Price: $3000 for the pair ($1600 each) these had a RRP of $4000 each, the amps are SGR plate amps and are worth over $1k each.
Item Condition: Excellent, and in perfect working order
Payment Method: Pickup - Cash only. Due to their size and weight i will not deliver these. You will need a station wagon to transport them or a medium size hatch, but then only one at a time i would think.
Will only split them if i have a purchaser for both
These are designed to sit in corners and as can be seen by the pictures, take up very little room real estate room.
They can be placed anywhere of course and be laid flat on the floor angled upwards. Very versatile indeed.
height: 1.1mtr
depth from front face to back corner: 590mm
front face width: 480mm
weight i estimate at around 60kg+
Amp SGR class A/B 300watt
x-over slope od either 12 or 24dB. Adjustable from 25Hz to 125Hz
fixed 80Hz HP output
phase dial from 0-180
phase invert switch
balanced or single ended inputs
rumble filter
Edited by JohnA, 07 June 2012 - 08:27 AM.
This topic is locked
