onboard phono stage or dedicated?
#1
Posted 01 March 2012 - 11:29 AM
I'm new to hi fi and vinyl equipment and have just set up my first modestly priced system. It comprises the following:
Marantz Pm6004 Int Amp
Monitor Audio Brx2
Rega Rp1 TT
I am wondering in your opinions, is it worth running a dedicated phono stage instead of using the pm6004's integrated one? I can't really find much discussion on whether or not the integrated phono stage is any good or if it is just "tacked on" as an extra feature. Is there something around a couple of hundred dollars that will increase performance noticeably? Thanks
#2
Posted 01 March 2012 - 05:11 PM
Hey guys,
Monitor Audio Brx2
Rega Rp1 TT
It would depend on what that particular integrated is. For instance some folk like the phono section on one of the integrated Shindo amps, but that kind of amp costs more than your current system. Some of the older integrated amps had relatively good integrated phono sections. The majority of vinyl fanatics use a dedicated phono stage. Depending on your budget why don't you contact member Cheekyboy (Keith) and inquire about his Graham Slee loaner program (I am not sure of current pricing). That way you can try it side by side with your integrated and decide whether you like and can afford a dedicated phonostage.
#3
Posted 01 March 2012 - 05:21 PM
Sure you can get better , but you may have to spend as much as the cost of your whole amp to do so.
#4
Posted 01 March 2012 - 05:28 PM
So give it a whirl for a while and you may end up like me, using the onboard for 16 years
Analogue setup: 1986 Townshend Rock Mk2/AO rewired RB250/Soundsmith retipped VdH DDT-II special, Marshall Leech head amp, Copland CSA-14, Castle Howards.
PC System: i7 win8, T Amp, Monitor Audio Monitor One.
Digital System: Squeezebox Touch, DVD P181 as transport for CD, Audio gd NFB2.
Plus 4 additional TTs
No Sub-woofers were used in the reproduction of this sound
#5
Posted 01 March 2012 - 10:37 PM
I run a Rega P1. I have a Rotel RA1520 with on board phono. My Rega Fono Mini sounded better then the on board Rotel, and the Graham Slee Amp 2 phono stage sounded better still.
I am here: http://tapatalk.com/map.php?dj2mr5
Having set a really tight budget for life's luxuries, like audio gear, has really made me appreciate the gear I already own, and to enjoy all the great music I have.
#6
Posted 03 March 2012 - 07:15 AM
#7
Posted 05 March 2012 - 12:13 AM
I second Tax's advice to contact cheekyboy for the Graham Slee loaner program.
I agree. If you're like us, eventually you'll upgrade the TT and cartridge and then you won't need to upgrade the phono stage.
Geoff
#8
Posted 12 March 2012 - 05:06 PM
Now I use a Gram Amp 2 Special Edition with my Thorens 295Mk4 + Ortofon 2MBlue cartridge - The GA2SE will stay even if I change the TT.
#9
Posted 12 March 2012 - 05:33 PM
If so start with that gives u more budget for a better tt
if not buy a separate phono
#10
Posted 12 March 2012 - 05:58 PM
#11
Posted 19 March 2012 - 11:46 AM
But if you feel its lacking in its delivery buy a seperate unit.
I noticed the difference straight away and it gets better every time I use it (burning in) - Im glad I bought it.
