iMac for Dummies Thread
5 replies to this topic
#1 vmhf
vmhf
  • 1,348 posts
Posted 06 November 2011 - 08:58 AM
I am a real dummy when it comes to computers so thought would start this thread off with a silly question.
I am trying to set my default screen brightness level to min. Every time I turn my iMac off and then on it resets to maximum level and I have to turn it down to min. I usually use the hot keys to adjust the level but know in System Preferences you can adjust the level there too. But could not find a default tab.
#2 Willco
Willco
  • 939 posts
Posted 06 November 2011 - 10:03 AM
You could try Pref's> Display> Color> untick box "Auto adjust brightness/etc"
Will
#3 vmhf
vmhf
  • 1,348 posts
Posted 06 November 2011 - 10:33 AM
Thanks Will. Just tried that but there appears to be no 'Auto adjust brightness' box showing.
Might get my 3 year old niece to help me out!
#4 proftournesol
proftournesol
    Moderator
  • Moderators
  • 5,693 posts
Posted 06 November 2011 - 12:23 PM
Have a look on your keyboard F keys, do F1 and F2 also have sun symbols on them? If so, that will adjust brightness
regards Michael
Analog: Pink Triangle (totally Funked) Kuzma Stogi Reference, Soundsmith Straingauge Digital: modified CEC TL-51X transport , MacMini, Weiss Minerva DAC Tuner: Tandberg A3011 Preamp: Octave HP500se Speakers: ADAM Tensor Deltas | Vibration management: HRS | Cables: Argento Serenity, WSS Kabel, Nordost, Transparent, Cardas |
Second System Source: Cambridge Audio DV99 | Apple TV (Gen 1)| DACMagic | Amplification: Sugden A25 Speakers: ADAM HM2
#5 rantan
rantan
    dazed & confused
  • 2,565 posts
Posted 06 November 2011 - 01:33 PM
Hi Victor.
I agree with the Prof. I always adjust the screen brightness by the F1 and F2 keys on the Mac keyboard.
Easy peasy.;)
#6 planet10
planet10
    Frugal-phile (tm)
  • 833 posts
Posted 06 November 2011 - 04:18 PM
You can try making a colour profile with the brightness turned down (Displays> Color Tab)
dave
community sites: http://www.frugal-horn.com/ http://www.t-linespeakers.org/ http://frugal-phile.com/
member of planet10-hifi, purveyor of EnABLed speaker drivers for the diyer, bespoke loudspeakers, and more
