* * * * - 1 votes
SACD DFF file extraction/backups
918 replies to this topic
#1 ozmillsy
ozmillsy
  • 3,103 posts
Posted 08 June 2011 - 09:57 AM
Hi Guys,
After playing around with digital audio de-embedding/capturing for sacd playback & backups, (click), I've come to the conclusion that this method is subject to the quality of the DSD2PCM conversion step in the players used for the process - and that in the 3 players I've tried, the converter chips were a compromise.
I'm now focussing my energy on extracting DFF files off the SACD discs. This will give me a straight file copy of the music files. I can then do what I like with them. Convert them to PCM using software then playback using my current solutions.
The biggest benefit is having backups of the music/discs, many of which are long OOP.
There is a solution under development to do this extraction, it's called sacd-ripper. Information can be found here.... click; sacd-ripper
To this point sacd-ripper has been a Linux app, which needed a Linux O/S installed onto a suitable PS3. But the project is now developing a native PS3 app, that will execute from within the GameOS PS3 operating system (as long as it has the LV1 patch).
This thread will document the process of achieving backups of my sacd's, by using sacd-ripper (native ps3 app version).
Update @ 18-June: Sacd ripping using a PS3 is now working, using a pre-release version of sacd-ripper (taking iso images of the sacd layer is stable). The details on what is required are;
1) Obtain a sacd capable PS3. For the suitable PS3 model numbers click here- PS3 compatibility list
2) Make sure the PS3 is at firmware version 3.55 or less (versions >=3.56 cant be rolled back, and cant be used for sacd-ripper)
3) Apply the OtherOS custom firmware update, required for sacd-ripper. OtherOS is available from here- http://gitbrew.org/otheros/
- Notes; there have been some reports of OtherOS bricking some players, use at your own risk.
,,,instructions for applying OtherOS is documented here- Click
,,,note, the downloaded OtherOS firmware image will need to be renamed to PS3UPDAT.PUP in between steps 4/5 in the documented process above.
4) Obtain the PS3 sacd keys and load them into the root of a USB stick/drive, available here- PS3 keys
5) Obtain the latest SACD-RIPPER package and load it into the root of a USB stick/drive. Not currently available in pre-compiled form, information can be found here- http://code.google.com/p/sacd-ripper/
6) Make sure you have a USB stick/drive that has enough capacity to store the rips (4gb minimum), needs to be formatted as FAT32.
sacd-ripper download link:
Update @ 11-July: compiled sacd-ripper r252 pkg (stable beta release) can be downloaded here; Click-post #266
scarletbook download link:
Update @ 9-July, compiled scarletbook release r252 available here; Click-post #245
Info: scarletbook.exe is a Windows application that can be used to extract individual tracks out of an ISO image that was taken by sacd-ripper. This utility is useful, if you want to minimise processing time on your PS3. The older PS3's are known to have overheating issues leading to the dreaded YLOD failure. In my case, I intend to minimise the usage of my PS3 by restricting it to taking ISO images only, and then using scarletbook on my pc to extract the tracks and convert them to PCM(wav) files.
SACD ISO Decoding in Foobar:
Update @ 17-July, SACD ISO images created by sacd-ripper can now be played back in Foobar natively, with no file extractions or conversions required using a plugin called "Super Audio CD Decoder".
Download link here; Click-post #307
Reference list of sacd players that can playback SACD-r's (ie: sacd iso images written to a dvd-r disc)
Play:
Cambridge Audio Azur 650BD
Denon DVD-2910
Denon DVD-3910
Marantz UD5005
NAD M5
NAD T585
OPPO BDP-80
OPPO BDP-83
OPPO BDP-83SE
OPPO BDP-93
OPPO BDP-95
Shanling SCD300
Sony BDP-S370
Sony BDP-S380
Sony BDP-S570
Sony BDP-S870
Sony BDP-S970
Yamaha BD-S1067
Do not play:
Accuphase DP-100
Ayre C-5xeMP
Denon DVD-1930
Denon DVD-1940
Denon DVD-2930
Integra DPS-6.9
Marantz DV-6001
Marantz SA-11S2
Marantz SA-15S1
Marantz SA-7001
Onkyo DV-SP504
Oppo DV-980H
Parasound D3
Philips DVP-9000S
Pioneer DV-565A
Pioneer DV-575A
Pioneer DV-600AV
Pioneer DV-610AV
Pioneer DV-656A
Pioneer DV-696AV
Pioneer DV-757Ai
Pioneer DV-989AVi
Pioneer DV-LX50
Sherwood Newcastle SD-871
Sony DVP-NS900V
Sony PlayStation3
Yamaha CD-S2000
Yamaha DVD-S1800
Yamaha DVD-S2700
Play after the firmware update:
Samsung HD745/945/950
Samsung HD841/941
Edited by ozmillsy, 18 July 2011 - 10:02 AM.
Digital Rig: Marantz CD94 (i2s) -> KillerDAC(click)
Analog Rig: Luxman PD-310 / Syrinx PU3 / DucKingwood 103r -> Eastern Electric Minimax Phono
Into: AudioNote M3 Pre -> Radford STA15 S3 -> Tannoy Monitor Golds (15's)
#2 ozmillsy
ozmillsy
  • 3,103 posts
Posted 08 June 2011 - 10:04 AM
The first step on this journey to rip SACD's, is to find a suitable PS3.
I've been loaned a PS3 with firmware 3.56 by a fellow forum member, and have been granted the license to try and rollback the firmware to an earlier version. No mean feat. There are plenty of instructions on the internet, some are bogus.
Has anyone got any experience rolling back their PS3 firmware?
The author of OtherOS has produced a youtube clip, which guides the user through loading the OtherOS custom firmware, and subsequently Linux (which his firmware is usually used for). This clip seems to suggest that formatting the PS3 harddrive will let the user then load their firmware of choice. But it's not that clear. I'm not sure if it's just wiping and starting again with the same firmware level (#), or whether it will let me roll back to an earlier version. Here's the clip....
Upu6X3m8rV0
Has anyone on SNA done this? Can you offer any advise?
Edit: I've since learned that the method in this clip cannot be used to rollback the firmware from 3.56 to an earlier version.
Edited by ozmillsy, 13 July 2011 - 10:33 AM.
#3 ctle
ctle
  • 51 posts
Posted 08 June 2011 - 10:22 AM
Hi oz, downgrade the firmware to 3.55 is currently not possible.
My son accidentally upgraded my PS3 to 3.60 last month so I'm waiting for the release of a new OtherOS version.
#4 ozmillsy
ozmillsy
  • 3,103 posts
Posted 08 June 2011 - 10:30 AM
I've heard that is the case if the player has been upgraded to 3.60, as they locked it down further. But I'm holding out hope that I can still rollback from 3.56.
It's more complicated than that, unfortunately. The 3.60 version of OtherOS is 1 thing. The other problem, is that Sony changed the sacd keys on the PS3 for firmware 3.60.
sacd-ripper only works with the older PS3 keys, available here; click
The keys for 3.60 are not available at this point, as I understand.
#5 KenTripp
KenTripp
  • 1,174 posts
Posted 08 June 2011 - 10:43 AM
I do admire your perseverance and will follow your latest efforts with great interest.
#6 ctle
ctle
  • 51 posts
Posted 08 June 2011 - 10:52 AM
Thanks for the info!
I don't think downgrade from 3.56 to 3.55 is currently possible.
#7 ozmillsy
ozmillsy
  • 3,103 posts
Posted 08 June 2011 - 10:59 AM
It's not the first time I've been told that. You maybe right. I havent thrown in the towel on this player (yet).
#8 collector
collector
  • 8 posts
Posted 08 June 2011 - 11:03 AM
Is the correct PS3 the 60Gb version with the CECHC serial number?
#9 ozmillsy
ozmillsy
  • 3,103 posts
Posted 08 June 2011 - 11:24 AM
CECHA00 is the code on the end of the serial number sticker.
#10 jamesg11
jamesg11
  • 264 posts
Posted 08 June 2011 - 09:09 PM
What's the rough going rate $AU, if you can locate the right PS3?
naquadria+cawsey power cond+cawsey power leads+cawsey interconnects>cyrus cdxtse>cyrus dacx+psxr/ mytek dsd dac>naquadria v2 passive pre>xlr>naquadria lucien+zpm power>chord odyssey 4/cawsey speakon-biwire>elac fs249be (wiring mods);macmini+16gb ram +ssd+2tb hd/cambridge 650bd>cyrus dacx/mytek dsd dac>
#11 ozmillsy
ozmillsy
  • 3,103 posts
Posted 09 June 2011 - 02:30 PM
Dont know. Do you have 1 to sell, or are you looking to buy?
#12 nfi42
nfi42
  • 930 posts
Posted 09 June 2011 - 02:39 PM
Just curious if this process allows you extract an SACD iso image?
Joe
Ambience Reference 1800 Hybrid Ribbons, Ayre V-5xe Power Amplifier, Ayre K-5xeMP Pre Amplifier, Ayre C-5xeMP CD/SACD/DVDA player, Dynavector P-75 mkII Phono Amp, Dynavector DV-17D3 Cartridge, Well Tempered Turntable, Nordost Heimdall cables, Pioneer LX508A 50inch Plasma, Oppo BDP83 (with region free mod) blu-ray player, Thor PS10 Power Supply.
#13 jamesg11
jamesg11
  • 264 posts
Posted 09 June 2011 - 07:39 PM
To buy! Audiocircle has just started a thread, with a key player stepping out - http://www.audiocirc...p?topic=95396.0
#14 ozmillsy
ozmillsy
  • 3,103 posts
Posted 09 June 2011 - 10:07 PM
Yes it will, as I understand, sacd-ripper will let you take an iso image of the sacd layer, or extract the individual DFF files. I believe it will have menu options to choose. Quoted from the author......
The user interface is simple but it will allow you to dump DSDIFF, DSF, ISO in both multi and stereo channels and it also creates the necessary ID3 tags so your track/disc information is not lost.
I will confirm this once I get it working.
Need to roll back the firmware first, if I can?
Edited by ozmillsy, 09 June 2011 - 10:11 PM.
#15 nfi42
nfi42
  • 930 posts
Posted 09 June 2011 - 11:13 PM
Thanks Millsy. I was just curious if my SACD player would be capable of playing an SACD iso burnt to recordable DVD.
Joe
#16 damohpi
damohpi
  • 583 posts
Posted 10 June 2011 - 09:57 AM
subscribing :thumb: I've was following the project on google-code but got the impression it was vapour ware so removed the feed, anyway it's interesting to see it has starting to be updated again
my ps3 is still on 3.41 so will try find time over the weekend to upgrade to the 3.55 cfw with otheros and get it running, updating my psl1ght install now so I can compile the packages
#17 ozmillsy
ozmillsy
  • 3,103 posts
Posted 10 June 2011 - 04:46 PM
Cool ! Cant wait to hear about your progress with it.
#18 damohpi
damohpi
  • 583 posts
Posted 10 June 2011 - 10:59 PM
got everything compiled, will install the firmware tomorrow and try it out
#19 tricka
tricka
    Suspended
  • Banned
  • 1,812 posts
Posted 11 June 2011 - 09:17 AM
Thanks OM and others for this thread. I've got a bunch of SACD's that I'd love to rip the DIFF layer off.
#20 LogicprObe
  • 8,899 posts
Posted 11 June 2011 - 09:41 AM
I'm really surprised that no one has bothered to hack up a computer solution yet.
#21 DoggieHowser
DoggieHowser
  • 2,205 posts
Posted 11 June 2011 - 11:08 AM
If you can find a computer drive that reads SACDs. I'm sure they'll be all over it ;)
#22 LogicprObe
  • 8,899 posts
Posted 11 June 2011 - 12:27 PM
I reckon it wouldn't be that hard to build and I reckon Sony legal would be all over you in a flash!
#23 ozmillsy
ozmillsy
  • 3,103 posts
Posted 11 June 2011 - 06:47 PM
I understand it's being worked on........
#24 LogicprObe
  • 8,899 posts
Posted 11 June 2011 - 06:58 PM
Yeah.......they cracked ordinary CD's in a flash because they were so popular.
If DSD was as popular, we would have had it six months after release!
#25 ozmillsy
ozmillsy
  • 3,103 posts
Posted 11 June 2011 - 08:52 PM
You make a fair point. But CD never had any kind of security applied to it, like SACD's have had - it's got 2 layers of copy protection, hardware where only properly licensed drives can read the discs, and software where the data is encrypted.
But yeah, I tend to agree, that if sacd's were more prevalent, then it wouldve been cracked long ago.
The work being done, is to try and get any regular pc dvd player to be able to read sacd's, and then extract/copy etc. I'm not holding my breath, but remain hopeful.
Until then, I'm pursuing this PS3 method.
#26 damohpi
damohpi
  • 583 posts
Posted 11 June 2011 - 08:53 PM
"cracked ordinary CD's" ? ...
anyway, epic fail - installed 3.55 firmware, sacd-ripper package, launched ok, but every disc I inserted came back with "sacd not recognised" - or something along those lines... ran the ps3 model detection pkg and "sacd not supported" on the drive..
I completely forgot my original 60gb PS3 was replaced with a 80gb model when our place was robbed a couple of years back..
oh well, time to find a 60gb model
#27 LogicprObe
  • 8,899 posts
Posted 11 June 2011 - 09:06 PM
What I meant was that there are plenty of apps, mods, conversions and all manner of things for CD........but very little for SACD.
They are even ripping BluRay like there no tomorrow as well!
#28 ozmillsy
ozmillsy
  • 3,103 posts
Posted 11 June 2011 - 09:43 PM
[sighs] this just adds more fuel to the fire, 1 way or another, I will get this ps3 ripping method going.......
#29 tricka
tricka
    Suspended
  • Banned
  • 1,812 posts
Posted 11 June 2011 - 11:18 PM
I have to say..why not just a sacd player?
#30 ozmillsy
ozmillsy
  • 3,103 posts
Posted 12 June 2011 - 07:50 AM
Primary driver is to have backups of my OOP sacd's that are really difficult to replace.
Once I have the data backed up and extracted, I can do other things with it. Like convert it, and play it back on other (better sounding) non-sacd based hardware.
#31 tricka
tricka
    Suspended
  • Banned
  • 1,812 posts
Posted 12 June 2011 - 09:30 AM
Ahhh...now that makes sense OzMillsy. Good idea. a 24/96 version would be great to have.
Thanks for investigating this.
#32 ozmillsy
ozmillsy
  • 3,103 posts
Posted 12 June 2011 - 09:49 AM
Rolling back the firmware of this PS3 in my possesion appears to be a dead end. I'm going to have to find a different PS3 for the task.
#33 LogicprObe
  • 8,899 posts
Posted 12 June 2011 - 09:51 AM
With me, it's more about playing the songs I want, in the order I want (or randomly even) without having to change discs, etc.
#34 ozmillsy
ozmillsy
  • 3,103 posts
Posted 16 June 2011 - 08:14 PM
Progress. Baby steps.
I've bought a second hand PS3 that has 3.55 firmware. It arrived today. It powers up, plays back sacd's (it's a CECHC02 model), and reports 3.55 firmware.
Now to load the custom (OtherOS) firmware......
#35 LogicprObe
  • 8,899 posts
Posted 16 June 2011 - 08:22 PM
I'm following your progress.
#36 ozmillsy
ozmillsy
  • 3,103 posts
Posted 16 June 2011 - 08:58 PM
OtherOS custom firmware loaded.....
#37 ozmillsy
ozmillsy
  • 3,103 posts
Posted 16 June 2011 - 09:06 PM
#38 ozmillsy
ozmillsy
  • 3,103 posts
Posted 16 June 2011 - 09:07 PM
#39 ozmillsy
ozmillsy
  • 3,103 posts
Posted 16 June 2011 - 09:08 PM
sorry about the flash, but if I dont use it, the snaps from this camera goes all fuzzy.
#40 tricka
tricka
    Suspended
  • Banned
  • 1,812 posts
awesome - well done.
#41 ozmillsy
ozmillsy
  • 3,103 posts
Posted 16 June 2011 - 09:13 PM
first ever sample dff file (by me) coming shortly, just to give people a looksy.
#42 damohpi
damohpi
  • 583 posts
Posted 16 June 2011 - 09:28 PM
Great stuff oz..
#43 ctle
ctle
  • 51 posts
Posted 16 June 2011 - 09:34 PM
Well done oz! How long would it take to rip a SACD?
#44 LogicprObe
  • 8,899 posts
Posted 16 June 2011 - 09:42 PM
Ha!
Well done mate!
#45 ozmillsy
ozmillsy
  • 3,103 posts
Posted 16 June 2011 - 09:51 PM
It's taking awhile, it's fairly slow, I'm only getting about 0.4M per second. The readme file for sacd-ripper says it should be about 0.9M per second, maybe there are some scratches on this first sacd?? This is a pre-release version, so,,, who knows. I'm writing to the usb stick, that might have something to do with the speed??
From the readme.....
There seems to be an SACD BluRay read speed limit that sets the maximum read speed to 2.6MB/sec,
yes I agree, this is slow! But DST decoding is even slower.. The PS3 GameOS has 6 SPUs available
for user operations. SACD-Ripper uses 1 SPU for decryption and the other 5!! for DST decoding.
Although this process is quite optimal the current decoding speed has been measured to be 0.9MB/sec
for a 2 channel rip. So for 2ch DST tracks the write speed to disc will be around 2.3MB/sec, for a
multi-channel the write speed is a bit higher (2.4MB.sec) but decoding is even slower at 0.6MB/sec.
