIY
Ta
CM
#5
Posted 03 July 2012 - 10:24 AM
audio-gd stuff is well made and are generally best at the price points they compete in, imho. i have had the nfb-2 and that was a great dac which you would have to spend
closer to a $1000 to better it, again in my experience and opinion and also in my system/room/ etc.
it would be hard to say what is better bang for buck? as with the kit you have no idea how it sounds till you build it, and there are lots of people on here who own audio-gd stuff that could
either let you listen to theirs or give you an idea of its sound.
i am not against diy as it can be a good way to get something nicer for the price and the fun of building it is also worth the experience.
i dont think you could go wrong either way as most silicon chip kits have been very good and i suspect this will be as well.
pp
oppo 105, audio gd master 7 dac, jeff rowland capri preamp, rotel rb1090 power amp,
vaf i93mk2 speakers, audioquest argent cables,
logitech squeezebox touch. ............................ps audio dl link 3 dac for sale !!!!
#6
Posted 04 July 2012 - 12:44 PM
#7
Posted 04 August 2012 - 04:13 PM
Hi,Hi guys,
I've read ths article (I bougth the magzs). I like they use DIR 9001 (according to Audio-gd it has natural sound compared others), discrete I/V & output preamp (discrete/ individual components has better soundstage, low-highs more open, more lows, sound comes closer) but ths DAC is not for my taste. My objections : they use IC regulators in their PSU (not discrete) and a simple passive R & C on its clock (see the X'Tal on DIR9001 circuit means less accurate, usually around 220 pps. Active clock can reach 3-10 theoritically). Active clock gives better soundstage, sound instruments comeindividually. But of course tht DAC is not meant for a serious one and more fit for affordabilty
Edited by joeyahoo1, 04 August 2012 - 04:14 PM.
Also tagged with one or more of these keywords: silicon chip, dac, DIY, crystal dac
Output Devices & Room →
Headphones & Headphone Amps →
Amp/DAC advice for AKG 601sStarted by arkticfox, 11 May 2013 |
General Discussions →
DIY Audio & Electronics →
Mission Argonaut Reincarnation ProjectStarted by Star Woofer, 09 May 2013 |
Source Discussions →
CD (Including DAC's) & Other Digital Sources →
Denon CD player skipping tracksStarted by firefly0071, 05 May 2013 |
Attention DIY subwoofer BuildersStarted by Jone5y, 25 Apr 2013 |
Have I done this right??Started by Jone5y, 10 Apr 2013 |
