Speaker Advice (under $1000)
10 replies to this topic
#1 strawdog
strawdog
    Newbie
  • 5 posts
Posted 16 April 2012 - 02:57 PM
Hi all.
I am after some advice on some decent speakers.
Hoping to spend around or under $1000, preferably after floorstanding speakers.
Will be for a turntable and integrated amp setup.
Does anyone have any opinion, advice or cautions on any of the following?
Definitive Technology BP 2006TL Floorstanding Speakers $1000
Definitive Technology BP7006 $1349
Paradigm Studio 10s $899
BOSTON ACOUSTICS Lynnfield VR series speakers x2 $499
Paradigm 11seMk3 $499
Mordaunt Short Avant 914i Speaker SystemPrice: $ 899
jbl studio series-s310-11 floorstanders $ 985
Jamo E680 pair $500
Subsonic PM2 Loudspeakers (Polymorphic)
M&K LCR-55 speakers $800
Thanks for any advice...
#2 cableconnoisseur
cableconnoisseur
    ** Serial Tweaker **
  • 2,537 posts
Posted 16 April 2012 - 03:49 PM
Hello strawdog,
Speakers must always be auditioned by a prospective buyer and if possible with the electronics you intend using them with (or a close-enough equivalent).
Otherwise you will most likely receive biased advice from a group of well-meaning individuals (audiophiles) and end up getting more confused than you were at the beginning of your quest.
Having said all that and based purely on my preference for the English sound, my pick would be the Mordurant Short package...... :cool: .
I wouldn't bother auditioning the $500 pairs listed as you won't get anywhere near the performance of the more expensive speakers you've listed above.
Regards,
Russ.
#3 danq
danq
  • 115 posts
Posted 16 April 2012 - 04:23 PM
As Russ said, auditioning is key. I'd add the Quad 21L2's to your list, which you may be able to get at $1000.
Primary: Macbook air -> (Wi-Fi) -> Squeezebox Touch -> Hegel HD2 DAC -> Dayens Ampino -> Magnepan 1.6QR :)
Secondary (synchronised): Macbook air running squeezeslave -> XTZ A-800 Class D amp -> Quad 21L2
#4 strawdog
strawdog
    Newbie
  • 5 posts
Posted 16 April 2012 - 04:50 PM
Thanks Russ and danq.
The prob is, when i was trying to decide on an amp the advice i got was to choose my speakers first and then audition the amp with the speakers!! It seems like i need to have at least one piece of equipment to get this ball rolling - but what should come first?!
Thanks for both the above suggestions though! Will look into the Mordaunt Short and look for the Quad - but the list above was mostly compiled from what is actually available for purchase - new or second hand.
Thanks again guys, i know these broad advice questions are hard to answer as each set up / environment / room / music tastes etc will alter the outcome, so any info is appreciated!
#5 Juicester
Juicester
  • 1,776 posts
Posted 16 April 2012 - 05:06 PM
CHeck out the classifieds for speakers around the $1k mark. I think you'll do best with second hand..... for the money.
Sonus Faber Cremona Auditor M | Sonus Faber Cremona Centre | REL B2 | Plinius 9200 | Plinius CD101 | Oppo BDP-93 (RF) | Onkyo TX-NR818 | Primare A30.3 | Audio GD DAC19 | Audio-GD DI | SB Touch | Black Cat Veloce | QED Sig Audio S ICs & QED Genesis Speaker Cable
#6 Andyaussie013
Andyaussie013
    Advanced Member
  • 35 posts
Posted 02 May 2012 - 06:04 PM
I got an Outdoor speaker worth 1000$ in just 499$ .But have no much Idea about floorstanding speakers . You can visit the resource to find in your category.
#7 shaun.o
shaun.o
    Advanced Member
  • 50 posts
Posted 08 May 2012 - 07:21 PM
If you're after new speakers for $1000, I'd suggest you aim for some bookshelfs instead - or find something on sale - check the Eastwood Hifi specials page.
Or go 2nd hand - probably pick up some Krix Lyrix Gold or B&W 602's on eBay.
Rotel / Krix / Oppo / Pioneer
#8 danq
danq
  • 115 posts
Posted 10 May 2012 - 01:19 PM
Just saw that at Eastwood HiFi they have Martin Logan Motion 10 on sale. Has anybody heard them?
#9 Arg
Arg
    The Argentinian
  • 946 posts
Posted 10 May 2012 - 02:01 PM
Hi strawdog, tell us what music you listen to and what you want the speaker to do really well.
#10 Braddles 63
Braddles 63
    Large Member I>
  • 747 posts
Posted 12 May 2012 - 11:52 PM
There are some Proac studio 125's on eBay. Highly reccomend.
#11 ayou2
ayou2
    Gimme some stick
  • 699 posts
Posted 13 May 2012 - 10:55 AM
Def Tech and Paradign would be my advice. I sold Paradigm for 7 years, they are an incredibly consistent maker who never make a bad model. They are pretty neutral & robustly made & also always made to be easy to drive and stable impedance.
Def Tech also make some brilliant speakers, they are one of the most underrated brands out there IMO and similar traits to Paradigm.
On the avoid list, Boston Acoustics have a reputation for unstable ohmage which can kill amps, JBL nearly always have bright treble, which can sound good on short audition but not good long term. M&K will be a bit stubborn to drive ie might need a big amp.
As Cable Con has already said, get in for a listen and don't run round too many shops or ask for too many opinions as that's all you'll get ... opinions.
If this is your first venture into hifi then stik with buying from a dealer as 2nd hand can be a minefield till you get more familiar with technical terms like sensitivity, impedance, matching to a room, environment and matching to decibel and music requirements.
If they sound good to you, they are good.
Keep it simple
If you are so inclined, buy Aussie made, there is a list of manufacturers at the head of this branch of the forum. Krix are awesome and pretty widely available.
Edited by ayou2, 13 May 2012 - 11:06 AM.
