scan speak 12" 6th order band pass
scan speak band pass 12\
32 replies to this topic
#1 dwayne
dwayne
  • 262 posts
Posted 10 April 2012 - 09:40 AM
Hey all i'm attempting to build a sixth order bandpass using the scan speak 30w/4558t00 and the matching passive radiator,
this design came about from influence from Mr Paul Spencer, was worried about its complexeity of tuning, but what the hell.
ok design brief it is for a coffee table subwoofer, and has to please the woman i'll post its transformation once its complete as a final surprise, just build pics for now.
The reason for bandpass is to reduce localisation issues from being so close, this will be used for movies only.
The rear chamber will be tuned using a passive radiator, whilst the front chamber will be tuned using twin 100mm ports.
The panel for which the passive and ports are mounted will be removable for tunning, also my ports are very close to boundaries so may need to shorten them considerably due to them acting like a shelf port.
using winisd this design will plumb down to 24hz half volume and roll off about 68hz, using around 300wrms will push its output midband to around 112db and 102db @ 20hz whilst keeping cone excursion to 16mm peak and port velocity to around 16ms will flare to reduce noise.
The rear volume is 70lts tuned to 16hz and front volume is 40lts tuned to 42hz
once built will tune and test in room for best performance.
some pics:Attached File  ss.jpg   32.67K   21 downloadsAttached File  ss2.jpg   28.69K   28 downloadsAttached File  home made jasper jig.jpg   38.2K   28 downloadsAttached File  cutout.jpg   22.72K   33 downloads   Attached File  testfit.jpg   29.79K   29 downloads
"Its this or a mistress!"
MUSIC: Nad C372, NAD C525bee cd player, Dual 510 TT, Nad pp2, Squeezebox duet, classic
HT: Panasonic 50" fullHD, Panasonic BD35 bluray, Onkyo 606 ht reciever,
SPEAKERS:Rear surrounds using creative sounds fr125 driver,exodus 2641
#2 audible1
audible1
    Advanced Member
  • 62 posts
Posted 12 April 2012 - 10:23 AM
looks great!
send more pics when you are finished.
I am interested in what you think the transient response is like - so please let us know how it sounds (or bring it along to a DIY GTG)
#3 Paul Spencer
Paul Spencer
    Über blogger
  • 5,661 posts
Posted 12 April 2012 - 11:02 AM
Watching with interest ...
#4 gainphile
gainphile
    dip∞le
  • 1,563 posts
Posted 12 April 2012 - 11:28 AM
Mmmm makita! :)
please keep us updated!
My equipments have dissapeared....
http://gainphile.blogspot.com
#5 Antripodean
Antripodean
  • 389 posts
Posted 12 April 2012 - 05:36 PM
Good project and a nice driver
I have to say WinISD is hopeless at modelling for a bandpass. Hornresp is useful but ultimately you need to tune it based on response
if it clicks, pops, buzzes or hums it isn't hifi! ...unless it's analogue ;)
DISCLAIMER: I own over 500 records :D
#6 Paul Spencer
Paul Spencer
    Über blogger
  • 5,661 posts
Posted 12 April 2012 - 05:44 PM
Roger is right. It tends to make the peaks look worse, but last one I tried based on the sim was workable.
#7 svenr
svenr
  • 134 posts
Posted 12 April 2012 - 10:38 PM
Hope you have measured the TSP of the driver before finalising the design. WinISD is simply for serious designs, make sure you fine-tune the port lengths, passive radiator mass and volumes to get a reasonable response. I don't fully understand why you use such as narrow bandwidth / highly resonant design at close proximity to the listener. Localisation is no issues for crossover frequencies lower than 150 Hz, and this crossover is way easier realised in the electrical domain.
#8 Paul Spencer
Paul Spencer
    Über blogger
  • 5,661 posts
Posted 13 April 2012 - 12:21 PM
Svenr, have you ever tried a sub in a coffee table position? I have and localisation can be a problem even with a low and steep crossover and a low distortion sub.
#9 davewantsmoore
davewantsmoore
    Nerd
  • 2,290 posts
  • State: TAS
Posted 14 April 2012 - 05:18 PM
Would it be fair to say that .... and acoustic filter will also filter harmonic distortion products (which is what is localisable as they are often above 100hz) ... where as an electrical filter will not.
"You can measure all you want, but a mass spectrometer isn’t going to find a lot of difference between lunch at a high school cafeteria and the best dinner at a four-star restaurant" - L. Olson
Gear
#10 dwayne
dwayne
  • 262 posts
Posted 14 April 2012 - 05:51 PM
Thanks for the encouragement fella's, as for final tuning, thats exactly why i opted for ports so they could be adjusted to suit, as i would have preferred a shelf port, and the passive is easily tuned unfortunetly the internal port end won't be flared. I also have allowed a little over volume which can easily be absorbed if needed. And yes i have tested the driver same as specs or close enough thanks svenr, i used the parts express woofer tester seems to work quite nicely.
Dave that's a very good point, as with what Paul said, i too have built an coffee table sub using two 10"peerless 1727's about ten years ago, and must say it sounded good but was definetly localised and that was crossed over actively at 70hz. So hoping it all comes together, i envisage lots of tunning and testing, as several people have brought up winisd poor modelling of bandpass as Roger mentioned.
And will lug it around to Pauls once complete for some testing..
p.s Paul did you decide on a mic yet?
#11 dwayne
dwayne
  • 262 posts
Posted 14 April 2012 - 05:54 PM
Oh yeah Roger thats the other reason i chose the scan speak, hopefully reliable source of drivers where design can be built by many if it turns out good, and great build quality, i too noticed little in tried and tested subs on the net for this model driver.. Hopefully the plunge is worth it.
#12 Paul Spencer
Paul Spencer
    Über blogger
  • 5,661 posts
Posted 15 April 2012 - 11:16 AM
Yes, that's correct. It's true of both the Synergy horn and bandpass subs. Whise talked about this aspect, as did Whatmough who took up the idea, and Geddes who also does a bandpass sub, in his case I believe he uses a PR also.
#13 hochopeper
hochopeper
    Advanced Member
  • 516 posts
Posted 16 April 2012 - 09:57 AM
Sorry to go a bit off topic but does anyone have any links to technical descriptions of how this works? Does Geddes cover it in his Audio Transducers book perhaps?
Edited by zman, 16 April 2012 - 09:57 AM.
If it measures well, it might be good. If it measures poorly, no chance.
#14 dwayne
dwayne
  • 262 posts
Posted 01 May 2012 - 10:18 PM
Hey all just a quick update have been working to the bone lately and not much time for fun..here some progress pics
brace panel
Attached File  brace.jpg   6.42K   8 downloads
brace installed
Attached File  bracein.jpg   7.41K   8 downloads
port baffle brace
Attached File  port brace.jpg   7.31K   6 downloads
additional bracing installed also further supports for the long vents
Attached File  bracelast.jpg   5.79K   3 downloads
Also what do you guys think would be the best method of fixing the m.d.f baffle whilst keeping it removable, tee nuts into solid timber or just straight screws? any ideas would be great. cheerz guys
#15 Paul Spencer
Paul Spencer
    Über blogger
  • 5,661 posts
Posted 01 May 2012 - 10:36 PM
Good to see some progress!
Tnuts are stronger but ordinary screws are fine unless they are cheapies.
#16 dwayne
dwayne
  • 262 posts
Posted 02 May 2012 - 06:18 AM
Thanks Paul, might look at the t nuts due to possibly needing to remove the panel many times for tunning, and wanting it to pull up tight everytime.
#17 dwayne
dwayne
  • 262 posts
Posted 06 May 2012 - 07:11 PM
and more pics
Attached File  braced.jpg   287.71K   10 downloads
get a grip!
have decided to go with tapered brass or mild steel screws into pine, if becomes problematic will implement t-nuts and bolts.
#18 dwayne
dwayne
  • 262 posts
Posted 08 May 2012 - 10:00 PM
and some more progress..getting closer now
Attached File  cabling.jpg   10.87K   13 downloads
all innerbond in place as well as glue. box tipped over onto lid piece
Attached File  fluff and glue.jpg   10.8K   22 downloads
once happy with positioning weigh the woofer box down!
Attached File  weighted.jpg   19.19K   20 downloads
next will be front panel and its cut outs.
#19 dwayne
dwayne
  • 262 posts
Posted 11 June 2012 - 09:34 PM
Hi guys have finally finished the box here are the final pics, onto testing phase now.
from what I can tell my example is almost on par with what was expected from winisd. Also localisation is none existent seems to be a success, here are the final build pics. Testing plots will be posted next.
Attached File  counter sinking driver.jpg   96.66K   5 downloads
Attached File  baffle.jpg   76.62K   6 downloads
Attached File  ports.jpg   70.24K   6 downloads
Attached File  flared.jpg   85.67K   9 downloads
Attached File  baffle complete.jpg   75.17K   12 downloads
Attached File  baffle fitted.jpg   66.72K   12 downloads
#20 Paul Spencer
Paul Spencer
    Über blogger
  • 5,661 posts
Posted 12 June 2012 - 12:11 AM
Nice job on the ports Dwayne! Looking forward to seeing the result.
#21 dwayne
dwayne
  • 262 posts
Posted 16 June 2012 - 06:14 PM
ok test plots
here is the first using
a monophonic pseudo-noise sequence. The Radiator has been weighted 30grams and microphone is 1ft away from either radiator or port see file name.
Testing using Dayton omnimic test software for all tests output from amp unchanged.
Attached File  30g port 1ft trk1.jpg   66.34K   11 downloads
Attached File  30g rad 1ft trk1.jpg   66.33K   14 downloads
and with 59grams
Attached File  59g port 1ft trk1.jpg   66.9K   15 downloads
Attached File  59g rad 1ft trk1.jpg   68.53K   12 downloads
next track is with monophonic short sine sweep
30grams
Attached File  30g port 1ft trk2.jpg   66.84K   9 downloads
Attached File  30g rad 1ft trk2.jpg   67.69K   9 downloads
59grams
Attached File  59g port 1ft trk2.jpg   68.83K   9 downloads
Attached File  59g rad 1ft trk2.jpg   68.25K   6 downloads
#22 dwayne
dwayne
  • 262 posts
Posted 16 June 2012 - 06:30 PM
ok next ones
the following are using a monophonic bass sweep to show bass response and decay
30gram
Attached File  30g port 1ft trk4 bass response.jpg   210.72K   10 downloads
Attached File  30g rad 1ft trk4 bass response.jpg   214.82K   7 downloads
and 59gram
Attached File  59g port 1ft trk4 bass response.jpg   215.76K   4 downloads
Attached File  59g rad 1ft trk4 bass response.jpg   220.81K   14 downloads
this was the setup
Attached File  testing.jpg   63.23K   24 downloads
and this graph is from the woofer tester to check impedance (59grams), both the 30gram and 59gram show very similar tunings which is the lowest points between the peaks round 17hz and 40hz, pretty close to what i had modeled for in winisd. I seem to think that the 30grams gives a flatter response.
Attached File  ss bandpass 130612.jpg   197.46K   25 downloads
Here is what the 59 gram looked like when placed in its intended position and microphone placed in listening position (couch)
track 1 monophonic pseudo noise sequence
Attached File  inroom listenin trak 1.jpg   66.35K   18 downloads
track 2 monophoni short sine sweep
Attached File  inroom listenin trak 2.jpg   66.41K   19 downloads
and finally bass response and decay
Attached File  listening trak4.jpg   217.78K   13 downloads
from what can be seen above i seem to have a big boost in room around the 20-40hz range.
Edited by dwayne, 16 June 2012 - 06:32 PM.
#23 Paul Spencer
Paul Spencer
    Über blogger
  • 5,661 posts
Posted 16 June 2012 - 11:32 PM
Are those smoothed? I'm not seeing anything that looks like an inroom measurement!
With your nearfield measurements the mic normally goes as close as you can get without risk of hitting the cone.
If those last ones really are showing inroom then your decay looks unusually good. In that case, lucky you! You might EQ the bottom octave down a little then cross at say 60 Hz or so. How is it going with imaging and localisation?
#24 dwayne
dwayne
  • 262 posts
Posted 17 June 2012 - 01:00 AM
Hey Paul yeah they are 1/6 octave, should I have used none? Might try a near field as you recommend, also yes the in room is with sub in final position and mic in listening seat at ear level. I'm pleased to say that I can't localize the sub even though it's only a foot away in front of me, imaging is excellent can't pick anything really happy with it this goes for both movies and music. The next step is final testing and obtaining a minidsp for high pass and any eq required. Looking at the graphs do you think the 30 gram plots are better then the 59 loaded.What is a bad decay?
#25 dwayne
dwayne
  • 262 posts
Posted 28 June 2012 - 08:20 PM
ok just quick update have recieved my minidsp in the mail today so will do some final unsmoothed testing this weekend then maybe apply some dsp yay!
#26 dwayne
dwayne
  • 262 posts
Posted 08 July 2012 - 07:34 PM
G'day all i have done some more testing, but now i have a weird situation, there seems to be a large dip (massive hole)centered at around 42hz
Attached File  track 1 freq port.jpg   69.25K   15 downloads
also to note this is also the tunning frequency, i am at a loss how my measurements are differing from first lot, these ones where done in its final position however i had made the measurements near field, but it also shows through on the listening position.
Attached File  track 1 freq list.jpg   68.94K   13 downloads
Is it possible for such a larger dip at the tunning frequency? i was under the impression there would be a peak if any thing. perhaps a higher tuning would help?
#27 Paul Spencer
Paul Spencer
    Über blogger
  • 5,661 posts
Posted 09 July 2012 - 09:38 AM
Are we looking at an inroom unsmoothed now?
#28 dwayne
dwayne
  • 262 posts
Posted 09 July 2012 - 10:42 AM
Hey Paul yes we are(the last pic), however for a sanity check i ran it smoothed and it still shows a large dip. Is this possible?
quick run down only differences, i did the nearfield as you suggested as close as possible to the driver as oppsed to one foot away. And for nearfield the sub is in its final position, first lot of pics was in different room. This would not matter being near field. Any ideas, could it be the tuning? perhaps the driver has broken in a little bit since testing?
My thoughts are to run tests again, then if i still get same results, cut ports down to raise tuning to hopefully push dip up out band. This may cause localisation problems...
one final thought, i may have used a different amp.....it was a rotel power amp...i'm now using a playmaster sub amp..more testing
#29 dwayne
dwayne
  • 262 posts
Posted 09 July 2012 - 10:43 AM
sorry first pic is nearfield on port, the radiator has same response.
#30 Paul Spencer
Paul Spencer
    Über blogger
  • 5,661 posts
Posted 09 July 2012 - 03:03 PM
Looks like you are showing just the output of the lower tuned rear chamber. The response of front and rear chambers should be different!
#31 dwayne
dwayne
  • 262 posts
Posted 09 July 2012 - 03:33 PM
ok, how do i test each one? originally i had been testing both the port and radiator, and i did do this with same tracks and levels etc, i might have to test it all again, also the second picture is in the listening position, a difference would not be seen correct?
#32 Paul Spencer
Paul Spencer
    Über blogger
  • 5,661 posts
Posted 09 July 2012 - 06:21 PM
mic goes right up close to the PR, as close as you can safely go - then the PR output should dominate ... with the ports the mic goes into the mouth in line with the edge of the box. Either way you should isolate relatively well, although when I've done this there was a bit more distance.
#33 dwayne
dwayne
  • 262 posts
Posted 10 July 2012 - 09:38 PM
Hey Paul thanks for your toughts, i didn't seem to get much difference between the port and radiator, which could be due to them being relatively close.
i also got round to doing another round of testing, i started with my mic settings, and found the mic level wasn't set to maximum which is required with the omnimic, the results were much better
all near field with 30g mass added to Radiator
this is @ port monophonic signal, pseudo noise setting.
Attached File  port trk1 30g (1).jpg   73.73K   4 downloads
and another
Attached File  port trk1 30g (2).jpg   74.68K   3 downloads
this is the radiator
Attached File  rad trk1 30g.jpg   72.9K   2 downloads
this is a sinewave @ the port
Attached File  port trk2 30g.jpg   69.52K   3 downloads
this is with active filter on amp set to 120hz and minidsp set to 50hz to knock out bump at port
Attached File  port trk2 30g act120 md50.jpg   63.26K   2 downloads
now at radiator
Attached File  rad trk2 30g act70 mdsp50.jpg   62.9K   3 downloads
this is with 6db of boost @ 35hz with a Q of 6 using minidsp to fill in hole
Attached File  rad trk2 30g act70 mdsp50 boost 4db@35hz q2.jpg   63.69K   3 downloads
my intial thoughts are that the boost is too much with a q too high, also to note now that i sorted out the mic, will be worthwhile adding weight to radiator to hopefully boost the low end more naturally in the design.
This is now the listening position with active filter @70 on amp and 50 on mini dsp no boost sine wave
Attached File  list trk2 30g act70 md50.jpg   63.43K   4 downloads
now with boost 6db @ 35hz, Q=6
Attached File  list trk2 30g act70 md50 boost35 6db q6.jpg   63.82K   6 downloads
all settings/graphs have a high pass applied @ 18hz.
so as mentioned before will try different weight to see its effect.
also to note the minidsp is fantastic, quite quick its great to see and hear your results immediately.
Dwayno
