Trevor Whittle Posted November 18, 2011 Share Posted November 18, 2011 Hi Does anyone have an opinion on whether the addition of a super tweeter would improve the sound of my Altec 19s? Any suggestions? Thanks Trev Link to comment Share on other sites More sharing options...
VanArn Posted November 19, 2011 Share Posted November 19, 2011 As the Altec Model 19 has a sensitivity of 99dB SPL for a one Watt input,a horn loaded tweeter would best suit the application.Certainly with the V.O.T.T. models, Altec's it was worthwhile to fit a JBL ring or slot radiator to extend the high freq's. The Model 19 should have the tangerine phase plug(802-8G driver) unit fitted and the improvement may not be as effective in this case. Link to comment Share on other sites More sharing options...
Trevor Whittle Posted November 19, 2011 Author Share Posted November 19, 2011 Thanks for your response. I've read that the addition of a super tweeter add a dimension of "space" to most speakers, even though the frequencies cannot be detected by ordinary ears. As the Altec Model 19 has a sensitivity of 99dB SPL for a one Watt input,a horn loaded tweeter would best suit the application.Certainly with the V.O.T.T. models, Altec's it was worthwhile to fit a JBL ring or slot radiator to extend the high freq's. The Model 19 should have the tangerine phase plug(802-8G driver) unit fitted and the improvement may not be as effective in this case. Link to comment Share on other sites More sharing options...
