spellcheck 2
#1
Posted 02 April 2012 - 01:31 PM
Has something changed again that I didn't see or read about?
2 channel set-up -Garrard 401 and Yamaha PF800 TT's - CA640Cv2 CD- NAD116 Pre - Rotel RB1070 amp- VAF DCX1v2 speakers.
A/V -Denon3802-PanasoniicXW300PVR-MS fronts-VAF DC6-2xJaycar 350w 12"subs-Yamaha & Realistic rears.
#2
Guest_dingo_*
Posted 02 April 2012 - 02:02 PM
Dingo.
#3
Posted 02 April 2012 - 06:49 PM
More Information: Click here to make a donation to StereoNET Australia.
Consonance Droplet CDP-5.0D | SGR Audio CX4F Floorstanders
#4
Posted 02 April 2012 - 07:04 PM
When you want check your spelling, right click.
On the window that pops up. on the bottom line you will see check spelling.
Then left click on that.It will then high light mistakes in block red.
Make the necessary corrections after that the usual wavy line should show up.
From time to time if its not working go through the right click left procedure in block red again.
Correct the mistake and it should go back to the wavy underline.
Edited by MC240, 02 April 2012 - 07:08 PM.
Caveat Dyslexic at work ![]()
When the going gets tough the weird turn pro HST
Current favourite track
http://www.youtube.com/watch?v=_lFRmd79GrM
#5
Posted 02 April 2012 - 08:14 PM
#6
Posted 02 April 2012 - 08:16 PM
The only thing I can think of Grumps is try it again maybe you missed a step.
Sorry to state the bloody obvious but can you at least see the check spelling with the green tick in front of it in the pop up when you right click
Edited by MC240, 02 April 2012 - 08:34 PM.
#7
Posted 02 April 2012 - 08:29 PM
When we first changed over it took a couple of days for it to work and it worked fine - then it stopped working a few days a go.
#8
Posted 02 April 2012 - 08:35 PM
#9
Posted 02 April 2012 - 08:50 PM
I have a tick next to the pop up - not sure it's green though
Nope no red underlines here - I just went to another site and tried it and it's working fine.
AH! success! under spellcheck in the pop up is 'Languages', when highlighted with the cursor English -Australia needs to be clicked.
#10
#11
Posted 02 April 2012 - 08:51 PM
Edited by MC240, 02 April 2012 - 08:52 PM.
#12
Posted 04 April 2012 - 09:20 AM
Same thing fixed it for me. Strange that is on for other sites and not here. Anyway all working now - and I finally realised you can have an Australian dictionary! YayAH! success! under spellcheck in the pop up is 'Languages', when highlighted with the cursor English -Australia needs to be clicked.
#13
Posted 04 April 2012 - 11:16 AM
I have to repeat this every time I turn the computer on each day or it won't work - like you I'm puzzled why it works automatically on all other sites, but here it's a manual switch on every day.Same thing fixed it for me. Strange that is on for other sites and not here. Anyway all working now - and I finally realised you can have an Australian dictionary! Yay
#14
Posted 04 April 2012 - 07:20 PM
Just Vinyl
SR-838/2M Bronze - Tweaked BHL Phono - Custom EL34 - ML-1's - Aurealis cables/IC's
#15
Posted 04 April 2012 - 07:52 PM
