Edit; not interested in 5.1, I just want two nice pillar styled speakers.
Edited by Nathanas, 10 April 2012 - 10:46 PM.
Posted 10 April 2012 - 10:29 PM
Posted 10 April 2012 - 10:45 PM
Edited by datafone, 10 April 2012 - 10:53 PM.
Just Vinyl
SR-838/2M Bronze - Tweaked BHL Phono - Custom EL34 - ML-1's - Aurealis cables/IC's
Posted 10 April 2012 - 10:48 PM
Posted 10 April 2012 - 10:49 PM
Adelaide Sales Representative
www.audiofidelity.com.au
Brinkmann MSB Technology SGR Audio
BRINGING YOU CLOSEST TO THE ORIGINAL SOUND!
Posted 10 April 2012 - 10:56 PM
Edited by Nathanas, 10 April 2012 - 10:58 PM.
Posted 10 April 2012 - 10:57 PM
So, let me get this right, you still want surround for TV and the PS3?Ok thanks. So I will need a stereo amp, cd and tape unit plus another receiver for the digital stuff- ps3, HDTV etc?
Just Vinyl
Posted 10 April 2012 - 11:02 PM
Edited by Nathanas, 10 April 2012 - 11:02 PM.
Posted 10 April 2012 - 11:03 PM
Edited by datafone, 10 April 2012 - 11:05 PM.
Just Vinyl
Posted 10 April 2012 - 11:11 PM
Posted 10 April 2012 - 11:15 PM
Edited by datafone, 10 April 2012 - 11:17 PM.
Just Vinyl
Posted 10 April 2012 - 11:23 PM
Posted 10 April 2012 - 11:33 PM
Posted 11 April 2012 - 12:45 AM
Sounds good mate. I'm in no rush. Yes budget is around 5k possibly a little more. If I can find second hand stuff that would be ok with me, I suppose being able to test drive the units may be an issue there though. In regards to speakers, which do reccommend?
Edited by triode12, 11 April 2012 - 12:55 AM.
Posted 11 April 2012 - 08:23 AM
Posted 11 April 2012 - 08:50 AM
Analogue setup: 1986 Townshend Rock Mk2/AO rewired RB250/Soundsmith retipped VdH DDT-II special, Marshall Leech head amp, Copland CSA-14, Castle Howards.
PC System: i7 win8, T Amp, Monitor Audio Monitor One.
Digital System: Squeezebox Touch, DVD P181 as transport for CD, Audio gd NFB2.
Plus 4 additional TTs
No Sub-woofers were used in the reproduction of this sound
Posted 11 April 2012 - 09:06 AM
Posted 11 April 2012 - 09:12 AM
Posted 11 April 2012 - 09:23 AM
Posted 11 April 2012 - 10:09 AM
Thanks mate. A guy over at whirlpool has been suggesting some stuff based on my budget so far. It is as follows.
Suggestion 1 (Full RRP = $4996)
Castle Knight 5 – $1799
NAD C356 – $899
Arcam CD17 – $1199
Rega P3 – $1099
Posted 11 April 2012 - 01:00 PM
Sonus Faber Cremona Auditor M | Sonus Faber Cremona Centre | REL B2 | Plinius 9200 | Plinius CD101 | Oppo BDP-93 (RF) | Onkyo TX-NR818 | Primare A30.3 | Audio GD DAC19 | Audio-GD DI | SB Touch | Black Cat Veloce | QED Sig Audio S ICs & QED Genesis Speaker Cable
Posted 11 April 2012 - 05:51 PM
Edited by Nathanas, 11 April 2012 - 05:55 PM.
Posted 11 April 2012 - 05:56 PM
Posted 11 April 2012 - 06:02 PM
Posted 11 April 2012 - 06:14 PM
Thanks Greg. So if I could buy an ideal second hand set up, what would you suggest?
Posted 11 April 2012 - 07:17 PM
Posted 11 April 2012 - 08:18 PM
Edited by stephenj, 11 April 2012 - 09:18 PM.
Posted 12 April 2012 - 07:30 AM
Rega Planer 3 : PS Audio GCPH : PS Audio DLIII (Cullen) : Bel Canto Pre3 : Audio Research VT50 : VAF I-33
Project RPM 5.1 : Project TubeBox SEII : Project DacBox FL :Rega Saturn : Melody SP9r : B&W 705
Bel Canto S300iu : Bel Canto S500 : John Blue JB4
NAD 355 : John Blue JB3
Posted 12 April 2012 - 07:36 AM
Posted 12 April 2012 - 08:17 AM
Posted 12 April 2012 - 09:49 AM
Edited by Nathanas, 12 April 2012 - 09:49 AM.
Posted 12 April 2012 - 10:03 AM
Posted 12 April 2012 - 10:23 AM
Posted 12 April 2012 - 10:49 AM
Posted 12 April 2012 - 12:13 PM
There is a lot to take in on this forum! I was aware that My hd devices would run into the tv for visuals, I wasn't sure how I would get the sound out. At the moment I use rca into a digitech multi box thing. I'm not sure I'm a fan of the RCA out from tv setup either rock. Would I need to go from the optical out into something to optimise sound? I haven't seen many high end amps/receivers so I not sure which is the best way to run sound out of the tv?
Batty that is a generous offer. Thanks heaps. I will take you up on that.
Posted 12 April 2012 - 12:18 PM
That's how I'd do it as it solves all problemsOr you could think about the nad c390dd digital stereo amp...
Edited by RockandorRoll, 12 April 2012 - 12:22 PM.
Posted 12 April 2012 - 12:37 PM
Posted 12 April 2012 - 12:50 PM
Posted 12 April 2012 - 01:45 PM
Would you be interested in a speaker kit where they supply everthing, including the front baffle, but you have to build the back and sides of the two speaker boxes?
.... If it saves me money and allows for nicer speakers then yes.
Posted 12 April 2012 - 01:54 PM
Edited by Nathanas, 12 April 2012 - 01:55 PM.
Posted 12 April 2012 - 01:58 PM
Posted 12 April 2012 - 02:10 PM
I could go a little over budget....
Posted 12 April 2012 - 02:18 PM
Posted 12 April 2012 - 08:52 PM
