Grumpy Posted August 6, 2015 Share Posted August 6, 2015 Bought a Toshiba USB HDD for my new TV today for easy TV recording - It records, but doesn't play the recorded content back. I then re-read the TV manual and a quick look on Google seems to suggest that only certain devices will work properly with the Pana TV's Has anyone had any experience with these USB HDD thingos on the Pana TV's please? Link to comment Share on other sites More sharing options...
Addicted to music Posted August 6, 2015 Share Posted August 6, 2015 Not on a Pana, but on a Samsung you get a prompt to format the drive. 1 Link to comment Share on other sites More sharing options...
Kaynin Posted August 6, 2015 Share Posted August 6, 2015 Yeah I've got 2 Pannies and use SD cards. I had to format the cards first, and you can't then use the storage device on another Pannie, they get formatted to work with the TV that formatted it... Link to comment Share on other sites More sharing options...
Grumpy Posted August 6, 2015 Author Share Posted August 6, 2015 I did go through all the format prompts and it did record but I can't play it back?? Link to comment Share on other sites More sharing options...
betty boop Posted August 6, 2015 Share Posted August 6, 2015 Yeah I've got 2 Pannies and use SD cards. I had to format the cards first, and you can't then use the storage device on another Pannie, they get formatted to work with the TV that formatted it... can only presume this is to protect copy right ? i.e. cant take the hard drive and play it on other peoples TVs ? pvrs are so cheap these days wouldn't it be cheaper to get one of those instead of a hard drive ? Link to comment Share on other sites More sharing options...
Kaynin Posted August 6, 2015 Share Posted August 6, 2015 can only presume this is to protect copy right ? i.e. cant take the hard drive and play it on other peoples TVs ? pvrs are so cheap these days wouldn't it be cheaper to get one of those instead of a hard drive ? Yeah, that makes sense, can be annoying when you're in a position to watch a recorded FTA show and want to do it on the second TV. @Grumpy are you absolutely sure you recorded to the device? I know on mine when I chose to record a program I have to flick through the options of "USB HDD Rec"., "SD Card Rec." and "Reminder". I'll have a flick through my menus and see if there's a playback option hidden away somewhere...rather than reading the manual... :lol: Link to comment Share on other sites More sharing options...
Kaynin Posted August 6, 2015 Share Posted August 6, 2015 Have you gone into : MENU - SETUP - RECORDING SETUP - USB HDD SETUP? Other than this, I'm out of ideas and can't help Link to comment Share on other sites More sharing options...
Grumpy Posted August 6, 2015 Author Share Posted August 6, 2015 Have you gone into : MENU - SETUP - RECORDING SETUP - USB HDD SETUP? Other than this, I'm out of ideas and can't help Yea, did all that thanks Kaynin Apparently a Western Digital device will work? I'll ring Panasonic tomorrow before I return the Toshiba USB thingo to make sure. Thanks all for your input. 1 Link to comment Share on other sites More sharing options...
Hippy Posted August 6, 2015 Share Posted August 6, 2015 An old PC put in a nice pretty slimline case with a TV tuner and a HDD can record a couple shows at once and let you watch a 3rd. If you throw in a wifi card or plug it into the home network you can then stream from a NAS or another computer or watch stuff on the internets like youtube. Wireless mouse and KB and away you go Id be happy to help you set up a HTPC box. Or for plug and play the WD media players with built in HDD are decently priced and work pretty good. In my experiences the plugging of a HDD or SD card into TVs can be a bit hit and miss. Link to comment Share on other sites More sharing options...
Grumpy Posted August 7, 2015 Author Share Posted August 7, 2015 Thanks Hippy - I have a PVR, but I want the USB thingo for easy TV recording for Georgina, my partner, who struggles with all things A/V Link to comment Share on other sites More sharing options...
Grumpy Posted August 7, 2015 Author Share Posted August 7, 2015 All fixed. What I first bought was a Toshiba portable HDD, but what I needed was a HDD that plugged into the mains power. Bought a SEAGATE 2TB Expansion desktop Drive AND Georgina has already recorded with it - Simple!! no more "how do I switch the PVR recorder on" 1 Link to comment Share on other sites More sharing options...
emesbee Posted August 7, 2015 Share Posted August 7, 2015 (edited) All fixed. What I first bought was a Toshiba portable HDD, but what I needed was a HDD that plugged into the mains power. Bought a SEAGATE 2TB Expansion desktop Drive AND Georgina has already recorded with it - Simple!! no more "how do I switch the PVR recorder on" I bought a 50" Panasonic in January 2014, and also use it with a Seagate 2TB USB drive for recording and playback (mains powered, presumably the same one as yours - they were on special in Officeworks at the time). It works fine. Edited August 7, 2015 by emesbee Link to comment Share on other sites More sharing options...
Addicted to music Posted August 7, 2015 Share Posted August 7, 2015 All fixed. What I first bought was a Toshiba portable HDD, but what I needed was a HDD that plugged into the mains power. Bought a SEAGATE 2TB Expansion desktop Drive AND Georgina has already recorded with it - Simple!! no more "how do I switch the PVR recorder on" @@Grumpy, How many USB drives do you have on the back of the Pana? The reason I'm asking is that the Samsung I have has 2 USB and only one USB slot is HDD enable that has the HDD and 1A label that means it's capable of driving a portable USB HDD without power. With my Samsung the Toshiba HDD you had would have worked fine with this USB with the 1A capability, however the other USB slot would not be able to power that portable HDD Link to comment Share on other sites More sharing options...
Grumpy Posted August 7, 2015 Author Share Posted August 7, 2015 I bought a 50" Panasonic in January 2014, and also use it with a Seagate 2TB USB drive for recording and playback (mains powered, presumably the same one as yours - they were on special in Officeworks at the time). It works fine. Got mine from Officeworks also.($109) and we are loving the ease of it all tonight. A.to.Music I have 3 USB ports on the the TV and the number 3 port is the one recommended. Link to comment Share on other sites More sharing options...
mickj1 Posted August 7, 2015 Share Posted August 7, 2015 Hey Grumps - I suppose you'll need most of the 2TB space to record the Australians batting cheers mick Link to comment Share on other sites More sharing options...
Addicted to music Posted August 7, 2015 Share Posted August 7, 2015 Got mine from Officeworks also.($109) and we are loving the ease of it all tonight. A.to.Music I have 3 USB ports on the the TV and the number 3 port is the one recommended. What I'm saying to you is that at least one of those USB ports should have had a 1A capability that is labelled HDD, this port should have been sufficient to drive up to a USB 3.0 2TB HDD with out the ones using external power. I can do that with my Samsung and so can my son's Samsung. Link to comment Share on other sites More sharing options...
Grumpy Posted August 7, 2015 Author Share Posted August 7, 2015 What I'm saying to you is that at least one of those USB ports should have had a 1A capability that is labelled HDD, this port should have been sufficient to drive up to a USB 3.0 2TB HDD with out the ones using external power. I can do that with my Samsung and so can my son's Samsung. Not with the Panasonics. I rang them today before I returned the portable HDD and was told by the Panasonic techs that a powered one was needed for record and playback - they were right . (it is a USB 3.0 2TB thingie!) It's all new stuff to me, but I'm happy as can be with the set-up now. 1 Link to comment Share on other sites More sharing options...
Addicted to music Posted August 7, 2015 Share Posted August 7, 2015 Not with the Panasonics. I rang them today before I returned the portable HDD and was told by the Panasonic techs that a powered one was needed for record and playback - they were right . (it is a USB 3.0 2TB thingie!) It's all new stuff to me, but I'm happy as can be with the set-up now. Gee that's a real bummer @@Grumpy, and it's for a Pana as well, those portable HDD are so handy to have, and because there USB 3.0 you can transfer a rip CD in a matter of a minute or less depends on the content compared to USB 2.0This is what the back of a Samsung looks like so you can see what I'm referring to: Link to comment Share on other sites More sharing options...
emesbee Posted August 8, 2015 Share Posted August 8, 2015 Got mine from Officeworks also.($109) and we are loving the ease of it all tonight. A.to.Music I have 3 USB ports on the the TV and the number 3 port is the one recommended. I bought mine not long after I bought the TV. Was fairly lucky with the price, Officeworks had them going for $79 at the time. I compared them with HN and JB at the time, and they were the cheapest by far. Didn't last long at that price though. Link to comment Share on other sites More sharing options...
