SOLD: FS: Xindak 8800MN Class A 200 watt monoblocks
  • This topic is locked This topic is locked
52 replies to this topic
#1 Wampy1234
Wampy1234
  • 63 posts
Posted 27 April 2010 - 03:03 PM
Pair of Xindak XA8800MN Class A 200 watt monoblocks
Price: $1800
Payment Method: Pickup - Cash, COD
Condition: Excellent
Reason for selling: Replacing with a more power efficient Class D amp.
Extra Info: These amps retail for $5,000 from Australian stores, see Aslan Acoustics or Audio Direct.
Specifications:
Rated Power: 200W/channel (8ohms load) 400W/channel (4ohms load)
Class A Power: 50W/channel(8ohms load)
Power Consumption: 400W
Frequency Response: 5Hz~150KHz (±0.5dB)
T.H.D : ≤0.025%(Rated Power)
S.N.R : ≥108dB (A-weighting)
Input Sensitivity: 1.7V
Net Weight: 24Kg/channel
Dimension (W*H*D): 305mm*202mm*427mm (For one channel only)
I'm happy to provide a demo before purchase.
Pictures added:
[ATTACH=CONFIG]16984[/ATTACH][ATTACH=CONFIG]16975[/ATTACH][ATTACH=CONFIG]16978[/ATTACH][ATTACH=CONFIG]16982[/ATTACH][ATTACH=CONFIG]16977[/ATTACH][ATTACH=CONFIG]16979[/ATTACH][ATTACH=CONFIG]16976[/ATTACH]
Edited by Wampy1234, 05 May 2010 - 10:43 AM.
added pictures.
#2 JA
JA
    Moderator
  • Moderators
  • 3,962 posts
Posted 27 April 2010 - 05:33 PM
Hello Wampy,
your advert is up and going.
I take it you mean a pair of these amplifiers. Can you please edit/clarify your ad to include this detail or simply show a pic?
Best
JA
The GFC was nothing compared to what we will see in the next 1-2 years....
Eliminate debt, Cash up, maybe even gold/silver-up and hunker down.
Sell high, buy low.
Evidence and knowledge is out there.... Let discovery be your reward
Have Fun
JA
Nessun Dorma @ 12yoPosted Image
#3 rantan
rantan
    dazed & confused
  • 2,565 posts
Posted 27 April 2010 - 06:12 PM
I must admit I had no idea these monos were class A.
No offense to the OP, but are you sure?
Either way these are wonderful amps and a great buy at the price.
Edited by rantan, 27 April 2010 - 08:05 PM.
#4 NoFidelity
NoFidelity
  • 93 posts
Posted 27 April 2010 - 06:25 PM
Wrong thread. Sorry, nothing to see here, moving right along. :S
Edited by NoFidelity, 27 April 2010 - 06:29 PM.
#5 Yamaha Man
Yamaha Man
    Yamaha as in NS-1000 not R1.
  • 1,781 posts
Posted 27 April 2010 - 06:54 PM
Bargain!!!!!!!!!!
Good judgement comes from experience and a lot of that comes from bad judgement.
#6 turntable
turntable
  • 5,783 posts
Posted 27 April 2010 - 07:06 PM
Is this the Australian model that is imported by the distributor or an import from HK/China ebay ? ie, Is it a true 240 volt amplifier or 220 volts?
I'm bored
I'm the chairman of the bored
#7 dr-wyas
dr-wyas
  • 219 posts
Posted 27 April 2010 - 11:46 PM
My guess would be imported 220V versions, as I think the 240V's are model XA8800MNE.
I've been been keen on a set of these for a while and if you lived closer to southeast QLD I'd be making you an offer. I think the freight cost from WA on these would be pretty crazy, so might have to pass.
Can I ask Wampy what Class D amp(s) you're upgrading to, and if the heat and power consumption was a concern with the Xindak's? (happy to PM if you want).
#8 Wampy1234
Wampy1234
  • 63 posts
Posted 28 April 2010 - 01:09 AM
Hi Turntable, I'd need to confirm with THOMO on these forums as I am the second owner.
The unit has 3 check boxes on the back with AC input power ratings:
110/120V ± 10% 50Hz T10A
220 ± 10% 50Hz F10A
230/240 ± 10% 50Hz F10A
The 230/240V one is selected so to speak.
#9 Wampy1234
Wampy1234
  • 63 posts
Posted 28 April 2010 - 01:12 AM
Hi Rantan,
Class A is specifically labeled on the mono's so I assume that is correct, they are also referred to as Class A whenever I found the tech specs online.
Regards,
Edited by Wampy1234, 28 April 2010 - 01:20 AM.
#10 Wampy1234
Wampy1234
  • 63 posts
Posted 28 April 2010 - 01:18 AM
Hey dr-wyas,
I swapped them out for a Wyred 4 Sound ST-1000 stereo amp.
I wasn't so much concerned about the power consumption but yes the heat was one of the reasons I decided to replace them, don't get me wrong, there is no issue running these amps under most conditions for a good 4 hours but after that I would give them a feel every so often to judge when they should be shut off to cool down. we're talking 10-15 mins before they are cool to the touch and ready to go on for another few hours.
The issue I had is that these amps were connected to my main setup which consists of my PC for music, movies, TV and also a few game consoles, I wanted an amp I could turn on and forget about for the rest of the day.
Regards,
#11 My Rantz
My Rantz
  • 496 posts
Posted 28 April 2010 - 01:41 PM
Hi Rantan,
Regards,
These are Class A for the first 50-60 watts. So technically they should be called class A/B amps. I have the 220v version bought from China, but I have a power regualtor set to 220v. These are truly wonderful amps. Much nicer than my previous MF A5 imho.
You can turn them on and forget about them, but best doing that in winter only :)
They do get hot!
I run these amps for hours and hours at times - even in summer. Class A amps will run very hot, it's not a flaw. But a fan in their direction can help confidence.
Edited by My Rantz, 28 April 2010 - 01:49 PM.
adding more information
#12 Wampy1234
Wampy1234
  • 63 posts
Posted 29 April 2010 - 01:37 AM
bump and pictures added.
#13 My Rantz
My Rantz
  • 496 posts
Posted 29 April 2010 - 08:12 AM
220 ± 10% 50Hz F10A
Judging from your pics, the amps seem to be the 220V rating. According to my mn's, the white spot indicates the power rating.
#14 Wampy1234
Wampy1234
  • 63 posts
Posted 29 April 2010 - 09:46 AM
Fair call, I hadn't looked before the question was raised earlier in the thread and have been running the amps fine on my mains without a power regulator.
I've done a bit of reading about it and the opinion of most people is that 220V gear will not have a problem running on 230V mains, none the less, as you said earlier though a regulator is an option for people who are concerned.
Regards,
#15 My Rantz
My Rantz
  • 496 posts
Posted 29 April 2010 - 01:51 PM
Yep, they mostly will run fine on std mains, but voltages can run as high as 256v as I've witnessed on our PS10 (or more I am led to believe). I've been told that a lot of gear sold here in Aus is really 220v because of larger European sales even though they may be marked 230 or 240 volts as the extra costs by manufactures for different transformers aren't worth it. I don't know if that's true or not, I just wasn't willing to take the chance since most of my stuff is either 220 or 230v, a regulated 220v with the PS10 will be just fine afaic. The 220v XA8800mn's have a 10% allowance meaning they should be okay at 242V.
Your amps represent great value at the price - someone will be getting a bargain and a pair of powerful and beautiful sounding mono blocks. Good luck with them.
#16 soundfan
soundfan
  • 4,303 posts
Posted 29 April 2010 - 04:55 PM
Hi My Rantz,
Can you elaborate on what the white spot indicates, and what the signifigance is? I'm at work so cannot check, but my Jungson amp (another Chinese amp) has 240v printed on back, but I know these amps are available in 220,230 v as well. Will be interested to see whether it is similarly marked.
Chris
An audiophile uses music to appreciate his hi fi, a music lover uses hi fi to appreciate his music. I am a music lover.
#17 My Rantz
My Rantz
  • 496 posts
Posted 29 April 2010 - 05:18 PM
There is a table printed on the back of the amps with 3 sets of voltages.
To save me getting the crane to move the amp out so I can read it, you can look at the pic in the first thread and see the table.
That one also has a black spot on the 240v but I think it's possible someone may have added that - possibly in China
The white spot aligns with the voltage of the transformer of the amp in question. Hope that helps Soundfan.
#18 Wampy1234
Wampy1234
  • 63 posts
Posted 02 May 2010 - 12:19 PM
bump for good measure.
#19 Wampy1234
Wampy1234
  • 63 posts
Posted 04 May 2010 - 12:42 PM
bump, bump, bump.
#20 Wampy1234
Wampy1234
  • 63 posts
Posted 05 May 2010 - 10:43 AM
Bump and price drop.
#21 rantan
rantan
    dazed & confused
  • 2,565 posts
Posted 05 May 2010 - 02:45 PM
These are great amps and if I was looking for something in this style, I would buy these in a heartbeat. The price is a bargain, but when you list a FS here, you are facing the hardest set of potential buyers I have ever seen. I truly wish you well
Good luck mate.
Edited by rantan, 05 May 2010 - 02:49 PM.
typos
#22 Wampy1234
Wampy1234
  • 63 posts
Posted 08 May 2010 - 11:31 AM
bump again
#23 Wampy1234
Wampy1234
  • 63 posts
Posted 10 May 2010 - 09:51 AM
Bump again, would it be possible for a mod to clean up some of the bump posts please :P
#24 Wampy1234
Wampy1234
  • 63 posts
Posted 12 May 2010 - 09:22 AM
another bump
#25 Wampy1234
Wampy1234
  • 63 posts
Posted 14 May 2010 - 11:29 AM
Bump again, don't miss out on this great buy folks.
#26 Wampy1234
Wampy1234
  • 63 posts
Posted 17 May 2010 - 11:21 PM
bump again
#27 Wampy1234
Wampy1234
  • 63 posts
Posted 25 May 2010 - 09:53 AM
bump again
#28 Wampy1234
Wampy1234
  • 63 posts
Posted 27 May 2010 - 11:50 AM
Bump again.
#29 My Rantz
My Rantz
  • 496 posts
Posted 27 May 2010 - 12:44 PM
I can't believe these amps haven't gone yet. Someone would have to point a gun at my head to get mine. What a great bargain!
#30 Nevagoodenuff
Nevagoodenuff
  • 62 posts
Posted 27 May 2010 - 01:14 PM
Increadibly tempted!! not quite the specs Im after and have been spending too much lately but ...mmm
#31 Wampy1234
Wampy1234
  • 63 posts
Posted 01 June 2010 - 10:48 AM
bump again
#32 Wampy1234
Wampy1234
  • 63 posts
Posted 02 June 2010 - 01:08 PM
Will be putting these up on eBay next week.
#33 Crannie
Crannie
  • 59 posts
Posted 02 June 2010 - 11:04 PM
Wimpy, any idea what it would cost to send to Sydney.
#34 Wampy1234
Wampy1234
  • 63 posts
Posted 03 June 2010 - 09:41 AM
Hi Crannie,
Could you provide a postcode and I'll get a quote using http://transdirect.com.au/
Regards,
#35 danter
danter
    dismembered
  • 2,768 posts
Posted 03 June 2010 - 10:00 AM
Try Smartsend at least - I could bore you with my numerous Transdirect horror stories, but needless to say, would never use them again (lost parts, damaged goods, clever insurance outs etc)
Main: SB Touch / Rega P3 / Audio-gd CD7 / Audio-gd Reference 10.2 / Marantz 240 / Spendor SA1
Office: SB Touch / Audiolab 8000S / JB3s
#36 Wampy1234
Wampy1234
  • 63 posts
Posted 03 June 2010 - 10:13 AM
Thanks for the suggestion, I haven't used them before but will steer clear.
Regards,
#37 Wampy1234
Wampy1234
  • 63 posts
Posted 09 June 2010 - 10:24 AM
Item listed on eBay: http://cgi.ebay.com....#ht_3012wt_1137
#38 Wampy1234
Wampy1234
  • 63 posts
Posted 16 June 2010 - 10:53 AM
Item re-listed, this time offering free postage Australia wide with a starting bid of $1,600.
http://cgi.ebay.com....#ht_1748wt_1137
#39 dr-wyas
dr-wyas
  • 219 posts
Posted 16 June 2010 - 11:23 AM
I demoed these amps at My Rantz' place a couple of weeks ago and they are SUPERB. A great future-proof purchase as I'm sure they've got enough juice to drive just about any speaker. Good luck Wampy!
#40 Wampy1234
Wampy1234
  • 63 posts
Posted 16 June 2010 - 12:52 PM
Thanks for the free plug dr-wyas :party
#41 Wampy1234
Wampy1234
  • 63 posts
Posted 21 June 2010 - 01:07 PM
No sale on eBay, trying this thread for another week or so..
Bump and price drop to $1,600.
#42 Rhett Morson
Rhett Morson
    Suspended
  • Banned
  • 842 posts
Posted 21 June 2010 - 02:51 PM
have you tried a hifi store that does second hand gear eg len wallis or decibel hifi?
maybe they could find a buyer youre not reaching online???
THREAD CLOSED - email me
morson@bigpond.com
Ph. 0243 522 188
#43 My Rantz
My Rantz
  • 496 posts
Posted 21 June 2010 - 03:34 PM
Wampy, if I had the spare cash I'd buy 'em for spares, though I doubt I'd ever need them.
Seriously people, you could not get better amps anywhere close to this price.
#44 Wampy1234
Wampy1234
  • 63 posts
Posted 22 June 2010 - 12:16 PM
Bump ;)
#45 Wampy1234
Wampy1234
  • 63 posts
Posted 23 June 2010 - 08:17 PM
Bump again
