huge static sound !!!
12 replies to this topic
#1 Bus_Boy
Bus_Boy
  • 1,536 posts
Posted 11 January 2012 - 10:24 PM
Sony S370 BRP > Optical downmix> Rotel RSP976 > Analouge > EP2000 > Speakers
So far i've watched a few movies with this setup, and everything was good. But tonight i was watching a movie and all of a sudden the dialogue was drowned out by a loud and constant static sound.
Popped the disc out and put a cd in, and all was fine, went back to the movie, all good. But then again after about 10 mins the same thing happened again. Didn't matter if i paused, skipped scenes ect, the sound stayed there, and only goes away if i open and close the tray. (note when pausing everything went quiet so i can rule out noise from the power amp)
Does anyone have any thoughts on what might be causing this? Could it be a firmware related issue? I've never updated the BRP's firmware in the 2+ years i've owned it, so far there hasn't been any issues.
#2 Telecine
Telecine
  • 2,817 posts
Posted 11 January 2012 - 10:37 PM
Does it happen on other discs?
Learn from the mistakes of others - you'll not live long enough to make them all yourself!
#3 Bus_Boy
Bus_Boy
  • 1,536 posts
Posted 11 January 2012 - 10:40 PM
On the few other movies i've watched nothing has happened. Also it's not around a certain timeline on the disc either, once i sort the issue by opening / closing the tray i can play the same scene back without any problems. It was a new disc too.
I've switched it all off now but i'll have another play around with it tommorow, and look into firmware updates.
#4 Telecine
Telecine
  • 2,817 posts
Posted 11 January 2012 - 10:46 PM
It could be a firmware related issue.
The other thing to try would be to swap the optical cable out.
Lastly, have a look at your bitstream settings on the BRP.
#5 LogicprObe
  • 8,891 posts
Posted 11 January 2012 - 10:50 PM
Weird.
No cyclones up there?
#6 Bus_Boy
Bus_Boy
  • 1,536 posts
Posted 11 January 2012 - 11:07 PM
Haha no cyclones, i've built the PJ mount to withstand a cat 5 anyway and i'll be taking my amps with me to the evac centre :P
#7 LogicprObe
  • 8,891 posts
Posted 12 January 2012 - 01:58 PM
Maybe you're too close to the beach?
#8 emesbee
emesbee
  • 5,113 posts
Posted 13 January 2012 - 11:37 AM
It might be worth checking for possible sources of RF interference near your equipment. I once had a video sender device located next to my Marantz AVR, and it caused intermittent logic malfunctions (one of which was a loud buzz of static through all the speakers at once). Stopped using the video sender, and no more problems.
Knowledge is knowing a tomato is a fruit.
Wisdom is not putting it in a fruit salad.
#9 Monkeyboi
Monkeyboi
  • 2,878 posts
Posted 13 January 2012 - 01:07 PM
Hi Bus_Boy,
It would be helpful if you filled us in on a few points to assist in tracking down the problem -
  • Disc title (BR or DVD?)
  • What audio track were you playing (DD5.1, dts, etc)
I'm a bit confused by this statement -
So I'm assuming that when you PAUSED the movie there was no sound? This is to be expected as there are a pair of transistors in the analogue outputs which short out the signal when the machine is in PAUSE mode.
Was the sound you heard like a loud hissing sound?
Alan R.
Edited by Alan Rutlidge, 13 January 2012 - 01:11 PM.
Amplification: ME-850HC power amp, Sony STR-DA5600ES receiver, Sony TA-P9000ES pre-amp, Sony TA-N9000ES x2 power amps, Sony TA-E9000ES pre-pro, custom analogue buffer / switch, custom RIAA pre-amp.  Sources (digital): Sony SCD-XA5400ES SACD player, Sony MDS-JA3ES minidisc deck, Tascam DA20 Mk2 DAT deck, Philips DCC900 Digital Compack Cassette deck, Sony BDP-S370 Blu-ray player, Sony PS3 slim, Pioneer DV-S838A DVD-Audio player.  Sources (analogue): Technics SL1200 GLD turntable, Tascam 42B reel to reel, Sony TC-K570 cassette deck.  Speakers: Quad ESL2905 (fronts), KEF Q75 (rears), Richter Odin (sub) & Unicorn (centre). DACs: CEC DX-71 Mk2, Emotiva XDA1.  Cartridges: Shure V15 type 3 (MR stylus), Shure V15VxMR.  Misc: dbx 119, Aurex AD-2 noise reduction system, Sony SQD2010 SQ/QS quad decoder, JVC 4DD5 and Pioneer QD-240 CD4 demodulators, VPI record cleaning machine.
Computer room system: Sony STR-DA5200ES receiver, Boston Acoustics CR9 speakers, Technics SL1200 (original version from the 70s)
Semi retired gear: Equinox Audio Jupiters, Sony SCD-XA333ES SACD player, Philips DCC130 portable Digital Compact Cassette player, Sharp Minidisc portable, 250W + 250W monoblock power amps.
Retired gear in storage: Sansui AU-417, Sansui TU-417, Richter Wizards, KEF Concerto x2 pairs, Sony ST-JX741 tuner, Sony CDP-338ESD CD player, Yamaha CA700 integrated amp,Tascam analogue mixing desk and a lot more other stuff than I care to list (mainly video)
#10 Bus_Boy
Bus_Boy
  • 1,536 posts
Posted 17 January 2012 - 11:59 AM
Hi Alan,
Im not sure on what audio track it was on, in the BRP settings i have it set to 2ch down mix, the movie was "The book of Eli" Blu Ray title. It was sort of a hissing sound, but a lower deeper note, the dialouge was barely audible when it was making this noise.
I have since taken the pre-procesecor out, as it was dirtying up the signal going to the amp which i discovered when playing music. I tried both analoge in, and digital in using the procesecor's dac, and the sound was very un pleasant, a lot of break up i the midrange vocals were awful.
I've plugged the analouge outputs straight into the power amp, and the sound is a lot cleaner, it's actually quite enjoyable considering the amp's intended application (EP2000) The only problem now is i don't have any control of the volume unless i get up.
I'm thinking about buying the "Emotiva" dac, as i'm only decoding 2ch aside from the sub, and it has a built in pre stage with a volume on the remote.
#11 Bus_Boy
Bus_Boy
  • 1,536 posts
Posted 17 January 2012 - 12:02 PM
Emesbee,
I can't think of anything that would interfere, due to my shortage of available power outlets i only ever run what is nessacary .The amp was on the bottom shelf, BRP midway, and the prosecsor on the top shelf. I've always run all my cables in seperate directions away from each other. It's got me stumped.
#12 Monkeyboi
Monkeyboi
  • 2,878 posts
Posted 17 January 2012 - 02:58 PM
Hi Alan,
Hmmm.... sounds like that pre-pro might have a problem. In 99.9% of pre-pros the incoming bitstream (DD, dts etc) is converted to PCM before decoding to audio via the internal DACs. Why it's not detecting (or didn't detect) the bitstream type is anyone's guess, but the fact the sound is sounding obviously not good suggests to me it might be faulty.
The Emotiva XDA-1 2 channel DAC will handle all LPCM bitstreams to 24 bit / 192kHz except via the USB port which is choked at 48kHz sampling. Just remember to set the bitstream output on your BR player to PCM as the XDA-1 only decoded PCM data, not DD, dts etc.
Alan R.
#13 Telecine
Telecine
  • 2,817 posts
Posted 17 January 2012 - 03:38 PM
On your BDP, make sure that you have both the Dolby Digital and DTS settings correct for 2 channel down mix.
