Nada Posted February 16, 2012 Share Posted February 16, 2012 This might be a big upgrade on the old standard Foobar equaliser. It does pre-echo minimisation controls the low frequencies with narrow bands down to 20Hz has a rapid open via "View" allows L/R balance check it out: http://www.hydrogenaudio.org/forums/index.php?showtopic=88504&st=0&p=755011entry755011 Graphic Equalizer By: xnor A graphic equalizer featuring - 31 bands (1/3rd octave width) - boost/cut range of +-12 dB in .1 dB steps - master gain - minimum phase filters to eliminate pre-echo - smooth frequency response - import/export functionality - mono and stereo mode http://www.hydrogenaudio.org/forums/index.php?showtopic=88504&st=0&p=755011entry755011 Link to comment Share on other sites More sharing options...
Lil Caesar Posted February 16, 2012 Share Posted February 16, 2012 Sweet. a FREE new toy to play with Cheers Nada. Link to comment Share on other sites More sharing options...
Guest Muon Posted February 17, 2012 Share Posted February 17, 2012 Interesting, doesn't work set on wasapi digital output. Not that I ever use EQ's anyway. Nice to post anyhow. Link to comment Share on other sites More sharing options...
LuzArt Posted February 17, 2012 Share Posted February 17, 2012 Awesome, thanks for the heads up. I do use a bit of mild boost for around 60hz-160hz for my 701's. Link to comment Share on other sites More sharing options...
LuzArt Posted February 17, 2012 Share Posted February 17, 2012 Bugger. Tried this, got a moderate but constant ticking sound, only when this version of the plugin is activated. Rolled back to my previous version, all good. Shame. Link to comment Share on other sites More sharing options...
Nada Posted February 18, 2012 Author Share Posted February 18, 2012 That's weird. Ive got WIN7 - Foobar v1.1.10 - Graphic Equalizer 0.3.7 - WASAPI with 120ms buffer Its been faultless from the first go. Try updating Foobar/reboot/close-reopen Foobar/WASAPI/Buffer length 30-200ms/other DSP's out and introduced The fix should be easy with a little trial and error. Link to comment Share on other sites More sharing options...
LuzArt Posted February 21, 2012 Share Posted February 21, 2012 Hmmm, wonder if it's because I use ASIO4ALL? Link to comment Share on other sites More sharing options...
Nada Posted February 21, 2012 Author Share Posted February 21, 2012 Did some serious listening with the Graphic Equaliser and preferred it without. Less is more ussually I suppose. Link to comment Share on other sites More sharing options...
Guest Muon Posted February 21, 2012 Share Posted February 21, 2012 That's what I find most of the time with software. Back when Winamp was one of the better players one of the tweaks to improve the sound was to strip everything nonessential from it. Link to comment Share on other sites More sharing options...
