Hello,
I'm relatively experienced with my Logitech 785 remote but after switching amps recently I'm quite frustrated that I can't seem to set up all activities (namely Foxtel, via HDMI into the VCR input). I'm not using ARC for TV duties as I want to use a PVR & this is why I'm not using the SAT TV input for Foxtel & using the VCR HDMI input instead.
So, the issue is that the amp will not switch direct to the Foxtel (VCR) input (it does for BD, DVD & SAT TV) & I can't find a command on either the supplied remote or the Logitech software? What's making this even more annoying is that while the AMP does show the source selection OSD when I activate the "Watch Foxtel" activity, the Logitech remote doesn't work with the left, right, up & down commands so I can't simply change the amp settings via the OSD.
Can anyone pls offer any advice on how I can fix this as this issue is really starting to annoy me & making it hard for me to simply enjoy the new amp (let alone the wife!!).
Cheers Matthew
Logitech Harmony 785 & New Marantz SR 6006
Started by mattjtaylor2809, Jan 09 2012 10:29 PM
3 replies to this topic
#1
Posted 09 January 2012 - 10:29 PM
2CH: Arcam A32 Amp + P35 Power Amp, Arcam CD192, Pro-Ject RPM5 with AT33PTG Cart, Jasmine LP2.0 SE Phono Stage, Ascension Summoner 863's speakers, AppleTV, FS Bravo 24/96 DP & TubeMagic D1 DAC. 5.1HT: Sony VW60 PJ, Marantz SR6006, Oppo 93 BDP, Dyn X32's. Cables: QED QT400 & Chord speaker cables with Graves Science & VDH D102 MkIII Hybrid interconnects.
#2
Posted 10 January 2012 - 08:06 AM
I had an issue with my Logitech around 'Game' on my processor. Turned out to be a dodgy code in the library. I just relearned the command from the local remote.
Main system: Oppo BD80, Dune HD - Meridian 621 -Meridian 861v6 with Sooloos endpoint - Meridian 5200 L/R/C - SGR Wingnut sub - Meridian DSP3200 rears
Family room: Meridian Sooloos - Meridian G68 - Meridian DSP3100 L/R
#3
Posted 10 January 2012 - 10:48 AM
try deleting all activities (not devices) and then reinstalling them. This usually fixes the problem.
Cheers Chewie
Cheers Chewie
#4
Posted 10 January 2012 - 06:29 PM
Thanks All.
The issue I have is whilst there is a HDMI VCR input, the actual Marantz remote doesn't have a button for this input? If I could get the logitech to learn the left, right, up & down commands I should be ok.
