SOLD: FS: Cambridge Audio DacMagic (White) SOLD
DAC DacMagic
  • This topic is locked This topic is locked
8 replies to this topic
#1 fordgtlover
fordgtlover
  • 404 posts
  • State: ACT
Posted 16 April 2012 - 09:31 PM
Item: Cambridge Audio DacMagic DAC (white)
Price: SOLD
Item Condition: 9.5/10 (no marks apparent)
Reason for selling: Too many DACs
Payment Method: Pickup - Cash, Paypal, Bank Transfer
Extra Info: The power pack has been replaced with a better one from Jaycar.
Here's some stock photos that are much better than my photography anyways :)
Attached File  dac_magic_front.jpg   33.26KB   17 downloadsAttached File  DAC_Magic_rear.jpg   815.3KB   19 downloads
DacMagic features
-Adaptive Time Filtering (ATF™) asynchronous upsampling technology converts 16-24 bit audio (at any standard sampling frequency between 32-96kHz) to 24 bit/192kHz
-32 bit Texas Instruments Digital Signal Processor (DSP)
-Dual Differential Virtual Earth balanced filter topology – low order two pole linear-phased Bessel filter takes advantage of high sampling rate achieved
-Twin WM8740 high quality DACs in dual differential mode for excellent stereo imaging
-Incoming sampling rate indicator 32/44.1/48/88.2/96kHz
-Choice of filters – linear phase, minimum phase and steep filter can all be selected to suit an individual’s listening preferences
-Phase select to invert or reinvert input, correcting possible recording problems
-Two inputs with both SPDIF & Toslink sockets allow wide range of digital sources to be connected
-USB input connects direct to PC without drivers to act as very high quality DAC/soundcard providing genuine hi-fi quality playback from desktop or media PC
-Singled ended phono and XLR balanced audio outputs
-Digital output (SPDIF and Toslink concurrently) passes through selected source for recording purposes
-Substantial aluminium front panel plus an entirely new ultra rigid, acoustically dampened chassis
-Can be used horizontally (using four rubber feet) or vertically (rubber foot)
-Available in silver
DacMagic Specifications
D/A Converters: Dual Wolfson WM8740 24bit DACs
Digital filter: Texas Instruments TMS 320VC5501 DSP upsampling to 24bit 192kHz
Analogue filter: 2-Pole Dual Differential Bessel Double Virtual Earth Balanced
Frequency Response: 20Hz to 20kHz (±0.1dB) - steep filter disabled
THD @ 1Khz 0dBFs: <0.001% 24bit
THD @ 1kHz -10dBFs: <0.001%
THD @ 20kHz 0dBFs: <0.002%
Signal to Noise Ratio: -112dB
Total correlated jitter: <130pS
Crosstalk @ 1kHz: < -100dB
Crosstalk @ 20kHz: < -90dB
Output Impedance: <50ohms
Output level (unbalanced): 2.1V rms
Output level (balanced): 4.2V rms (2.1V per phase)
Digital input word widths supported: 16-24bit (16 bit for USB)
Digital input sampling frequencies supported: 32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz (44.1kHz, 48kHz for USB)
Audio output up-sampling: Fixed 24bit 192kHz
Dimensions (H x W x D): 52 x 215 x 191mm (2.0 x 8.6 x 7.6”)
Weight: 1.2kg/2.6lbs
DacMagic Support
User's Manual
DacMagic User's Manual - English
Edited by fordgtlover, 17 April 2012 - 10:41 PM.
The first principle is that you must not fool yourself and you are the easiest person to fool. --- Richard P. Feynman
It is easier to fool people than to convince people that they have been fooled. --- Internet (attributed to Mark Twain, but remains unverified)
#2 Suopermanni
Suopermanni
  • 17 posts
Posted 17 April 2012 - 01:12 PM
I'm very interested in this! Just one question: What do you mean by ONO?
#3 cheekyboy
cheekyboy
  • 6,397 posts
Posted 17 April 2012 - 02:47 PM
Usually means 'or near offer' doesn't it?.................but I'll bite!! :P
Keith
Vinyl Eye Records - Online New Vinyl Records
Graham Slee Projects- Australian Equipment Loaner Program
#4 mikey d
mikey d
  • 1,137 posts
Posted 17 April 2012 - 03:43 PM
Keith
Just what you need Keith :cool:
#5 cheekyboy
cheekyboy
  • 6,397 posts
Posted 17 April 2012 - 04:14 PM
What's that Mikey? I need a DACmagic like I need a hole in the head! :D I thought the abbreviations ONO or OBO were pretty common out there..........that's why I said I'll bite. ;)
Keith
#6 fordgtlover
fordgtlover
  • 404 posts
  • State: ACT
Posted 17 April 2012 - 07:23 PM
Yup - ono = or near offer
<life of brian>
HARRY THE HAGGLER: Well, we're-- we're supposed to haggle.
</life of brian>
Edited by fordgtlover, 17 April 2012 - 07:24 PM.
#7 Suopermanni
Suopermanni
  • 17 posts
Posted 17 April 2012 - 08:52 PM
What kind of postage options can you give me? Would it be possible to get it by Friday?
#8 fordgtlover
fordgtlover
  • 404 posts
  • State: ACT
Posted 17 April 2012 - 09:58 PM
PM Sent
#9 proftournesol
proftournesol
    Moderator
  • Moderators
  • 5,693 posts
Posted 18 April 2012 - 09:13 AM
Congratulations on the sale of your item. If you feel you have benefited from using this system for the sale of an item through our classifieds system then please consider making a donation.
Donation Payment Options
You can make a donation via Paypal (using Credit Card or Paypal Balance), or Direct Deposit.
Click below to make a donation:
Thank you, your support is appreciated and every dollar makes a difference.
regards Michael
Analog: Pink Triangle (totally Funked) Kuzma Stogi Reference, Soundsmith Straingauge Digital: modified CEC TL-51X transport , MacMini, Weiss Minerva DAC Tuner: Tandberg A3011 Preamp: Octave HP500se Speakers: ADAM Tensor Deltas | Vibration management: HRS | Cables: Argento Serenity, WSS Kabel, Nordost, Transparent, Cardas |
Second System Source: Cambridge Audio DV99 | Apple TV (Gen 1)| DACMagic | Amplification: Sugden A25 Speakers: ADAM HM2
