Prime for a D7000
30 replies to this topic
#1 proftournesol
proftournesol
    Moderator
  • Moderators
  • 5,649 posts
Posted 01 December 2011 - 04:04 PM
Earlier this year I bought a D7000 with an 18-200 Nikkor lens for my trip to Europe. Great range and I only needed 1 lens but it sure was a heavy camera. I want to buy a prime, anywhere from 28 to 50mm. Any recommendations? It'll be used for general photography when I want to travel lighter, portraits, landscapes, occasional macro.
regards Michael
Analog: Pink Triangle (totally Funked) Kuzma Stogi Reference, Soundsmith Straingauge Digital: modified CEC TL-51X transport , MacMini, Weiss Minerva DAC Tuner: Tandberg A3011 Preamp: Octave HP500se Speakers: ADAM Tensor Deltas | Vibration management: HRS | Cables: Argento Serenity, WSS Kabel, Nordost, Transparent, Cardas |
Second System Source: Cambridge Audio DV99 | Apple TV (Gen 1)| DACMagic | Amplification: Sugden A25 Speakers: ADAM HM2
#2 gainphile
gainphile
    dip∞le
  • 1,563 posts
Posted 01 December 2011 - 04:34 PM
I just got my nikkor 50mm 1.4 and it renewed my photography hobby!
My equipments have dissapeared....
http://gainphile.blogspot.com
#3 88pro
88pro
  • 211 posts
Posted 01 December 2011 - 06:55 PM
I would recommend 50mm 1.4 as well. 1.4 should get really good low light as well as lot of out of focus shots. But if you are really into people photography check out 85mm as well
Limited resources(money) means more research! (Corollary might not be true)
Getting back to more research
#4 Aslan
Aslan
  • 5,565 posts
  • State: TAS
Posted 01 December 2011 - 07:43 PM
Another one for the Nikkor 50 1.4. Its my favourite all purpose lens used extensively for portraits and also for stitched panorama landscape work.
FYI I also have the 85 1.8.........excellent for portraits but too long for landscapes
Don't forget Prof that the D7000 is a crop body so the 50 will effectively be 80 or thereabouts. I run my lenses on an FX sensored D700.
Edited by Aslan, 01 December 2011 - 07:46 PM.
Cheers, Andrew
#5 LuzArt
LuzArt
    Tube Pre + SS Power = Awesome
  • 790 posts
Posted 01 December 2011 - 07:46 PM
A 50mm is probably a good move. I have the 50/1.8 and although I hardly use it on my D700, it becomes 75mm on a D7000 so closer to being a portrait lens. The 1.8 is quite light and plasticy but also very cheap.
Good to see some other Nikon shooters here :)
Metrum Acoustics Octave Audiophilleo 2 (Aldi battery mod) Schiit Audio Lyr (Philips E88CC Miniwatt '66 SQ) AKG K701 Golden Jacks -10db Decware CSP2+ Rotel RB971 Yamaha RX-V1800 Vifa JV60 (Paul Spencer X'Overs) Vifa/HMV 2-way Subsonic XC-1 Yamaha YST-SW215 Sony S370 Pioneer DV655A WD HD TV
Luzart. Photography.
#6 Aslan
Aslan
  • 5,565 posts
  • State: TAS
Posted 01 December 2011 - 07:49 PM
You just reminded me I have a 50 1.8 laying around here that I don't use any more! A very good entry level 50 it is.
Cheers, Andrew
#7 LuzArt
LuzArt
  • 790 posts
Posted 01 December 2011 - 08:02 PM
Ahh just reread you post Andrew, you too have a D700. Isn't it a dream to use? We had our work Xmas do last week and I used the D700 with an SB800 and it just worked. Best metering I've had in a camera. +1 on the 85/1.8 too.
#8 gainphile
gainphile
    dip∞le
  • 1,563 posts
Posted 01 December 2011 - 08:15 PM
You have both 1.4 and 1.8, so was the 1.4 a good value?
I thought long and hard and bit the bullet for 1.4. I thought it's soft wide opened but very nice at 2.2
#9 JA
JA
    Moderator
  • Moderators
  • 3,962 posts
Posted 01 December 2011 - 08:21 PM
The 50mm/1.4 and 85mm/1.8, both already recommended are both excellent for available light photogrsphy, indoors at concerts when no flash is allowed. They will also allow you pop the subject out of the background more easily with their shallow depth of field capabilities in portraiture. They could also be used with extension tubes, close up lenses for more extreme macro.
Along with the excellent 18-200 you already have, you won't need anything else unless you feel like a bit of wildlife photography, surveillance or astro.
Best
JA
Edited by JA, 01 December 2011 - 08:28 PM.
The GFC was nothing compared to what we will see in the next 1-2 years....
Eliminate debt, Cash up, maybe even gold/silver-up and hunker down.
Sell high, buy low.
Evidence and knowledge is out there.... Let discovery be your reward
Have Fun
JA
Nessun Dorma @ 12yoPosted Image
#10 Spearmint
Spearmint
  • 3,105 posts
Posted 01 December 2011 - 08:30 PM
I would check out the EXIF data from your photos you generally take when on holiday.
The reason I say this, when we were on our last big trip the majority of my images were taken under 50mm
Also IMO for a crop camera I'd probably opt for a 35mm lens, which will get you close to a 50mm lens equivalent used on a FF body.
Cheers;
Minty
"Sometimes it is easier to ask forgiveness than to get permission... "
#11 proftournesol
proftournesol
    Moderator
  • Moderators
  • 5,649 posts
Posted 01 December 2011 - 08:35 PM
so how about a Nikon AF-S DX Nikkor 35mm f1.8G ?
regards Michael
#12 houdinifangs
houdinifangs
    Overlord
  • 2,112 posts
Posted 01 December 2011 - 08:40 PM
50mm lenses are great outside and for portraits. If you intend to take many interiors - say at a GTG, a 35mm or even 28mm is much better. Another option is a 85mm+ Macro lens which double for portraits etc. Macro lens + Ring Flash = fun
Let the Wookie win
#13 Spearmint
Spearmint
  • 3,105 posts
Posted 01 December 2011 - 08:45 PM
Check this page out for another opinion about female portraits and the 50mm lens
Cheers;
Minty
#14 Spearmint
Spearmint
  • 3,105 posts
Posted 01 December 2011 - 08:47 PM
I'm not sure, there should be a number of reviews and examples from this lens around the net.
I mostly use zoom lenses, but do have a couple of primes for different occasions.
Cheers;
Minty
#15 ehtcom
ehtcom
  • 2,750 posts
Posted 01 December 2011 - 09:03 PM
For lighter travel, I'm considering a 16-85mm DX.
Review here.
After lugging 12-24mm f4, 17-55mm f2.8 and 80-200mm f2.8 around on our last holiday, my back reckons the little 16-85 is looking pretty good :)
Cheers, Earle.
EHT Communications P/L
Trading as: Weston Acoustics
www.westonacoustics.com
email: ehtcom@bigpond.net.au
"The bitterness of poor quality remains long after the sweetness of low price is forgotten." - Benjamin Franklin
#16 ehtcom
ehtcom
  • 2,750 posts
Posted 01 December 2011 - 09:12 PM
Another lens comes to mind, the AF-S DX Micro Nikkor 40mm F2.8 macro would make for a nice compact setup.
#17 kunalraiker
kunalraiker
  • 1,206 posts
Posted 01 December 2011 - 09:30 PM
I purchased the 50mm 1.8 when I got my setup for D7000, was chip as chips payed like $60.00, my wife reckons its the best lens we have and I do have some expensive ones !
#18 Aslan
Aslan
  • 5,565 posts
  • State: TAS
Posted 01 December 2011 - 09:39 PM
A great option Michael..................being stuck in FX land, I hadn't considered the DX specific models.............yes, it would be a ripper with your body.
Cheers, Andrew
#19 Aslan
Aslan
  • 5,565 posts
  • State: TAS
Posted 01 December 2011 - 09:41 PM
Yes, the 1.4 is a tad soft wide open - but that's a plus for female portraits in some ways. It's sweet spot is between 2.2 and 3.5 where it nails it!
Cheers, Andrew
#20 Aslan
Aslan
  • 5,565 posts
  • State: TAS
Posted 01 December 2011 - 09:44 PM
I love the D700 mate, its low light capability is staggering, especially with large aperture lenses.
I have:
50 f1.4
50 f1.8
85 f1.8
105 f2.8 macro
70-200 f2.8 zoom
Just have to save up the pennies for the new 35mm FX 1.4, but geez it's expensive.
Cheers, Andrew
#21 cmcook
cmcook
  • 186 posts
Posted 02 December 2011 - 12:15 PM
SWMBO recently bought one to use on her D5100 and she's pretty happy with it. Interesting to note that Nikon lenses have a worldwide warranty.... Her's was ordered from the UK so no VAT charged either. She's also got an old 50mm f1.8 lens which only works with manual focus (or maybe it was only ever manual anyway) - these are really cheap as so many were made but still good quality.
#22 ehtcom
ehtcom
  • 2,750 posts
Posted 02 December 2011 - 01:36 PM
Most likely an AF lens, the D5100 doesn't have a build in focus drive, so you need to get AF-S lens for auto focus. The "s" stands for Silent wave motor.
Cheers, Earle.
#23 cmcook
cmcook
  • 186 posts
Posted 02 December 2011 - 08:49 PM
It is indeed an AF lens. I thought it was but had a nagging doubt when i was posting that.
Her photos are here if anyone is interested:
http://www.rachelmor...et/photography/
and
http://www.rachelmorrison.net/52snaps/
There will be some photos taken with both of those lenses on there.
#24 gainphile
gainphile
    dip∞le
  • 1,563 posts
Posted 02 December 2011 - 08:53 PM
Oh my ... !
#25 ehtcom
ehtcom
  • 2,750 posts
Posted 02 December 2011 - 09:11 PM
and
Very nice.
#26 buddyev
buddyev
  • 374 posts
Posted 07 December 2011 - 12:11 PM
I have a 16-85 and its a cracker. Its not the fastest or the lightest, but as for construction and sharpness and nice focal range I reckon its the pick of the dx zooms.
Russ
Review here.
After lugging 12-24mm f4, 17-55mm f2.8 and 80-200mm f2.8 around on our last holiday, my back reckons the little 16-85 is looking pretty good :P
Cheers, Earle.
Study: Rega P3 24, Ortofon 2m blue, Graham Slee Gram amp 2se, Rega Dac, Rega Apollo R cdp, Arcam A90 & P90 bi-amping, B&W CDM 7, Atlas Equator interconnects
Lounge: iMac, iTunes,  Apple TV, Eastern Electric MiniMax DAC, Arcam Delta 290, Orpheus Apollo, Quad 12l
#27 ehtcom
ehtcom
  • 2,750 posts
Posted 07 December 2011 - 02:37 PM
Russ
Thanks Russ.
It will now be my next "camera gear" purchase.
Cheers, Earle.
#28 proftournesol
proftournesol
    Moderator
  • Moderators
  • 5,649 posts
Posted 25 January 2012 - 07:05 PM
OK, I ended up getting a Nikkor 50mm f/1.8D. Cheap, sharp, fun:)
regards Michael
#29 blackfox
blackfox
  • 577 posts
Posted 11 February 2012 - 01:54 AM
Awesome. I Personally have the Nikkor 50mm f1.8D on my D7000
Why did only one person recommend the 35mm prime? Thats my next purchase!
Since ppl are listing their lenses:
Nikkor 50mm f1.8D
18-70mm f/3.5-4.5 (d70 kit lens)
18-105mm nikon kit lens
Right now wanting to buy an 80-200mm ED f2.8 and a wide lens maybe 12-24 and most definitely a 35mm prime!
Guys is it really worth upgrading to the 50mm f1.4 if i have the f1.8?
Chief Editor for downunderaudio.com
Also on Twitter
And Facebook
#30 Spearmint
Spearmint
  • 3,105 posts
Posted 11 February 2012 - 10:18 AM
Nikkor 50mm f1.8D
If you are wanting an equivalent of a 50mm with a crop sensor then the 35mm would give you the closest to the same angle of view.
Cheers;
Minty
#31 Aslan
Aslan
  • 5,565 posts
  • State: TAS
Posted 11 February 2012 - 12:56 PM
Nikkor 50mm f1.8D
Mate, the Nikkor 50 f1.4 is a VASTLY superior lens to the 1.8. Chalk and cheese, go for it!
Cheers, Andrew
