Golden Ear hi-rez player for iPad/iPhone
1 reply to this topic
#1 mjs
mjs
  • 106 posts
Posted 30 April 2012 - 09:07 PM
Been mucking around with some hi-rez players that replace or sit beside iTunes, such as Pure Music and Audirvana on the 2ch system via Mac Mini to an external DAC to amps/speakers etc.
Today I downloaded "Golden Ear" which is a hi-Rez Player app for the iPad and iPhone. I have played 44/16 tracks via iTunes before (ok, using "Music" since iOS5) but this allows higher rez stuff and have just been listening to 96k/24bit files on the iPad. Now, storage limitations aside, it's great to be able to do that. Certainly what I compared which was the hi-Rez files vs the native iTunes AAC files, was chalk and cheese. Not sure how far in terms of rez, the new native "Music" app can go. Clearly the iPad "DAC" and analog output stage is never going to be state of the art, but it's not that bad.
I do a bit of air travel with work and enjoy high quality music on board, but with a growing iTunes library that is at least 44/16, its impossible to sync at the native resolution as I run out of space even at 64gig. Golden Ear enables most hi-Rez file types to be synced via the Apps function on iTunes. It should be therefore possible to sync three or four albums at hi-rez and enjoy them that way.
Anyone else have any experience with this app?
Edited by mjs, 30 April 2012 - 09:08 PM.
#2 mjs
mjs
  • 106 posts
Posted 30 April 2012 - 11:55 PM
Also listening via Capriccio. Files can be downloaded to both Golden Ear and Capriccio via FTP protocols (rather than syncing thru iTunes) using FileZilla in my case - can't believe how easy it is.
Golden Ear seems to be better to me at this stage, more detail, better "air" and separation.
So many toys and so little time!!
Edited by mjs, 01 May 2012 - 10:07 PM.
