HELP!
Tested everything. Different cables etc. Front analog does not have sound. Rears does. Same power amp. Switched cables around etc.
Any tech have Primare knowledge!?
HELP! Help! help!
HELP: Primare SP 31.7.
Started by holliswhy, Apr 16 2012 08:05 PM
3 replies to this topic
#1
Posted 16 April 2012 - 08:05 PM
Naim CD5i. Naim Supernait. Spendor SP2/3R2.
#2
Posted 16 April 2012 - 09:10 PM
if checked the obvious ie any cabling stuff up and tried other channels on the power amp. and nothing wrong wiht your speakers. then narrows down to something in the pre amp. only briefly played with a primare av pre some years ago, so anything I say is useless. but there are primare dealers around. suggest take it in. hook upto a system see if they can help, eliminate something your doing and your system. then it might be a trip in for repairs otherwise....
"Technology is a drug. We can't get enough of it."
#3
Posted 16 April 2012 - 09:42 PM
Thanks al
I rebooted and it started working again.... lols
#4
Posted 16 April 2012 - 09:48 PM
talk to the tech at Synergy Audio (the importer) - forgotten his name but specifically ask for the tech, pretty helpful and takes the time of day
ALW
edit - are the old ctrl-alt-del trick - well done in sorting!
ALW
Edited by alittlewino, 16 April 2012 - 09:49 PM.
