GainPork™ the minimalist crispy skin pork
41 replies to this topic
#1 gainphile
gainphile
    dip∞le
  • 1,563 posts
Posted 09 September 2010 - 01:53 PM
I've cooked this for a few occassions and generally people like it. So this is how it's done
Like a good gainclone amplifier, the ingredients are minimal:
- Pork belly, salt
- chinese wine (optional).
  • Buy 1kg pork belly from the local butcher, and do not ask him to score. Do not wash.
  • Score into squares so it's easier to cut later (and let the fat cook the skin). Not too deep, and should not touch the meat part.
  • Sprinkle salt (can be normal salt/sea salt) and cover with paper towel for 5 minutes. The salt will suck the moisture out of the skin, and the paper towel will suck even more. Do this twice to get extra-dry skin which is the prime requirements for "crackling"
  • Sprinkle salt throughout the prepared meat
  • Pre-heat oven to 225-230 °C and put the meat low enough to allow even distribution of heat. Use top heater only.
  • Cook for 10-15 minutes. It should come out like the picture above.
  • Optionally brush a bit of Chinese cooking wine on the skin part (not too wet!). Normally I use paper towel to do this and not a brush. Sprinkle bit more salt and back in the oven.
  • Continue to cook at 225-230 °C for another 10-15 minutes until the skin all crackles like above. Observe closely! as the transition between well-crackling and burnt black is very quick.
  • Once the skin is all blistered and you see a hint of burnt section, set the oven temperature down to 120 °C and continue cooking for 45-60 min. This is to allow the meat to cook.
  • Once done, put in a plate and leave alone for 20 minutes. Do not be tempted to cut before this time as it will be too juicy and ruins the dryness of crackling. Do not wrap in foil.
There you go... and eat in moderation (if you can)
My equipments have dissapeared....
http://gainphile.blogspot.com
#2 leck
leck
  • 175 posts
Posted 09 September 2010 - 02:01 PM
Definitely giving this one a go. Thanks so much for posting this! Crackling can be hit and miss sometimes, that looks like a surefire way to get it spot on
#3 Keith_W
Keith_W
    Advanced Member
  • 9,346 posts
Posted 09 September 2010 - 02:03 PM
Looks good gainphile! :) I think the Chinese version normally has 5-spice powder in it though.
#4 xtrachewy
xtrachewy
  • 710 posts
Posted 09 September 2010 - 02:08 PM
For a variation, lightly dust Asian five-spice powder and poke several thin slivers of garlic into the meat to marinade overnight - steam for ~30-45 minutes until skin is soft.....remove and allow to cool for ~20 min uncovered - this helps the skin to dry.
Using a paddle with lots of fine nails hammered through, repeatedly tap the softened skin to create heaps of fine holes....rub salt in generously and bake as above (but less time).
The steam/bake technique will help keep the meat tender/moist with a finely textured crackle. Serve with fruity sauce: plum, apple, HP brown sauce....
Edited by xtrachewy, 09 September 2010 - 02:42 PM.
#5 wadiaman
wadiaman
  • 233 posts
Posted 09 September 2010 - 02:12 PM
Thanks Gainphile. I am getting hungry just reading your post!
Cheers, Greg
2 Channel: Wadia, First Watt, Zu Headphone: Apple, Benchmark, Yamamoto, Grado
'I lost my shirt, I pawned my rings. I've done all the dumb things'
#6 Grainy
Grainy
  • 491 posts
Posted 09 September 2010 - 02:28 PM
Ahhh, the secret to good crackling huh? I had a delicious and crispy Pork Belly at Cutler & Co the other night. I'll be giving this a go. Thanks :)
There is a better than 50% chance that I have just taken this thread off topic......
#7 xtrachewy
xtrachewy
  • 710 posts
Posted 09 September 2010 - 02:40 PM
The 1 kg steak (shared b/w two), cooked for 1 hr at Cutler & Co was tender in the middle with a proper dark crust.....much better than Rockpool.
#8 Jake
Jake
    Jakerator
  • Moderators
  • 10,130 posts
That looks fantastic GP! Unfortunately though my new food regime would not allow me to even smell it.
Can’t tell if you're serious or trolling hard. The internet has dulled my sarcasm receptors.
#9 gainphile
gainphile
    dip∞le
  • 1,563 posts
Posted 09 September 2010 - 02:46 PM
The crackling is one thing, which I found out not too difficult to get. But there are different grade of crackling. In this case I have sacrified lightness of crackling to success rate. Also there is a certain grade of dryness into the meat which should not be the case.
Regarding the additional spices, I found them make the food yummy but also lose its "porkiness". So it's a matter of taste like eating fries with sauce.
This little place at Elizabeth st. is currently my benchmark. The dish is called "Crispy skin pork with vegetable on rice". Repeat that a few times :). Do not go there during lunch time due to long queue.
#10 xtrachewy
xtrachewy
  • 710 posts
Posted 09 September 2010 - 04:00 PM
Looking forward to Peking GainDuck...... :popcorn
#11 xtrachewy
xtrachewy
  • 710 posts
Posted 30 September 2010 - 04:51 PM
Crispy Pork with noodles for dinner - yummo.
#12 Rockford
Rockford
  • 218 posts
Posted 30 September 2010 - 08:21 PM
I love Pork Belly and I am so going to try this.
#13 My Rantz
My Rantz
  • 496 posts
Posted 15 November 2010 - 12:25 PM
Unfortunately not recommended for diabetics or those with cardiac histories.
Double damn it!
#14 JCR33
JCR33
  • 1,684 posts
Posted 15 November 2010 - 12:53 PM
I tried doing the same and this was the end result..., back in March this year...:D
JCR33
User and importer of Kondo, 47 Labs and Ocellia
#15 damohpi
damohpi
  • 583 posts
Posted 15 November 2010 - 01:31 PM
the MIL swears by leaving the pork belly uncovered in the fridge overnight after salting to maximise the drying out, so I will try the paper towel trick and see how it compares as 24hr notice is far too much forethought/planning for me :D thanks for the tip
#16 Rockford
Rockford
  • 218 posts
Posted 09 January 2011 - 07:01 PM
Gave it a bash tonight.
Got some Trunkey Farm Pork from Orange and heaped on the Maldon salt.
Ate it with roast potatoes and veges and a very nice 2006 Main Ridge Half Acre Pinot Noir.
Yummo, the meat was so moist and tender and the crackling just the right crunchy consistency. (my arteries are having a stop work meeting as a type...)
#17 Moondog
Moondog
  • 2,564 posts
Posted 09 January 2011 - 07:50 PM
That food is an utter disgrace, But dang im sure it tastes awesome.
MD
Enjoy The Music , Not the Sound
#18 xtrachewy
xtrachewy
  • 710 posts
Posted 09 January 2011 - 11:26 PM
Personally I would have gone with a dry apple cider to cut through the richness.....
Lovely pork porn - it's wrong to be hungry (again) at 00:25 :)
#19 Monkeyboi
Monkeyboi
  • 2,877 posts
Posted 10 January 2011 - 12:31 AM
OMG, how did I manage to miss this thread? :) This has to be one of my favourite dishes. gainphile, I just know your recipe is going to be my undoing. Gotta give your method a try soon. :)
Alan R.
Amplification: ME-850HC power amp, Sony STR-DA5600ES receiver, Sony TA-P9000ES pre-amp, Sony TA-N9000ES x2 power amps, Sony TA-E9000ES pre-pro, custom analogue buffer / switch, custom RIAA pre-amp.  Sources (digital): Sony SCD-XA5400ES SACD player, Sony MDS-JA3ES minidisc deck, Tascam DA20 Mk2 DAT deck, Philips DCC900 Digital Compack Cassette deck, Sony BDP-S370 Blu-ray player, Sony PS3 slim, Pioneer DV-S838A DVD-Audio player.  Sources (analogue): Technics SL1200 GLD turntable, Tascam 42B reel to reel, Sony TC-K570 cassette deck.  Speakers: Quad ESL2905 (fronts), KEF Q75 (rears), Richter Odin (sub) & Unicorn (centre). DACs: CEC DX-71 Mk2, Emotiva XDA1.  Cartridges: Shure V15 type 3 (MR stylus), Shure V15VxMR.  Misc: dbx 119, Aurex AD-2 noise reduction system, Sony SQD2010 SQ/QS quad decoder, JVC 4DD5 and Pioneer QD-240 CD4 demodulators, VPI record cleaning machine.
Computer room system: Sony STR-DA5200ES receiver, Boston Acoustics CR9 speakers, Technics SL1200 (original version from the 70s)
Semi retired gear: Equinox Audio Jupiters, Sony SCD-XA333ES SACD player, Philips DCC130 portable Digital Compact Cassette player, Sharp Minidisc portable, 250W + 250W monoblock power amps.
Retired gear in storage: Sansui AU-417, Sansui TU-417, Richter Wizards, KEF Concerto x2 pairs, Sony ST-JX741 tuner, Sony CDP-338ESD CD player, Yamaha CA700 integrated amp,Tascam analogue mixing desk and a lot more other stuff than I care to list (mainly video)
#20 gainphile
gainphile
    dip∞le
  • 1,563 posts
Posted 10 January 2011 - 12:31 PM
I normally consume something like this once in 1 or 2 months. But this holiday season it had been pretty bad I admit, like twice a week.
One thing which I haven't figured out is how to make that yummy brownish sauce/juice as in the chinese place.
#21 lem
lem
  • 22 posts
Posted 14 January 2011 - 03:52 PM
This recipe works great with pork belly. Even better on a weber bbq.
http://appetiteforch...t-pork-char-siu
#22 xtrachewy
xtrachewy
  • 710 posts
Posted 14 January 2011 - 05:11 PM
Lem,
Get some rose-scented Chinese wine and add a good dash to the marinade - it adds a complex aroma and makes all the difference (for example: http://rasamalaysia....ecipe-char-siu/)
#23 lem
lem
  • 22 posts
Posted 14 January 2011 - 06:10 PM
hello xtrachewy,
thanks for the tip. i will hunt down some rose scented wine next time i visit my local asian supermarket.
lem
#24 xtrachewy
xtrachewy
  • 710 posts
Posted 26 November 2011 - 10:14 PM
hmmm....love lechon and Honeybee chicken with banana ketchup :) And those crispy fried tiny crabs ... quite tasty with San Miguel beer.
Agree - Italian porchetta etc.
#25 aad_ht
aad_ht
  • 389 posts
Posted 28 November 2011 - 12:26 PM
Ohhh that looks awesome. I must try it this week :) So the crucial part is getting all the moisture out so it goes crispy.
Thanks :P
I'm curious to see what deep fried battered pork tastes like?
Cycling Motivation.com.au - Pedal Powered Passion
#26 Grumpy
Grumpy
    G.O.F.
  • 9,767 posts
Posted 28 November 2011 - 01:16 PM
I have 2 roast pork in the freezer - one for Xmas the other might get cook REAL soon me thinks.
YUMM! bastards!!!!!!!!!!!!!!!!!!!!!
PEACE
2 channel set-up -Garrard 401 and Yamaha PF800 TT's - CA640Cv2 CD- NAD116 Pre - Rotel RB1070 amp- VAF DCX1v2 speakers.
A/V -Denon3802-PanasoniicXW300PVR-MS fronts-VAF DC6-2xJaycar 350w 12"subs-Yamaha & Realistic rears.
#27 gainphile
gainphile
    dip∞le
  • 1,563 posts
Posted 28 November 2011 - 01:43 PM
Does anyone know how to make that brownish sauce?
You know the one at Chinese restaurant when ordering roast pork on rice???
#28 aad_ht
aad_ht
  • 389 posts
Posted 28 November 2011 - 02:08 PM
You sir owe me a new keyboard, its saturated in saliva hahaha. All this talk of food..... Must resist leaving office desk for food....
#29 Grumpy
Grumpy
    G.O.F.
  • 9,767 posts
Posted 28 November 2011 - 03:00 PM
You sir owe me a new keyboard, its saturated in saliva hahaha...
Yea! same here. Had a Fritz and sauce sandwich for lunch - not quite a roast Pork:)
PEACE
#30 xtrachewy
xtrachewy
  • 710 posts
Posted 28 November 2011 - 03:21 PM
Possibly like sweet & sour pork without the sauce?
Though in my family, we dust the pork pieces in a flour blend (plain & rice) for a crisp (and less battery!) result....and I first subtly marinade the meat with a bit of rice & Stones ginger wine.
In general fine 'scoring' will produce a finer textured crackle but keeping the skin dry (or rubbing with salt, and sometimes oil and/or lemon juice) and high temperature help enormously to produce lovely crackle.... though I've had slow long cooked (lower temp) Italian porchetta with amazing crackle.
I've also had crackle where the skin is removed from the meat and 'crackled' separately sandwiched b/w two metal trays under high heat - this produces a flat crackle (good presentation).
And Grandma used to make a Asian hotpot with pork crackle - it would soften and become quite spongey (soaks up the gravy). Yum.
#31 b4sound
b4sound
  • 606 posts
Posted 28 November 2011 - 03:42 PM
Stop It!!! Might need to visit Pacific House now...
Simpli-FI Pilot: Sonos ZP90 > Empirical Audio Synchro Mesh > Schiit Bifrost > Leben C300XS > Harbeth P3ESR
#32 xtrachewy
xtrachewy
  • 710 posts
Posted 01 December 2011 - 02:27 PM
So I did a Google Image search for 'roast pork' - oh my Lordy (gulp) ... did I have food-porn thoughts..... now must go and scratch that itch !!
#33 mikizee
mikizee
  • 1,089 posts
Posted 01 July 2012 - 06:10 PM
Cooking this again tonight after a successful tryout last week. Must remember to take a photo tonight... it looked fantastic last time.
What to have with it... beer or red?
Adelaide Sales Representative
www.audiofidelity.com.au Posted Image Posted Image Posted Image Posted Image
Brinkmann MSB Technology SGR Audio
BRINGING YOU CLOSEST TO THE ORIGINAL SOUND!
#34 mikizee
mikizee
  • 1,089 posts
Posted 01 July 2012 - 06:25 PM
Looking good so far... back in the oven it goes
#35 LogicprObe
  • 8,858 posts
Posted 01 July 2012 - 06:49 PM
Yes...........the rack makes a big difference.
#36 Super Mustud
Super Mustud
  • 2,500 posts
Posted 01 July 2012 - 06:55 PM
I promised myself some months ago to try this and forgot.
Glad this thread has reappeared. Good on you mikizee
Posted by prof - "It just does get a bit tedious seeing speculation, hyperbole and exaggeration masquerading as fact....over and over and over with no attempt or interest in real information."
#37 mikizee
mikizee
  • 1,089 posts
Posted 01 July 2012 - 08:33 PM
Absolutely orgasmic
#38 emesbee
emesbee
  • 5,109 posts
Posted 02 July 2012 - 02:26 PM
Looks a lot like bacon.
Knowledge is knowing a tomato is a fruit.
Wisdom is not putting it in a fruit salad.
#39 Super Mustud
Super Mustud
  • 2,500 posts
Posted 02 July 2012 - 05:10 PM
A beautiful job, mikizee.
I am inspired. Just need to get Mrs Mustud out of the way for a few hours.
Damn cholesterol police....
#40 mikizee
mikizee
  • 1,089 posts
Posted 03 July 2012 - 10:12 AM
Thanks Mustud - it was delicious. Really should ramp up my cardio workouts to burn it off.... but its so bloody cold. Maybe I'll just stay inside and watch TV.
#41 progladyte
progladyte
    The Dismembered Member
  • 1,353 posts
Posted 27 July 2012 - 10:21 PM
Excellent job there!
There are 3 levels of intelligence amongst humans today.
The most intelligent learn by listening to other intelligent people.
The second most intelligent learn by reading intelligently written books.
The rest of us learn by pissing on the electric fence.
#42 LogicprObe
  • 8,858 posts
Posted 27 July 2012 - 10:32 PM
This thread is making me fat!
Next..................I'll be needing a lawyer!
