What is the difference between dolby digital PCM and plain old dolby digital?
4 replies to this topic
#1 GAT474
GAT474
  • 1,271 posts
Posted 27 December 2011 - 07:05 AM
I gifted myself a couple of blurays for Christmas and noted one had the soundtrack options of dolby digital and dolby digital PCM. When I selected the PCM version my receiver showed it was receiving a signal via the multi channel input and the dolby digital version was as per normal. I'm using a Pana bluray player connected to a Denon 2310 via HDMI.
Does anyone know the difference between the two?
#2 davewantsmoore
davewantsmoore
    Nerd
  • 2,334 posts
  • State: TAS
Posted 27 December 2011 - 07:50 AM
DD = (lossy) encoded AC3 audio (decoded to PCM by your device)
DD PCM = not encoded in AC3 ... could be better ... depending on number of channels, bit rate, etc. compared to the above.
#3 joz
joz
    monsieur illuminati
  • 4,758 posts
Posted 27 December 2011 - 08:00 AM
From memory it will wil multiple channel PCM which will be at a much higher bitrate than plain vanilla DD.
It should sound better.
CHEERS THE JOZ!!
Peace love and mungbeans
Home of the Illuminators!!
#4 GAT474
GAT474
  • 1,271 posts
Posted 27 December 2011 - 12:38 PM
Thanks for the info. I take it that the PCM will still not be in the same league as DD HD or the DTS HD?
#5 davewantsmoore
davewantsmoore
    Nerd
  • 2,334 posts
  • State: TAS
Posted 27 December 2011 - 02:13 PM
Perhaps, but not necessarily. DD could be stereo or multi ... and DD PCM could be either 2 or more channels.
In the past, I've found it common for there to be a DD (AC3 surround) track, plus a PCM (lossless stereo) track .... AFAIK due that being what would fit on the media.
Again, probably but not necessarily. Both are lossless, however the bit/sample rates of either could AFAIK be anything .... The HD audio formats do generally offer the higher bit/sample rates when they are available of course.
