mitsubishi or jvc projector
#1
Posted 04 June 2012 - 09:31 AM
#2
Posted 04 June 2012 - 09:38 AM
If you are looking at only 2D get the JVC. The contrast and black levels on JVC are amazing.
For 3D, DLP is still king. But its a pale shadow of the JVC for blacks and contrast.
#3
Posted 04 June 2012 - 11:41 AM
Both pjs out of box need calibration. I understand some issues with the colour management system on the mitsu. And jvc x3 doesnt come with a full colour management to calibrate perfectly.
If spending so much I'd try get the newer model x70. As comes with full ifs calibration on board. And understand its pretty much like the x90 which have seen and is awesome.
Not seen the mitsu 9000 but understand it is the 3D king. The jvcs on other hand are pretty woefull on 3D !
Edited by :) al, 04 June 2012 - 11:43 AM.
#4
Posted 04 June 2012 - 11:51 AM
That uses choice components. The memory chips used are higher spec and the lens and DILA panels are bin sorted higher grade. The X7 is just the X3 with a different firmware.
The X3 has a restricted color gamut which IMHO works quite well even without CMS. The X7/9 works very well in Xenon/Film mode.
#5
Posted 04 June 2012 - 12:27 PM
I wouldnt recommend a grey import on a pj such as this with no warranty here and the given the issues the jvcs have had on failures on their pjs of late not a good idea unless like playing russian roulette !
#6
Posted 04 June 2012 - 02:07 PM
#7
Posted 04 June 2012 - 07:30 PM
#9
Posted 05 June 2012 - 08:40 AM
120inch screensize and what do you mean by ambient light? have a dedicated room for the projector so can make the room quite dark during the day.screen size and ambient light?
#10
Posted 05 June 2012 - 10:53 AM
The SMPTE standard is 16 foot lamberts (20+ is better).
The JVC wont do that on a screen that size, its not bright enough. I'd be looking an an Epson or the like
#11
Posted 05 June 2012 - 11:22 AM
In my old room with no light control, I had in various stages, a Panasonic AE700, a Mitsubishi HC5000, a JVC HD1, a Panasonic AE3000, an old Optoma DC2 DLP, a JVC HD250, a JVC RS40 then a JVC RS60 and each time, it was clear when there was an improvement in black levels or contrast. Even during the day when the stray light was more obvious.
#12
Posted 05 June 2012 - 11:35 AM
Anyway, foot lamberts is the reference - the cedia manual says:
"The image with a 100IRE raster should be measured at the primary viewing position and deliver a minimum of 28 foot lamberts +/- 3 foot lamberts with conventional lamps, which should insure a minimum of 14 foot lamberts throughout the duration of the useful life of the lamp. Projectors with light sources that do not lose light output over time should measure at least 14 foot lamberts using the same method."
#13
Posted 05 June 2012 - 08:14 PM
#14
Posted 05 June 2012 - 08:40 PM
For 3D, they still exhibit ghosting tho it's slightly better than JVC. But nothing like the flicker free DLP 3D.
As a compromise all in one system, a friend of mine has had good results with the Optoma HD8300.
#15
Posted 06 June 2012 - 07:30 AM
#16
Posted 14 July 2012 - 09:33 AM
#17
Posted 14 July 2012 - 09:40 AM
2D images on the JVC look amazing.. great impact and the perception of depth is incredible.
#18
Posted 14 July 2012 - 09:55 AM
#19
Posted 18 July 2012 - 08:01 PM
The exception is pjs with a dynamic iris. You will still be able to see black level pumping.
Personally I would get the JVC because it has te potential to be better.
As for which model, I think the last few generations of JVC projectors have shown minor improvements since they were so good anyway. What has happened is the base models become as good as the previus top model. If you're not a total perfectionist, I would just get the cheapest one, or buy last year's used.
I have an HD750. Still love it.
Edited by sfdoddsy, 18 July 2012 - 08:01 PM.
Apogee Duetta Signatures, Rythmik x 2, Duevel Planets, Ohm Micros, Anthem, Velodyne, JVC RS20, Firehawk.
My Latest Dipoles
#20
Posted 18 July 2012 - 08:37 PM
Your maximum (or minimum) black level is set by your room. If there is any light on the screen you will nt be abe to take full advantage of the JVC better blacks. So if you have any ambient light, other features become more important and a pj with lesser blacks may work out better.
While it is true that the ambient light can affect black levels, I've found that for most given rooms, it is still very obvious moving from say an AE3000 Panasonic LCD to even an old JVC RS10.
#21
Posted 17 August 2012 - 08:24 AM
#22
Posted 20 August 2012 - 11:43 AM
#23
Posted 20 August 2012 - 07:42 PM
#24
Posted 20 August 2012 - 08:02 PM
#25
Posted 20 August 2012 - 09:18 PM
ok al is the x90 much better than the x70
couldnt tell you, I only saw the x90 back to back with the x30 the jvc guys had setup. I understand the x90 is upspec in components vs the x70. though use the same basis quite a hike up from the x90...probably want to check out for yourself to see if the price up is worth it. otherwise if the x70 gets a big slab of the x90 would be a bit of a bargain
#26
Posted 20 August 2012 - 11:23 PM
#27
Posted 25 August 2012 - 09:21 AM
yeah al i agree with not buying one from overseas. way to risky with no warranty if it doesnt work when it gets here. also it could get damaged in transit...have seen the x90 when was at the melb av show. definitely a step up from the x30. with all the lamp and other issues with PJs with regard your previous comment yardley I dont think grey importing one from overseas a good idea.
#28
Posted 21 September 2012 - 12:06 PM
take a look around http://audioaddictio...iew/66/194.html
#29
Posted 21 September 2012 - 12:59 PM
Mitsubishi hc9000d is awesome, fantastic images wiith my bluray,
I think that's based off the old Sony SXRD panels. Great for 2D motion but not as good blacks and contrast as the JVC DILA. But still noticeable ghosting.
#30
Posted 21 September 2012 - 02:06 PM
i dont think the 9000 is available anymore and the new model the 7800 is DLPMitsubishi hc9000d is awesome, fantastic images wiith my bluray,
#31
Posted 17 October 2012 - 08:59 PM
I'll have to disagree. The JVC strength is the absolute level of black compared to other projectors with no iris pumping. If you have any ambent light that absolute level goes up and the advantage diminishes.
My sparky was doing work on my place today and is considering a projector. Whilst I normally recommend JVC, i said to him what I would say the OP. Turn off all your lights and check whether your screen is truly black, ie invisible.
If not, that somewhat grey patch will be the best you can do for black levels and other things become more important such as brightness, processing, colour accuracy etc.
But unless you can start with an absolutely black room you will never experience the potential contrast ratio of the JVC projectors.
As for buying from OS, i've bought my last 4 or 5 projectors that way. It's not worth it for a cheap model, but certainly used to be for a JVC given the ripoff prices here. I buy B Stock from AVS. It's usually last years model for half this years.
There's no Aussie warranty, but still a US one if something catastrophic happens. It never has.
My current JVC has developed a a minor but annoying band, but would have out of warranty here as well.
Edited by sfdoddsy, 17 October 2012 - 09:00 PM.
My Latest Dipoles
#32
Posted 17 October 2012 - 10:41 PM
I use blackout curtains but do watch a fair bit of movies during the day when some light comes through. The walls are a mixture of light colored and darker toned paint so there is some reflection to the screen. That's the bare minimum for projectors though. And the improvements in the black and contrast are still noticeable.
If you can't even have black out curtains and there's light streaming through, you shouldn't even be considering projectors.
