Digital Man Posted August 21, 2016 Share Posted August 21, 2016 Hi, I wish to ask of you all, is this particular headphone amp, a, all valve unit ? or, is it a hybrid ? Thanks Link to comment Share on other sites More sharing options...
Neo Posted August 22, 2016 Share Posted August 22, 2016 Hi Glen I would say a hybrid design as all xcan h/amps are Neo Link to comment Share on other sites More sharing options...
Digital Man Posted August 22, 2016 Author Share Posted August 22, 2016 Hi, Thanks, I guess that answer the question, once and for all. Thanks all. Link to comment Share on other sites More sharing options...
Neo Posted August 22, 2016 Share Posted August 22, 2016 You may find this site interesting http://www.rock-grotto.co.uk/x-ccessories.html Neo Link to comment Share on other sites More sharing options...
Digital Man Posted August 22, 2016 Author Share Posted August 22, 2016 Hi, Yes, that is very interesting, have you personally tried the Music Fidelity X-Cans ? how would you compare them, to say, the Little Dot Mk II or Mk III ? Link to comment Share on other sites More sharing options...
Neo Posted August 22, 2016 Share Posted August 22, 2016 (edited) I started with xcan v-8p for my sennheiser hd 650 then got the v8 psu then got x10v3 buffer well 2 actually Still had them in 2 of my setups until recently, sold here as I restructured my setups and they were in surplus In regard to the other units haven't tried them so can't really comment Edited August 22, 2016 by Neo Link to comment Share on other sites More sharing options...
Digital Man Posted August 22, 2016 Author Share Posted August 22, 2016 Hi, How did you find the V-8p ? Did you use it with any grado's ? Link to comment Share on other sites More sharing options...
Batty Posted August 22, 2016 Share Posted August 22, 2016 I have the v3 X-Can used with AKG Q701s and I find it very good indeed, I have fitted the Rock grotto Capacitor upgrade kit which made a difference in both bass and treble. Link to comment Share on other sites More sharing options...
Neo Posted August 22, 2016 Share Posted August 22, 2016 I found v8p excellent, additional refinements were added when I got the dedicated psu. 1.3w into 32ohm that's plenty to drive even the most demanding headphones Unfortunately I only dealt with sennheiser headphones when I had that as a primary listening source, but can't imagine it being a bad match. So the headphones I used are sennheiser hd 650 300ohm, 500 and 558 which I believe are 50ohm a piece The other wonderful thing which can be done with is tube substitution or rolling but I never done that as I preferred the sound of ecc88 The other duty that v8p saw was as a single source valve preamp that was its primary purpose in the last year or so Neo Link to comment Share on other sites More sharing options...
Digital Man Posted August 26, 2016 Author Share Posted August 26, 2016 Hi, Are the Musical Fidelity Headphone amps, OTL ? Link to comment Share on other sites More sharing options...
Hydrology Posted August 26, 2016 Share Posted August 26, 2016 I have a X-Can V2 that I'm about to sell on the classifieds if youre interested @@LinearTracker. PM if you need any more info. Link to comment Share on other sites More sharing options...
Neo Posted August 26, 2016 Share Posted August 26, 2016 OTL? Link to comment Share on other sites More sharing options...
MusicOne Posted December 10, 2016 Share Posted December 10, 2016 On 8/26/2016 at 4:06 PM, Neo said: OTL? Output transformerless. 1 Link to comment Share on other sites More sharing options...
Digital Man Posted January 26, 2017 Author Share Posted January 26, 2017 Hi, Thanks for the reply, but, I did mention originally, that I do not want transformerless, plus, I've given up on head phone amps, I will have one built into my next Weston valve amp, in the near future Link to comment Share on other sites More sharing options...
