USB to S/PDIF Devices
#1
Posted 13 January 2012 - 07:01 AM
#2
Posted 13 January 2012 - 07:49 AM
The biggest factor is the quality and stability of the crystal oscillators (i.e. the "clocks") in the devices. The stability is influenced by the quality of the power supply, hence all the talk about running things from batteries.
Lenehan ML2 Reference with "limited edition" stands < Ribbontek cables < Rega Elicit (direct input) < Ribbonflex interconnects < Metrum Octave < Dtek digital cable < Audiophilleo 2 < home-made split USB cable with Tevion Li-Ion battery pack < MacBook Pro with Audirvana+ doing upsampling and volume control
#3
Posted 13 January 2012 - 11:40 AM
Also, would the difference between the jkeny and offramp be significant on a good dac or are the returns diminishing as you move up in dac quality?
Thanks.
#4
Posted 13 January 2012 - 01:29 PM
#5
Posted 16 January 2012 - 10:56 PM
#6
Posted 16 January 2012 - 11:29 PM
Why go to USB?
Greg
Adelaide Sales Representative
www.audiofidelity.com.au
Brinkmann MSB Technology SGR Audio
BRINGING YOU CLOSEST TO THE ORIGINAL SOUND!
#7
Posted 17 January 2012 - 05:40 AM
#8
Posted 17 January 2012 - 09:51 AM
I'd like to give one a try, but I can not afford to buy an audiophilleo or offramp.
I just want to get a feel for what they can do.
#9
Posted 17 January 2012 - 09:55 AM
I don't want to hijack the thread, but is there anything half decent for cheap? like <$200?
The cheapest one worth trying is the Audio-GD Digital Interface. It's not async, but it's pretty good regardless. You still need a decent coax cable though, which adds to the cost and complexity.
#10
Posted 17 January 2012 - 10:36 AM
Apart from the factor of synergy - different DACs might perform slightly better with a JK than an AP, for example - they basically all sound the same. That is, the better they are the more they sound like nothing at all. All you're left with is the sound of the music and the DAC.
Indeed. I preferred the Metrum Octave with the JK more so than with the AP. The JK took away some of the glassiness and etch (that was more prominent with the AP). Having said that, I mostly prefer the AP with other DACs but there really isn't a lot in it.
Editor, Digital Audio Review.
#11
I have read in a few different forums that the OPTICAL output of the 2011 Mac Minis is exceptionally low in jitter--less that 30 pico-seconds and some measurements close to 10 pS.
Why go to USB?
Greg
I have a Mac mini 2011 and the sound quality out of USB to the Audiophilleo is way, way better than out of the optical port.
#12
Posted 17 January 2012 - 11:05 AM
You're welcome to borrow my Audio-GD Digital Interface for a week or two if you like - I'm without a DAC at the moment so it's not being used.
Copland CTA 520 power amp / Copland CTA 305 preamp / Metrum Octave / Audiophilleo 2 / Blue Jeans speaker cable and interconnects
#13
Posted 17 January 2012 - 11:23 AM
#14
Posted 17 January 2012 - 12:21 PM
I tested this via the headphones (B&W P5) and could notice a difference. Example, female vocals, the end of higher notes were a bit harsher via the optical, and a bit smoother via the DI. I'm too inexperienced to now if this is jitter or not, just that I could hear a noticeable difference.
On the main system, I haven't yet noticed a difference as background music plays. I haven't had a chance lately to have a listening session when all is quiet.
Having set a really tight budget for life's luxuries, like audio gear, has really made me appreciate the gear I already own, and to enjoy all the great music I have.
#15
Posted 17 January 2012 - 01:31 PM
Available now I believe.
#16
Posted 17 January 2012 - 01:53 PM
What about the Musical Fidelity V Link 192?
Its biggest weakness is that is has only one crystal oscillator, for the 48/96/192 family. If you're playing 44.1 material, you get PLL-induced jitter as the v-link has to approximate that frequency.
It works - i.e. you get audio out of USB and into SPDIF - but it doesn't sound much good.
#17
Posted 17 January 2012 - 02:17 PM
#18
Posted 17 January 2012 - 02:37 PM
#19
Posted 17 January 2012 - 02:45 PM
#20
Posted 17 January 2012 - 02:59 PM
The new V Link (still) has this issue, or do you mean the old one? The new V Link 192 has only just been released.
I know nothing of the new one - it's not even officially out yet, by the look of it. I'm talking about the 96kHz one. (Shouldn't have mentioned 192 in the crystal frequency earlier, sorry.)
#21
Posted 17 January 2012 - 03:11 PM
Fair enough, just wondered if you were on an inside run there
#22
Posted 17 January 2012 - 04:08 PM
i use thisI don't want to hijack the thread, but is there anything half decent for cheap? like <$200?
http://coemaudio.com...uter-Audio/287/
it does what i pay it to do
Rega Planer 3 : PS Audio GCPH : PS Audio DLIII (Cullen) : Bel Canto Pre3 : Audio Research VT50 : VAF I-33
Project RPM 5.1 : Project TubeBox SEII : Project DacBox FL :Rega Saturn : Melody SP9r : B&W 705
Bel Canto S300iu : Bel Canto S500 : John Blue JB4
NAD 355 : John Blue JB3
#23
Posted 17 January 2012 - 04:10 PM
Fascinating finding noted there.
Did you try up-sampling into the Metrum by any chance? If so did the etch change?
“Einstein said that if quantum mechanics were correct then the world would be crazy. Einstein was right - the world is crazy.”
#24
Posted 17 January 2012 - 05:18 PM
So, a Jkeny Mk3 will sound the same as the offramp 5 but for the $700 price difference, you are getting better execution (more realism?). I am trying to figure out which device to purchase. I don't mind paying for quality if I am actually getting it. Also, would the difference between the jkeny and offramp be significant on a good dac or are the returns diminishing as you move up in dac quality?
Having compared by myself, and with fellow Audiophiles, an Off-Ramp to all the others you mention, and the Berkeley, I can assure you it sounds the best with one exception. By sounding the best is meant less slurry, smother, more analogue like, and a lack of a quality I call 'darkness' that I have come to associate with Jitter. The one exception is I2S into a PDX from the Off-Ramp compared to its internal battery powered M2Tech board. I, and some fellow audiophiles, have conducted a careful comparison of the two and it was excruciatingly close - so close right now I will not which won by a whisker. I have both in my system now and when I get some time will do some more comparisons. I have already done a quick further comparison with a fellow SNAer and we thought, again very very close, but the Off-Ramp may just be slightly smother by a whisker - whether that is at the expense of something else only further listening tests will show. How does it compete? The conjecture is the shorter path lengths of the internal M2Tech is what allows it to be so competitive whereas the external version of the M2Tech is not.
The problem here however is not which is best - the problem is is it worth the extra dosh. Of the people I have demoed the Off-Ramp to some say it is (I am in that camp) others say it isn't. Its basically up to you.
Bill
Mac-Mini, Essential Signature USB Cable, Level 2 PDX, Ribbontek RCA Cables, NAKSA 100, Ribbotek Speaker Cables, Lenehan ML3 Reference.
#25
Posted 17 January 2012 - 05:21 PM
I have read in a few different forums that the OPTICAL output of the 2011 Mac Minis is exceptionally low in jitter--less that 30 pico-seconds and some measurements close to 10 pS. Why go to USB?
I have tried it into my Metrum and to be blunt - it is hopeless - slow, uninvolving, and boring. I only recommend it as an interim measure.
Bill
Edited by bhobba, 17 January 2012 - 05:28 PM.
#26
Posted 17 January 2012 - 05:26 PM
What about the Musical Fidelity V Link 192? Available now I believe.
An acquaintance bought one over (not the newer model) - OK - but my other stuff at the time murdered it.
Bill
Edited by bhobba, 17 January 2012 - 05:32 PM.
#27
Posted 17 January 2012 - 08:51 PM
Hailide Bridge is good because it is the cable too.
http://www.aprilmusi...ub02_03_05.html
#28
Posted 17 January 2012 - 09:52 PM
#29
Posted 17 January 2012 - 10:43 PM
#30
Posted 17 January 2012 - 10:56 PM
I have heard the Bryston referred to in your other post - sound was good, it is a different approach than the mac mini though - more expensive possibly too.
The different dacs might sound different with different converters. Interesting that the Phasure, Lampizator, pdx and Audio Aero dacs have related or inbuilt converters.
IMO what is happening know is that the computer software, usb/spdif converters and dacs are developing fast and one should buy equipment that can be upgraded. I would not buy anything that is not upgradeable. My reasoning. If I buy a Bryston that can do music at 32/192 and I can download music at 384 and my dac can only do 24/96 then I will be limited to 24/96. And finally listen before you buy.
#31
Posted 17 January 2012 - 11:46 PM
Have you checked one of these out,Stello U3 (link Below) dual chip sets for both sampling frequencies.
Yes - not bad - but the Audiophilleo was clearly better.
Bill
#32
Posted 17 January 2012 - 11:49 PM
A lot of people like the Kingrex UC-192 USB/Spdif Bridge - it is ~ USD200.
For $189:
http://shop.maplesha...r=USBADAPTER-CL
Also for about $350:
http://www.lindemann...odukt-features/
"Unlike other products on the market, the USB-DDC 24/192 has an additional data processing circuit (with data buffering and clock-synchronization), which means it can guarantee an output signal jitter performance that not even the most expensive CD drives can match. The grounding system is completely electrically insulated"
A comprehensive listing here:
http://thewelltemper...W/USB_SPDIF.htm
Edited by wis97non, 18 January 2012 - 01:02 AM.
More info
#33
Posted 19 January 2012 - 10:42 AM
The change was quite phenomenal. I used to be happy with the Metrum just being fed straight off the PC. This has really taught me that I can get so much more out of it. I had heard about this, but I didn't realise how much better it was.
The sound is more natural, has more drive behind it, more emotion behind it, bass has more substance to it (more punch?)...
I wasn't exactly unhappy with the Metrum on its own, but I used to think it sounded a bit thin... like listening to music in too large and open a space from the back of the venue (like the BEC if you know what I mean...)... but adding the DI, it has made it like I am sitting in the sweetspot of a well designed amphetheatre. (I don't know if I'm explaining this well... but I'm not good at using words to describe sound. I'm relatively new to this game)
Now, I will definitely have to think about getting something to the likes. May be even an Audiophilleo 2 if budget allows, and everyone thinks it's that much better (what's everyone's opinion on this?)
I will definitely have to wait till after I pay my rego next week, but research starts!!
#34
Posted 19 January 2012 - 11:42 AM
Pure marketing bull****, I'm afraid. Have a look at the circuit board photo and you'll see a Wolfson WM8804 SPDIF chip. That's where the "buffering and clock sync" comes in.
It's a clever chip, and yields real improvements over doing nothing at all, but it's not on par with some of the other products mentioned. Even the Audio-GD is likely to beat it in most cases, though it doesn't go to 192kHz.
BTW, the WM8804/5 is also found in the Firestone Bravo, the Rega DAC and the SPDIF-equipped PDX. Probably in the new Cambridge Audio products. And so on.
#35
Posted 19 January 2012 - 11:45 AM
Seaninbrisbane has kindly loaned me the Audio dg DI, and I had a little play with it so far.
Oh yes, the Metrum absolutely needs a clean SPDIF source because it has no jitter rejection of any significance built into it. I'm sure we could arrange for you to have a listen with an AP2 - it's better than the Audio-GD but probably not as dramatic an improvement as you've just heard.
#36
Posted 19 January 2012 - 01:23 PM
Thanks kdoot. I'd like to hear AP2 in action sometime, but I'm happier with spending less money than more, so (unless there is a massive jump in performance,) I might just try a few $200-250ish devices and see which one works best for me... along with some web research.
I think some that are currently on my list are M2tech hiface, Audio DG DI and v-link II... this list may blow up to be a lot longer as my research goes on.
#37
Posted 19 January 2012 - 01:30 PM
The Metrum is one of those DAC's that benefits enormously from a low jitter source - any better source is easily heard with that DAC. I always recommend if you get a Metrun you get the best source you can - even though it is by far the most expensive the Off-Ramp performs the best with that DAC.
Bill
#38
Posted 19 January 2012 - 01:39 PM
I have other things in life that needs to be taken as priority, fortunately or unfortunately...
#39
Posted 19 January 2012 - 01:51 PM
I understand with more money, you can get better performance, but I just can not justify the spending with my finances. I have other things in life that needs to be taken as priority, fortunately or unfortunately...
No problemo. Simply remember with the Metrum to get the best your budget will allow.
Bill
#40
Posted 19 January 2012 - 03:03 PM
I may save up to get an audiophilleo, or try and find what is the best for under $250 in my system... or may be there's a comparable unit to audiophilleo in the similar or less price?? anyone willing to put in their thought on this?? (anyone with thoughts on hi-face evo or bel canto thing?)
I've still got a few days in loan of the Audio dg, so I'll see if I can get my hands on any comparison units in the meantime.
#41
Posted 19 January 2012 - 04:28 PM
Whether to go Audiophilleo 1 or 2 or ?. Whether to stay PC or go Mac Mini or another DAC etc etc......
Currently for PC driven sound it basically looks like:
Laptop--->USB to Onkyo NDS1--->ME12 DAC via coax(or Perpet Tech 1A,3A)--->ME24--->ME850--->TannoySRM1000
FLAC lossless ripped with DBPoweramp, using J River MC17 using no DSP settings and 16/44.1 except for HDCD albums. Using ASIO4all.
Also any thought on using a Vaunix USB hub or something similar to minimise USB power noise etc?
So any advice would also be appreciated on this subject.
Decisions decisions... so many forum articles and reviews.....
Steve
Edited by ummagumma, 19 January 2012 - 04:48 PM.
correction
#42
Posted 19 January 2012 - 08:34 PM
ummagumma - There's no SQ difference between the AP1 and AP2. It's all explained on their website. If you're on a PC, why not stay, use the free software available (foobar) maybe with JPlay to wring as much SQ out of it as you can (I still haven't tried that yet) and go with a decent DAC (around AU$500). There's a bunch available at that price now and I daresay more to come.
Luzart. Photography.
#43
Posted 19 January 2012 - 08:45 PM
Interesting comment. Thanks
#44
Posted 19 January 2012 - 09:00 PM
Has anyone tried this comparison with a DI or Audiophilleo in the USB chain?
How does it compare?
Is there anyone in Adelaide (or elsewhere) who would like to bring along or loan a DI or Audiophilleo so I can compare for myself?
Greg
#45
Posted 19 January 2012 - 10:21 PM
I have compared the optical against the USB from the 2011 Mac Mini to the Audio-gd NFB2 and to my ears (and a few others) the optical wins each time.
Yep. It's worth saying again and again: the built-in USB interfaces on the majority of DACs are really not worth listening to. Even Toslink straight from a computer tends to beat it!
