The Best budget Bluray Player around?
22 replies to this topic
#1 aad_ht
aad_ht
  • 389 posts
Posted 28 September 2011 - 03:38 PM
Hey all,
I'm off to buy a bluray player tonight, I was just wondering if someone could recommend one?
Likelyhood is it will be under the $170 mark.
I am happy to get something cheaper. I may head down to JB Hifi for one if they have any good specials too.
Must buy tron hehe
Cycling Motivation.com.au - Pedal Powered Passion
#2 Yamaha Man
Yamaha Man
    Yamaha as in NS-1000 not R1.
  • 1,804 posts
Posted 28 September 2011 - 04:13 PM
2nd hand PS3 maybe?
Good judgement comes from experience and a lot of that comes from bad judgement.
#3 Dr X
Dr X
  • Banned
  • 2,203 posts
  • State: NT
Posted 28 September 2011 - 04:42 PM
I bought the Sony BDPS380 for a bit less than $170 recently. It has co-axial output (no optical) and can play SACD's.
#4 cableconnoisseur
cableconnoisseur
    ** Serial Tweaker **
  • 2,537 posts
Posted 28 September 2011 - 06:11 PM
JB have some decent specials on at the moment.
With your budget, you should be able to get something from Sony, Panasonic, Samsung, LG et al.
Let us know what you end up with.
Russ.
#5 aad_ht
aad_ht
  • 389 posts
Posted 28 September 2011 - 09:01 PM
Thanks very much once again for all your help. I did end up going to JB.
I ended up going for a Samsung BDD5300 BluRay Player, it performs beautifully.
I did also plurge a bit, I purchased the full star wars bluray Collection which looks fantastic even on my Soniq 42" Full HD Screen hehe.
#6 cableconnoisseur
cableconnoisseur
  • 2,537 posts
Posted 29 September 2011 - 05:52 AM
Nice to see a Happy Shopper.
Hope you also bought yourself a decent HDMI cable?
Russ.
#7 aad_ht
aad_ht
  • 389 posts
Posted 29 September 2011 - 07:30 AM
Russ.
I guess thats where things can get a bit sketchy haha. The unit feels strong enough but i'm not so sure on the quality. It was about $36 from JB-hifi. (so probably not a decent one lol)
#8 ronascension
ronascension
  • 310 posts
Posted 03 October 2011 - 05:20 PM
+1 Sony S380 Bluray Player and Starwars Boxset in Bluray.
Ron.
AUDIO: Marantz SR7002 AV. LR Speakers: AS Monitor 823PH. Marantz CD6003 & Laptop>V-Link for FLAC/WAV. HT: Yamaha RX-V663. LR: AS Monitor 612PR, C: AS 442PS, SLSR: Yamaha. WDTV, Sony S380 & S760 Bluray. TV: 40" Samsung A750 LCD.
#9 Jliang70
Jliang70
  • 461 posts
Posted 04 October 2011 - 01:01 PM
Has anyone here try the Toshiba region free bluray player ?
#10 aad_ht
aad_ht
  • 389 posts
Posted 04 October 2011 - 02:54 PM
Any particular part number for that toshiba one?
You could always try the samsung one, its easy to make it region free :(
#11 Pete54
Pete54
  • 22 posts
Posted 05 October 2011 - 12:36 AM
Another vote for the Sony S380. I picked one up from JB recently for about $150.
For a 1m cable run, you won't notice any difference in picture quality between a $20 cable or a $200 cable. Everyone knows expensive HDMI cables are just snake oil
Edited by Pete54, 05 October 2011 - 12:40 AM.
#12 Jliang70
Jliang70
  • 461 posts
Posted 05 October 2011 - 03:54 PM
You could always try the samsung one, its easy to make it region free :)
The Toshiba model I am askng about is BDX3200 bluray player, it goes for about $175
It is region free for both bluray and dvd with modification, it is also a 3D bluray player.
#13 :) al
:) al
  • 1,670 posts
Posted 05 October 2011 - 07:05 PM
I believe the soniq from JB cant be beat for the money. know a few using it without issue. and it is region out the box, which is a real bonus !
"Technology is a drug. We can't get enough of it."
#14 pchan
pchan
    Glorified Cleaner
  • 1,978 posts
Posted 16 October 2011 - 08:50 AM
+1
I have a s470 and a s580 Sony bpd, I wasn't planning to go Sony because of there reputation on laser quality, It may not be region free for bluray but they play everything and no issues laser readings compared to previous models. The samsung I have has reading problems as well!!!
#15 LogicprObe
  • 8,900 posts
Posted 16 October 2011 - 08:57 AM
I have the Sony 370..............it's a great player but I've yet to play a BluRay on it!
#16 Bus_Boy
Bus_Boy
  • 1,536 posts
Posted 16 October 2011 - 04:27 PM
I too have the 370, and it get's a lot of use. I haven't compared it to any other players, because at the time it was pretty much the cheapest BRP from a well known manafactuer.
Edited by Bus_Boy, 16 October 2011 - 04:46 PM.
#17 LogicprObe
  • 8,900 posts
Posted 16 October 2011 - 05:31 PM
Best component under two hundred bucks that I ever bought!
#18 pchan
pchan
    Glorified Cleaner
  • 1,978 posts
Posted 17 October 2011 - 04:52 AM
If yu have a 1080 panel, yu wont be disappointed on the sony range, they are value for money, only bad points: slightly noisy spinner and you cant select tracks direclty, must use forward/reverse to find tracks on CD.
#19 LHC
LHC
  • 406 posts
Posted 29 October 2011 - 06:22 PM
The Sony 370 is indeed an excellent value for money player, but it is not true that it can play everything. I have a Sony music DVD (von Karajan plays Four Seasons) that it can't play. Not a fault of the disc as it plays fine on an Oppo 980H.
Prior to the Sony I bought a Samsung BD-C6900 on run-out price, just a little more than $200. The Samsung was a significant step up on the 370 in terms of picture and sound. On Blu-ray material the picture difference was not big; but for upscaling DVD the Samsung was heaps better, smoother edges and more vibrant colour. Audio wise the 6900 created a wider and much deeper sound stage, and music has more weight and presence. In comparsion the Sony was a bit hard, more forward and congested. Unfortunately the Samsung skips on many of our imported DVD, and we had no choice but returned it for a 370.
#20 LogicprObe
  • 8,900 posts
Posted 29 October 2011 - 06:32 PM
I mainly got mine to play avi files off USB drives, DVD's and SACD's........and the occasional music CD.
I thought it was great value for $180!
#21 markm1111
markm1111
  • 1,171 posts
Posted 23 November 2011 - 02:38 PM
Dick Smith has Sony S380, Panasonic BD75GN, and LG Multiformat all for $118 incl delivery at the moment.
Which one would you pick?
Stereo: SB Touch (Bolder), Welborn psu, Bel Canto Dac3, Pre3, Ref1000 MKII's, Lenehan ML-1 Ultras, Rel 505 HT: Add Oppo BDP-95, iQ2, Onkyo 875, ML-1 centre, Yam In-Ceilings
Study: SB Transporter, Burson PI-160, ML-1 PlusR's, Leben CS-300XS, 47 Labs Lens Head: Add Violectric HPA V200, T1/K702/ATH-W5000/AH-D7000/DT770 600
Cables: Jungson Silver XLR, Audio Art Cable IC-3s, Black Cat Veloce digital IC, Lenehan Ribbontek SCs,Consonance/Zu/stock power cables, Consonance power filters
#22 TigerScent
TigerScent
  • 623 posts
Posted 24 November 2011 - 10:01 AM
I am using a Sony PS3 (old version) for Blu-ray/DVD's, and like the fact that it upsamples, and doubles up for playing games. Seems to be pretty good value all round.
If I had a choice for a dedicated player, I would get the Oppo with 7.1 analogue input option...
#23 arrow224
arrow224
  • 155 posts
Posted 24 November 2011 - 01:41 PM
I would go the S380. Biased as I have an S370, but at least the S380 can do SACD over HDMI, whereas the others cannot.
ASCII a stupid question, get a stupid ANSI!
<-------- The information went data way -------->
