hi, just a quick question. At the moment i am feeding my minimax plus from my computer via Xonar essence stx digital coaxial would this be better than using the usb into the dac. Thanks for any input/explainations.
Minimax Dac Plus Question
Started by nothing1, Apr 16 2012 02:05 AM
2 replies to this topic
#1
Posted 16 April 2012 - 02:05 AM
#2
Posted 16 April 2012 - 06:25 AM
Dont have the Xonar card but looking at what its got its it has all the package as bring typical Brown Burr.
I downloaded the driver from EE for the plus and Foolbar and used a normal printer cable. Set Foolbar up to 32 bit and away it goes. This is feed through a Dell Latitude 4300. Really nice sound. All you need is a 2.0 usb printer cable, so why dont you give it a try and compare the 2! The USB on the plus is 24/192.
Regards
pchan
Regards
pchan
#3
Posted 16 April 2012 - 11:58 AM
Thanks pchan
